Since today, when starting Steam, the update modal shows up, but then the user is logged out;
the session crashes with X11 I/O error
Oddly, when starting steam via terminal there are no X11 I/O errors, however I noticed that one of the games didn’t start (crashes before any window is opened) that would usually start, while another started fine.
Occurs on up-to-date arch with extra/nvidia 495.46-9. First time I experience this issue.
Here’s the journal:
Jan 18 20:33:50 hostname audit[4212]: USER_END pid=4212 uid=0 auid=1000 ses=13 msg='op=PAM:session_close grantors=pam_loginuid,pam_keyinit,pam_systemd_home,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_gnome_keyring acct>
Jan 18 20:33:50 hostname kernel: audit: type=1113 audit(1642534430.823:345): pid=4212 uid=0 auid=1000 ses=13 msg='op=logout id=1000 exe="/usr/bin/lightdm" hostname=hostname addr=? terminal=/dev/tty7 res=success'
Jan 18 20:33:50 hostname lightdm[4212]: pam_unix(lightdm:session): session closed for user <user>
Jan 18 20:33:50 hostname audit[4212]: USER_LOGOUT pid=4212 uid=0 auid=1000 ses=13 msg='op=logout id=1000 exe="/usr/bin/lightdm" hostname=hostname addr=? terminal=/dev/tty7 res=success'
Jan 18 20:33:50 hostname pulseaudio[4295]: X11 I/O error exit handler called, preparing to tear down X11 modules
Jan 18 20:33:50 hostname pulseaudio[4295]: X11 I/O error handler called
Jan 18 20:33:50 hostname at-spi-bus-launcher[4241]: X connection to :0 broken (explicit kill or server shutdown).
Jan 18 20:33:50 hostname systemd[1]: systemd-coredump@5-8575-0.service: Consumed 1.023s CPU time.
Jan 18 20:33:50 hostname audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@5-8575-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 18 20:33:50 hostname kernel: audit: type=1131 audit(1642534430.783:344): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@5-8575-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=suc>
Jan 18 20:33:50 hostname systemd[1]: systemd-coredump@5-8575-0.service: Deactivated successfully.
Jan 18 20:33:50 hostname systemd-coredump[8577]: [?] Process 4130 (Xorg) of user 0 dumped core.
Module linux-vdso.so.1 with build-id f4c0c67a495415ccf56ef21d6eaadfebc34186ec
Module libffi.so.8 with build-id f90d8b734f6de9b25faedb8cbfab7054dafc0a42
Module libgobject-2.0.so.0 with build-id e67b3a29cecdd98c3d8bd6eb7524a812331b20a2
Module libgudev-1.0.so.0 with build-id a9f734ea9206d637d5aacfbd86298c91cdc1a33a
Module libwacom.so.2 with build-id 1d9b89a6d39be5568d5f44888b8a74f46a30c152
Module libevdev.so.2 with build-id b62ae69f839f1b6b06ef2c1df19f25ff09b0d824
Module libmtdev.so.1 with build-id 0cea2a842ae9a0ef02a08477076caab0e5ac5e42
Module libinput.so.10 with build-id e03db31785b31a4e48fde375cf7e13e3a6ad604a
Module libinput_drv.so with build-id d9f69f11259485316bd206e67e34dd23bbede5cc
Module libnvidia-glcore.so.495.46 with build-id 8113b84202e276df12ecc4fc58788506fd5ba386
Module libnvidia-tls.so.495.46 with build-id 59f61b3d522665be01a2429d278e7892f4e56e41
Module libglxserver_nvidia.so with build-id b448f7b6982718772d814f0b5fd3a01a9c226578
Module libwfb.so with build-id e7f4027f76d37b1d8a37119132fa7e68fbe757ed
Module libstdc++.so.6 with build-id 9b5eeeb149bf3c4efe787fb398b44f00507aec87
Module nvidia_drv.so with build-id c0f43c87bd9d909d127cd02f169aace2269ffe5d
Module libxcb.so.1 with build-id 0d1ef11740a5daad2ee331e812a51aa6574af222
Module libX11.so.6 with build-id 5ba5798d193c0065014b8c6252a0678671c8d478
