I need to configure my C/C++ software per XML or JSON. Know someone the proper possibility for that NVidia-SOM to parse the XML and JSON files for reading and writing ?
We appreciate your help.
I hesitate to answer because I don’t know about the particular JSON you are asking about. I will say though that if you simply want to read and view XML, then something like xmllint
will work. There is also xmlcopyeditor
. Also, “bluefish
” isn’t technically an XML editor, but it can work with XML.
@waldemar.friesen there isn’t particular about Jetson to parse XML or JSON files, you would use a library for it like on other platforms. Personally, I use TinyXML2 and GitHub - nlohmann/json: JSON for Modern C++ for C++ libraries for these.
