hello everyone:
I want to boot from SD, and referring to this URL(Unable to boot from SD card when using Jetpack 4.3)
I format SD card to ext4,echo the uuid to bootloader/l4t-rootfs-uuid.txt and copy the sample rootfs to sd card.
when I run:sudo ./flash.sh jetson-xavier external
the log stop at “[ 13.0118 ] tegrarcm_v2 --isapplet”
virtual box’s problems?
my env:
virtual box 6.0.20 + ubuntu18.04 + Tegra186_Linux_R32.3.1_aarch64
ps: internal emmc have a system and I don’t want to flash it.
full log:
ouqc@ouqc-VirtualBox:~/lab/Xavier/L4T/flash/Linux_for_Tegra$ sudo ./flash.sh jetson-xavier external
# L4T BSP Information:
# R32 , REVISION: 4.2
# Target Board Information:
# Name: jetson-xavier, Board Family: t186ref, SoC: Tegra 194,
# OpMode: production, Boot Authentication: NS,
copying soft_fuses(/home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg)... done.
./tegraflash.py --chip 0x19 --applet "/home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/mb1_t194_prod.bin" --skipuid --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --bins "mb2_applet nvtboot_applet_t194.bin" --cmd "dump eeprom boardinfo cvm.bin;reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0086 ] Generating RCM messages
[ 0.0118 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader /home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/mb1_t194_prod.bin zerosbk
[ 0.0159 ] Header already present for /home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/mb1_t194_prod.bin
[ 0.0220 ]
[ 0.0261 ] tegrasign_v2 --key None --getmode mode.txt
[ 0.0288 ] Assuming zero filled SBK key
[ 0.0441 ]
[ 0.0469 ] tegrasign_v2 --key None --file /home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin --offset 2960 --length 1136 --pubkeyhash pub_key.key
[ 0.0502 ] Assuming zero filled SBK key
[ 0.0534 ]
[ 0.0641 ] tegrahost_v2 --chip 0x19 0 --updatesigheader /home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin /home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.hash zerosbk
[ 0.0821 ]
[ 0.0869 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg.pdf sfuse.bin
[ 0.0934 ]
[ 0.0970 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm /home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin 0 0
[ 0.1032 ] RCM 0 is saved as rcm_0.rcm
[ 0.1110 ] RCM 1 is saved as rcm_1.rcm
[ 0.1141 ] RCM 2 is saved as rcm_2.rcm
[ 0.1160 ] List of rcm files are saved in rcm_list.xml
[ 0.1255 ]
[ 0.1257 ] Signing RCM messages
[ 0.1322 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[ 0.1401 ] Assuming zero filled SBK key
[ 0.1401 ]
[ 0.1402 ] Copying signature to RCM mesages
[ 0.1461 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[ 0.1500 ]
[ 0.1501 ] Boot Rom communication
[ 0.1546 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml --skipuid
[ 0.1577 ] RCM version 0X190001
[ 0.1647 ] Boot Rom communication completed
[ 1.1969 ]
[ 2.2038 ] tegrarcm_v2 --isapplet
[ 2.2055 ] Applet version 01.00.0000
[ 2.2309 ]
[ 2.2329 ] tegrarcm_v2 --ismb2
[ 2.2697 ]
[ 2.2719 ] tegrahost_v2 --chip 0x19 --align nvtboot_applet_t194.bin
[ 2.2737 ]
[ 2.2757 ] tegrahost_v2 --chip 0x19 0 --magicid PLDT --appendsigheader nvtboot_applet_t194.bin zerosbk
[ 2.2798 ] adding BCH for nvtboot_applet_t194.bin
[ 2.2864 ]
[ 2.2905 ] tegrasign_v2 --key None --list nvtboot_applet_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 2.2937 ] Assuming zero filled SBK key
[ 2.3030 ]
[ 2.3165 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_applet_t194_sigheader.bin.encrypt nvtboot_applet_t194_sigheader.bin.hash zerosbk
[ 2.3206 ]
[ 2.3255 ] tegrarcm_v2 --download mb2 nvtboot_applet_t194_sigheader.bin.encrypt
[ 2.3275 ] Applet version 01.00.0000
[ 2.3544 ] Sending mb2
[ 2.3549 ] [................................................] 100%
[ 2.3751 ]
[ 2.3785 ] tegrarcm_v2 --boot recovery
[ 2.3831 ] Applet version 01.00.0000
[ 2.4209 ]
[ 3.4250 ] tegrarcm_v2 --isapplet