Module libGLX.so.0 with build-id 2a08836c6e6126ce9ff4496b6aacaf29ae9b4e7b
Module libGLdispatch.so.0 with build-id 501765b3a78d668860fa54229b18107473aeda4c
Module libGL.so.1 with build-id 912ac4f37a9fa2d5abcf7a9088c9983cfe46f12a
Module libglx.so with build-id 6b205eec3a3ff50b171967e2bd104793f92ea0b3
Module libpcre.so.1 with build-id 845483dd0acba86de9f0313102bebbaf3ce52767
Module libbrotlicommon.so.1 with build-id a4ba3f4b4571c8272343b621da812a6e24a202a7
Module libglib-2.0.so.0 with build-id 220436a4e27f39372710df014d2517c0387eefa4
Module libgraphite2.so.3 with build-id 47761dc11e553f519cde97ed9ee985be12ccdae2
Module libresolv.so.2 with build-id c915c72668282861a813f7ea3c0780f37b681dc0
Module libkeyutils.so.1 with build-id ac405ddd17be10ce538da3211415ee50c8f8df79
Module libkrb5support.so.0 with build-id adf65240a4d2aba772d7a0772b4d015469934113
Module libcom_err.so.2 with build-id be99503e12b86d78d6ede2f0d1ffb66408a37576
Module libk5crypto.so.3 with build-id eb8220b8f36675aac769450be4cb6bb7f97ec38a
Module libkrb5.so.3 with build-id 72d26767c5cb1097db75a5f5bff88860233c902b
Module libgpg-error.so.0 with build-id 3801187d42c4955bd93c605451430cdf1b164e63
Module libbrotlidec.so.1 with build-id 45defc036e918e0140a72f1fbce6e7692d38241d
Module libharfbuzz.so.0 with build-id 1d9dee49dd99162c3f83eb3259c3c88c6b4cd7fe
Module libpng16.so.16 with build-id 2dc0bce07f199bf983c07a05fb95a6f4af83a9b3
Module libbz2.so.1.0 with build-id 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
Module libgssapi_krb5.so.2 with build-id e6e098ad51ce7bdd3dbe902d7b0f69a90f8a9e08
Module libgcc_s.so.1 with build-id 7f8508bb914546ada778809b64b99d234337d835
Module libgcrypt.so.20 with build-id db45f5d5e0f7af1e77324fea1885f974619ad268
Module libcap.so.2 with build-id f56c6cd6ad4d35053340d7ff2f8f954498796739
Module liblz4.so.1 with build-id e63600ab23b2f6997f42fac2fa56e1f02ce159a1
Module libzstd.so.1 with build-id 6214183688018e3fba6d66db10c2c8d0b45e0578
Module liblzma.so.5 with build-id 8b615460aa230708c5183f16bede67aa0437d95e
Module librt.so.1 with build-id 75484da2d6f1515189eefa076e0a40328834cd16
Module libfreetype.so.6 with build-id 26c5f833068ff72660d1975cbc2074c3eb47fad8
Module libfontenc.so.1 with build-id 5a11f1fb8c3f2714be9eb6697318f20e301e1d2f
Module libz.so.1 with build-id 0c1459c56513efd5d53eb3868290e9afee6a6a26
Module ld-linux-x86-64.so.2 with build-id 040cc3dd10461562f177df39e3be2f3704258c3c
Module libc.so.6 with build-id 4b406737057708c0e4c642345a703c47a61c73dc
Module libxcvt.so.0 with build-id 30bad674c8227152bb709556a3657d0258554309
Module libpthread.so.0 with build-id 07c8f95b4f3251d08550217ad8a1f31066229996
Module libtirpc.so.3 with build-id 5bef2adfdee3df283f593b3e2d37b6dac405256a
Module libdrm.so.2 with build-id 457a1a1bd25f1d5541a10d3f16c5dc1440d77c7d
Module libudev.so.1 with build-id e7bd18780bd5753c14f8561be78e4e78ae0266ee
Module libdbus-1.so.3 with build-id 74f2ab9c60512f3a93c932c3f627564d42e0b11e
Module libsystemd.so.0 with build-id 69dfd360ef432adc8911dd446411765f1922fb48
Module libxshmfence.so.1 with build-id 8876d9ccf620858795724ca24b9e567585a77cec
Module libXfont2.so.2 with build-id 154202dd7ddb86f6ae4d3bc762dfd8570b86882a
Module libXdmcp.so.6 with build-id 8ca0792d23c8b8b4c0864297512349292bea5955
Module libXau.so.6 with build-id 1c67764663e07bec24d8951e5fd93f4d165979ff
Module libnettle.so.8 with build-id 9a878e513c02007598fcf1e2e286c2203f13536e
Module libpciaccess.so.0 with build-id 9dd24e76ebc38465541313b36446ffb4af842c12
