Dear nvidea Team and folks from the comunity,
I am trying to implement a2f as part of my production pipline for my current job. First of all: great Programm, thx 4 making this possible. Even if everything works great for me so far and i am really impressed by the results, there are a view issues in the process, that i dont really understand and they slowing me down.
I am using the Blender branch thats provided by omniverse for the export ( its so handy <3). The export is as easy as i t should be, as long i exporting only the mesh of my character. The first questions Starting with the import in a2f:
1: Is there a possibillity to export the model with the correct Axis. Its no dealbreaker, for sure but would be nice, if i dont have to set it up in a2f
2: When i seted up the axes, i prepare the character setup. Mostly i am just using the bodymesh for the skin, without any aditional meshes, to keep it as simple as possible. But when i press “Setup Character”, both of the mark meshes appear somewhere faaaar away from my mesh. As i found out i can jump to them in viewport by pressing “F” i found them. And its a pain to get them in the right position for every of my models. Is there a way to prefent that? Or is there a smarter way, to get them at least closer to my mesh?
as you can see in the picture my mark is somwhere in the background, and his coordinates are telling this as well.
when i set all the position transforms to 0 i can at least see mark, but he is still far in the background.
I also dont understand, why my character is on a total different spot then the mark meshes if i set their cordinates to 0/0/0…
Apart from that i am geting scarted to death everytime after my mesh fitting,
the post wrap and mesh fiting mostly works flawless <3
3: Sometimes it hapens, that the fingers for example are moving with the face. I have no clue so far where this comes from, but is there a way of dealing with this?
4:I didnt know what to expect as i tried to export it back to blender, but it was much easier then i thought.even if i was lucky and found a solution, i dont really understand that good whats happening. Pls tell me, if there is a better workflow, putting it back into blender then mine. For me it worked the best so far with an export of an Geometry USD Cache. i choose rigid xform as keys ( even if i dont know what that means^^??) because geo cach messing up the transforms if i open it up in blender. The first time i was successfull with it i used the import USD funktion of the omniverse belnder branch. Later on i discovered that i can load in every blender build the usd file into a meshsequence modifier (never worked with this before) and it works fine.
5: So far my last question is how to deal with corupted files. I know in produktion, there is only one answer: Backups! But as i tested it happend multiple times that i wasnt able to open the whole blender project (many different ones) as well as the a2f projects. Is there any recomendation from you?
I really apreciate your product, and i will be happy for any helping hand.
Ty