[ 3.4635 ]
[ 3.4655 ] tegrarcm_v2 --ismb2
[ 3.4676 ] MB2 Applet version 01.00.0000
[ 3.5036 ]
[ 3.5056 ] tegrarcm_v2 --ismb2
[ 3.5088 ] MB2 Applet version 01.00.0000
[ 3.5436 ]
[ 3.5470 ] Retrieving EEPROM data
[ 3.5472 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/cvm.bin
[ 3.5494 ] MB2 Applet version 01.00.0000
[ 3.5906 ] Saved platform info in /home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/cvm.bin
[ 3.6331 ]
[ 3.6332 ] Rebooting to recovery mode
[ 3.6358 ] tegrarcm_v2 --ismb2
[ 3.6397 ] MB2 Applet version 01.00.0000
[ 3.6719 ]
[ 3.6720 ] Rebooting to recovery mode
[ 3.6748 ] tegrarcm_v2 --reboot recovery
[ 3.6809 ] MB2 Applet version 01.00.0000
[ 3.7267 ]
Board ID(2888) version(400) sku(0001) revision(J.0)
Using UUID 27327c3a-3c1d-4d39-ac25-0e699a7e479b for mounting root partition.
copying bctfile(/home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-memcfg-p2888.cfg)... done.
copying bctfile1(/home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-memcfg-sw-override.cfg)... done.
copying uphy_config(/home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg)... done.
copying device_config(/home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-bct-device-sdmmc.cfg)... done.
copying misc_cold_boot_config(/home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-l4t.cfg)... done.
copying misc_config(/home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-flash.cfg)... done.
copying pinmux_config(/home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg)... done.
copying gpioint_config(/home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg)... done.
copying pmic_config(/home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg)... done.
copying pmc_config(/home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg)... done.
copying prod_config(/home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg)... done.
copying scr_config(/home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini.cfg)... done.
copying scr_cold_boot_config(/home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini.cfg)... done.
copying bootrom_config(/home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg)... done.
copying dev_params(/home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-br-bct-sdmmc.cfg)... done.
Existing bootloader(/home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
copying initrd(/home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
populating kernel to rootfs... done.
version 1.0.0
[ 0.0092 ] Generating signature
[ 0.0122 ] tegrasign_v2 --key --getmode mode.txt
[ 0.0150 ] Assuming zero filled SBK key
[ 0.0299 ]
[ 0.0301 ] header_magic: c05514
[ 0.0323 ] tegrahost_v2 --chip 0x19 --align 1_Image
[ 0.0395 ]
[ 0.0414 ] tegrahost_v2 --chip 0x19 0 --magicid DATA --appendsigheader 1_Image zerosbk
[ 0.0476 ] adding BCH for 1_Image
[ 1.1450 ]
[ 1.1473 ] tegrasign_v2 --key --list 1_Image_sigheader_list.xml --pubkeyhash pub_key.key
[ 1.1492 ] Assuming zero filled SBK key
[ 1.2551 ]
[ 1.2600 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_Image_sigheader.encrypt 1_Image_sigheader.hash zerosbk
[ 1.9405 ]
[ 1.9897 ] Signed file: /home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/Image_sigheader.encrypt
Generate header for Image_sigheader.encrypt
Generate 16-byte-size-aligned base file for Image_sigheader.encrypt
Remove temporary file
done.
populating initrd to rootfs... done.
populating /home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb to rootfs... done.
Making Boot image... done.
Existing sosfile(/home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing tegraboot(/home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/nvtboot_t194.bin) reused.
Existing cpu_bootloader(/home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
Existing mb2blfile(/home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/nvtboot_recovery_t194.bin) reused.