Module libdl.so.2 with build-id 5abc547e7b0949f89f3c0e21ab0c8331a7440a8a
Module libm.so.6 with build-id 2b8fd1f869ecab4e0b55e92f2f151897f6818acf
Module libpixman-1.so.0 with build-id 341f793dcada3a48a306a793d265a517e3f2e7d6
Module Xorg with build-id 54f45e59d2fb69e7a45684977b9a172ae1dd2730
Stack trace of thread 4130:
#0 0x00007fd82badcd22 raise (libc.so.6 + 0x3cd22)
#1 0x00007fd82bac6862 abort (libc.so.6 + 0x26862)
#2 0x00005576e12459b0 OsAbort (Xorg + 0x1539b0)
#3 0x00005576e12474f5 FatalError (Xorg + 0x1554f5)
#4 0x00005576e124ceca n/a (Xorg + 0x15aeca)
#5 0x00007fd82bc8b870 n/a (libpthread.so.0 + 0x13870)
Stack trace of thread 4160:
#0 0x00007fd82bc8a600 __lll_lock_wait (libpthread.so.0 + 0x12600)
#1 0x00007fd82bc83580 __pthread_mutex_lock (libpthread.so.0 + 0xb580)
#2 0x00005576e123ae05 n/a (Xorg + 0x148e05)
#3 0x00005576e12455e1 n/a (Xorg + 0x1535e1)
#4 0x00005576e1241629 n/a (Xorg + 0x14f629)
#5 0x00007fd82bc81259 start_thread (libpthread.so.0 + 0x9259)
#6 0x00007fd82bb9e5e3 __clone (libc.so.6 + 0xfe5e3)
ELF object binary architecture: AMD x86-64
Jan 18 20:33:49 hostname rtkit-daemon[925]: Supervising 6 threads of 3 processes of 1 users.
Jan 18 20:33:49 hostname rtkit-daemon[925]: Successfully made thread 8580 of process 4295 owned by '1000' RT at priority 5.
Jan 18 20:33:49 hostname root[8581]: ACPI group/action undefined: jack/videoout / VIDEOOUT
Jan 18 20:33:49 hostname rtkit-daemon[925]: Supervising 5 threads of 3 processes of 1 users.
Jan 18 20:33:49 hostname root[8578]: ACPI group/action undefined: jack/lineout / LINEOUT
Jan 18 20:33:49 hostname kernel: audit: type=1130 audit(1642534429.723:343): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@5-8575-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=suc>
Jan 18 20:33:49 hostname rtkit-daemon[925]: Successfully made thread 8580 of process 4295 owned by '1000' RT at priori>
Jan 18 20:33:49 hostname kernel: audit: type=1130 audit(1642534429.723:343): pid=1 uid=0 auid=4294967295 ses=429496729>
Jan 18 20:33:49 hostname kernel: audit: type=1334 audit(1642534429.723:342): prog-id=52 op=LOAD
Jan 18 20:33:49 hostname kernel: audit: type=1334 audit(1642534429.723:341): prog-id=51 op=LOAD
Jan 18 20:33:49 hostname kernel: audit: type=1334 audit(1642534429.723:340): prog-id=50 op=LOAD
Jan 18 20:33:49 hostname systemd[1]: Started Process Core Dump (PID 8575/UID 0).
Jan 18 20:33:49 hostname audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump>
Jan 18 20:33:49 hostname audit: BPF prog-id=52 op=LOAD
Jan 18 20:33:49 hostname audit: BPF prog-id=51 op=LOAD
Jan 18 20:33:49 hostname audit: BPF prog-id=50 op=LOAD
Jan 18 20:33:49 hostname acpid[600]: client 4130[0:0] has disconnected
Jan 18 20:33:49 hostname kernel: audit: type=1701 audit(1642534429.713:339): auid=4294967295 uid=0 gid=0 ses=429496729>
Jan 18 20:33:49 hostname audit[4130]: ANOM_ABEND auid=4294967295 uid=0 gid=0 ses=4294967295 pid=4130 comm="Xorg" exe=">
Jan 18 20:33:49 hostname root[8573]: ACPI group/action undefined: jack/videoout / VIDEOOUT
Jan 18 20:33:49 hostname root[8571]: ACPI group/action undefined: jack/lineout / LINEOUT
Jan 18 20:33:49 hostname rtkit-daemon[925]: Successfully made thread 8554 of process 8502 owned by '1000' high priorit>
Jan 18 20:33:49 hostname rtkit-daemon[925]: Successfully made thread 8552 of process 8502 owned by '1000' high priorit>
Jan 18 20:33:49 hostname rtkit-daemon[925]: Supervising 4 threads of 2 processes of 1 users.