Existing mtspreboot(/home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/preboot_c10_prod_cr.bin) reused.
Existing mcepreboot(/home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/mce_c10_prod_cr.bin) reused.
Existing mtsproper(/home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/mts_c10_prod_cr.bin) reused.
Existing mb1file(/home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing bpffile(/home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/bpmp_t194.bin) reused.
copying bpfdtbfile(/home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/t186ref/tegra194-a02-bpmp-p2888-a04.dtb)... done.
Existing scefile(/home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing camerafw(/home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/camera-rtcpu-rce.img) reused.
Existing spefile(/home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/spe_t194.bin) reused.
Existing drameccfile(/home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/dram-ecc.bin) reused.
Existing badpagefile(/home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/badpage.bin) reused.
Existing wb0boot(/home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/warmboot_t194_prod.bin) reused.
Existing tosfile(/home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/tos-trusty_t194.img) reused.
Existing eksfile(/home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb)... done.
Copying nv_boot_control.conf to rootfs
version 1.0.0
[ 0.0087 ] Generating signature
[ 0.0103 ] tegrasign_v2 --key --getmode mode.txt
[ 0.0121 ] Assuming zero filled SBK key
[ 0.0130 ]
[ 0.0132 ] header_magic: d00dfeed
[ 0.0156 ] tegrahost_v2 --chip 0x19 --align 1_tegra194-p2888-0001-p2822-0000.dtb
[ 0.0185 ]
[ 0.0203 ] tegrahost_v2 --chip 0x19 0 --magicid DATA --appendsigheader 1_tegra194-p2888-0001-p2822-0000.dtb zerosbk
[ 0.0218 ] adding BCH for 1_tegra194-p2888-0001-p2822-0000.dtb
[ 0.0394 ]
[ 0.0418 ] tegrasign_v2 --key --list 1_tegra194-p2888-0001-p2822-0000_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 0.0443 ] Assuming zero filled SBK key
[ 0.0554 ]
[ 0.0600 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt 1_tegra194-p2888-0001-p2822-0000_sigheader.dtb.hash zerosbk
[ 0.0715 ]
[ 0.0725 ] Signed file: /home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
Generate header for tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
Generate 16-byte-size-aligned base file for tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
done.
generating system.img for booting...
Making system.img...
populating rootfs from /tmp/tmp.WitCmFU94S ... done.
Sync'ing system.img ... done.
Converting RAW image to Sparse image... done.
system.img built successfully.
Existing tbcfile(/home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/cboot_t194.bin) reused.
copying tbcdtbfile(/home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb)... done.
copying cfgfile(/home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/t186ref/cfg/flash_t194_sdmmc.xml) to flash.xml... done.
Existing flasher(/home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu_t194.bin) reused.
Existing flashapp(/home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/tegraflash.py) reused.
./tegraflash.py --bl nvtboot_recovery_cpu_t194.bin --sdram_config tegra194-mb1-bct-memcfg-p2888.cfg,tegra194-memcfg-sw-override.cfg --odmdata 0x9190000 --applet mb1_t194_prod.bin --cmd "flash; reboot" --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --cfg flash.xml --chip 0x19 --uphy_config tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device_config tegra19x-mb1-bct-device-sdmmc.cfg --misc_cold_boot_config tegra194-mb1-bct-misc-l4t.cfg --misc_config tegra194-mb1-bct-misc-flash.cfg --pinmux_config tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --gpioint_config tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --pmic_config tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --pmc_config tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --prod_config tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --scr_config tegra194-mb1-bct-scr-cbb-mini.cfg --scr_cold_boot_config tegra194-mb1-bct-scr-cbb-mini.cfg --br_cmd_config tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --dev_params tegra194-br-bct-sdmmc.cfg --bin "mb2_bootloader nvtboot_recovery_t194.bin; mts_preboot preboot_c10_prod_cr.bin; mts_mce mce_c10_prod_cr.bin; mts_proper mts_c10_prod_cr.bin; bpmp_fw bpmp_t194.bin; bpmp_fw_dtb tegra194-a02-bpmp-p2888-a04.dtb; spe_fw spe_t194.bin; tlk tos-trusty_t194.img; eks eks.img; bootloader_dtb tegra194-p2888-0001-p2822-0000.dtb"
saving flash command in /home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/flash_win.bat
*** Flashing target device started. ***
version 1.0.0
[ 0.0033 ] tegrasign_v2 --key None --getmode mode.txt
[ 0.0057 ] Assuming zero filled SBK key
[ 0.0090 ]
[ 0.0092 ] Generating RCM messages
[ 0.0153 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader mb1_t194_prod.bin zerosbk
[ 0.0201 ] Header already present for mb1_t194_prod.bin
[ 0.0429 ]
[ 0.0458 ] tegrasign_v2 --key None --getmode mode.txt
[ 0.0478 ] Assuming zero filled SBK key
[ 0.0483 ]
[ 0.0550 ] tegrasign_v2 --key None --file mb1_t194_prod_sigheader.bin --offset 2960 --length 1136 --pubkeyhash pub_key.key
[ 0.0574 ] Assuming zero filled SBK key
[ 0.0587 ]
[ 0.0640 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin mb1_t194_prod_sigheader.hash zerosbk
[ 0.0717 ]
[ 0.0752 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg sfuse.bin
[ 0.0888 ]
[ 0.0926 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm mb1_t194_prod_sigheader.bin 0 0
[ 0.0950 ] RCM 0 is saved as rcm_0.rcm
[ 0.1021 ] RCM 1 is saved as rcm_1.rcm
[ 0.1028 ] RCM 2 is saved as rcm_2.rcm
[ 0.1037 ] List of rcm files are saved in rcm_list.xml
[ 0.1148 ]
[ 0.1149 ] Signing RCM messages
[ 0.1171 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[ 0.1199 ] Assuming zero filled SBK key
[ 0.1348 ]
[ 0.1349 ] Copying signature to RCM mesages
[ 0.1371 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[ 0.1510 ]
[ 0.1511 ] Parsing partition layout
[ 0.1560 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.1645 ]
[ 0.1646 ] Creating list of images to be signed
[ 0.1723 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
[ 0.1742 ] MB1: Nvheader already present is mb1_t194_prod.bin
[ 0.1756 ] Header already present for mb1_t194_prod_sigheader.bin
[ 0.1779 ] MB1: Nvheader already present is mb1_t194_prod.bin
[ 0.1829 ] Header already present for mb1_t194_prod_sigheader.bin
[ 0.1926 ] adding BCH for spe_t194.bin
[ 0.2057 ] adding BCH for spe_t194.bin
[ 0.2096 ] adding BCH for nvtboot_t194.bin
[ 0.2192 ] adding BCH for nvtboot_t194.bin
[ 0.2300 ] Header already present for preboot_c10_prod_cr.bin
[ 0.2391 ] Header already present for preboot_c10_prod_cr.bin
[ 0.2402 ] Header already present for mce_c10_prod_cr.bin
[ 0.2441 ] Header already present for mce_c10_prod_cr.bin
[ 0.2454 ] adding BCH for mts_c10_prod_cr.bin
[ 0.2650 ] adding BCH for mts_c10_prod_cr.bin
[ 0.4020 ] adding BCH for cboot_t194.bin
[ 0.5202 ] adding BCH for cboot_t194.bin
[ 0.5335 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[ 0.5504 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[ 0.5573 ] adding BCH for tos-trusty_t194.img
[ 0.5742 ] adding BCH for tos-trusty_t194.img
[ 0.5842 ] adding BCH for eks.img
[ 0.6035 ] adding BCH for eks.img
[ 0.6037 ] adding BCH for bpmp_t194.bin
[ 0.6068 ] adding BCH for bpmp_t194.bin
[ 0.6478 ] adding BCH for tegra194-a02-bpmp-p2888-a04.dtb
[ 0.6858 ] adding BCH for tegra194-a02-bpmp-p2888-a04.dtb
[ 0.7167 ] adding BCH for camera-rtcpu-rce.img
[ 0.7472 ] adding BCH for camera-rtcpu-rce.img
[ 0.7625 ] adding BCH for adsp-fw.bin
[ 0.7786 ] adding BCH for adsp-fw.bin
[ 0.7817 ] Header already present for warmboot_t194_prod.bin
[ 0.7896 ] Header already present for warmboot_t194_prod.bin
[ 0.7908 ] adding BCH for boot.img
[ 0.8388 ] adding BCH for boot.img
[ 2.1506 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[ 3.4475 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[ 3.4639 ]
[ 3.4640 ] Filling MB1 storage info
[ 3.4640 ] Generating br-bct
[ 3.4658 ] Performing cfg overlay
[ 3.4658 ] ['tegra194-mb1-bct-memcfg-p2888.cfg', 'tegra194-memcfg-sw-override.cfg']
[ 3.4669 ] sw_memcfg_overlay.pl -c tegra194-mb1-bct-memcfg-p2888.cfg -s tegra194-memcfg-sw-override.cfg -o /home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/4224/tmp7pmGSh1.cfg
[ 3.6070 ]
[ 3.6072 ] Updating dev and MSS params in BR BCT
[ 3.6074 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/4224/tmp7pmGSh1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 3.7082 ]
[ 3.7083 ] Updating bl info
[ 3.7100 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[ 3.7137 ]
[ 3.7137 ] Generating signatures
[ 3.7158 ] tegrasign_v2 --key None --list images_list.xml --pubkeyhash pub_key.key
[ 3.7178 ] Assuming zero filled SBK key
[ 4.0068 ]
[ 4.0069 ] Generating br-bct
[ 4.0095 ] Performing cfg overlay
[ 4.0097 ] ['/home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/4224/tmp7pmGSh1.cfg']
[ 4.0098 ] Updating dev and MSS params in BR BCT
[ 4.0100 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/4224/tmp7pmGSh1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 4.1339 ]
[ 4.1340 ] Updating bl info
[ 4.1364 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 4.1441 ]
[ 4.1442 ] Updating smd info
[ 4.1480 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 --updatesmdinfo flash.xml.bin
[ 4.1658 ]
[ 4.1660 ] Updating Odmdata
[ 4.1738 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatefields Odmdata =0x9190000
[ 4.1904 ]
[ 4.1907 ] Get Signed section of bct
[ 4.1952 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listbct bct_list.xml
[ 4.2068 ]
[ 4.2115 ] tegrasign_v2 --key None --list bct_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[ 4.2197 ] Assuming zero filled SBK key
[ 4.2359 ]
[ 4.2362 ] Updating BCT with signature
[ 4.2412 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatesig bct_list_signed.xml
[ 4.2646 ]
[ 4.2673 ] Generating coldboot mb1-bct
[ 4.2730 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_cold_boot_bct.cfg --sdram /home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/4224/tmp7pmGSh1.cfg --misc tegra194-mb1-bct-misc-l4t.cfg --scr tegra194-mb1-bct-scr-cbb-mini.cfg --pinmux tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --pmc tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --brcommand tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --gpioint tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --uphy tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device tegra19x-mb1-bct-device-sdmmc.cfg
[ 4.2773 ] MB1-BCT version: 0x1
[ 4.2800 ] Parsing config file :tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
[ 4.2968 ] Added Platform Config 0 data with size :- 3008
[ 4.3018 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini.cfg
[ 4.3109 ] Added Platform Config 1 data with size :- 19640
[ 4.3450 ] Parsing config file :tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg
[ 4.3463 ] Added Platform Config 2 data with size :- 24
[ 4.3515 ] Parsing config file :tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg
[ 4.3537 ] Added Platform Config 4 data with size :- 348
[ 4.3599 ] Parsing config file :tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg
[ 4.3613 ] Added Platform Config 3 data with size :- 92
[ 4.3634 ] Parsing config file :tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg
[ 4.3678 ] Added Platform Config 5 data with size :- 56
[ 4.3690 ] Parsing config file :tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg
[ 4.3699 ] Added Platform Config 7 data with size :- 392
[ 4.3699 ]
[ 4.3699 ] Parsing config file :tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg
[ 4.3700 ] Added Platform Config 8 data with size :- 12
[ 4.3700 ]
[ 4.3700 ] Parsing config file :tegra19x-mb1-bct-device-sdmmc.cfg
[ 4.3700 ] Added Platform Config 9 data with size :- 32
[ 4.3700 ]
[ 4.3701 ] Updating mb1-bct with firmware information
[ 4.3749 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 4.3794 ] MB1-BCT version: 0x1
[ 4.3795 ]
[ 4.3795 ] Updating mb1-bct with storage information
[ 4.3900 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 4.3930 ] MB1-BCT version: 0x1
[ 4.4036 ]
[ 4.4079 ] tegrahost_v2 --chip 0x19 --align mb1_cold_boot_bct_MB1.bct
[ 4.4213 ]
[ 4.4241 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1.bct zerosbk
[ 4.4268 ] adding BCH for mb1_cold_boot_bct_MB1.bct
[ 4.4389 ]
[ 4.4430 ] tegrasign_v2 --key None --list mb1_cold_boot_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 4.4469 ] Assuming zero filled SBK key
[ 4.4554 ]
[ 4.4618 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_cold_boot_bct_MB1_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_sigheader.bct.hash zerosbk
[ 4.4742 ]
[ 4.4750 ] Generating recovery mb1-bct
[ 4.4784 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_bct.cfg --sdram /home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/4224/tmp7pmGSh1.cfg --misc tegra194-mb1-bct-misc-flash.cfg --scr tegra194-mb1-bct-scr-cbb-mini.cfg --pinmux tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --pmc tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --brcommand tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --gpioint tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --uphy tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device tegra19x-mb1-bct-device-sdmmc.cfg
[ 4.4814 ] MB1-BCT version: 0x1
[ 4.4830 ] Parsing config file :tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
[ 4.4851 ] Added Platform Config 0 data with size :- 3008
[ 4.4903 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini.cfg
[ 4.4916 ] Added Platform Config 1 data with size :- 19640
[ 4.5225 ] Parsing config file :tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg
[ 4.5242 ] Added Platform Config 2 data with size :- 24
[ 4.5255 ] Parsing config file :tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg
[ 4.5271 ] Added Platform Config 4 data with size :- 348
[ 4.5319 ] Parsing config file :tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg
[ 4.5335 ] Added Platform Config 3 data with size :- 92
[ 4.5346 ] Parsing config file :tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg
[ 4.5359 ] Added Platform Config 5 data with size :- 56
[ 4.5371 ] Parsing config file :tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg
[ 4.5384 ] Added Platform Config 7 data with size :- 392
[ 4.5385 ]
[ 4.5386 ] Parsing config file :tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg
[ 4.5386 ] Added Platform Config 8 data with size :- 12
[ 4.5386 ]
[ 4.5386 ] Parsing config file :tegra19x-mb1-bct-device-sdmmc.cfg
[ 4.5386 ] Added Platform Config 9 data with size :- 32
[ 4.5386 ]
[ 4.5387 ] Updating mb1-bct with firmware information
[ 4.5409 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 4.5436 ] MB1-BCT version: 0x1
[ 4.5498 ]
[ 4.5499 ] Updating mb1-bct with storage information
[ 4.5532 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 4.5561 ] MB1-BCT version: 0x1
[ 4.5749 ]
[ 4.5768 ] tegrahost_v2 --chip 0x19 --align mb1_bct_MB1.bct
[ 4.5786 ]
[ 4.5809 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --appendsigheader mb1_bct_MB1.bct zerosbk
[ 4.5834 ] adding BCH for mb1_bct_MB1.bct
[ 4.5846 ]
[ 4.5906 ] tegrasign_v2 --key None --list mb1_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 4.5931 ] Assuming zero filled SBK key
[ 4.5936 ]
[ 4.6007 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
[ 4.6155 ]
[ 4.6157 ] Generating coldboot mem-bct
[ 4.6183 ] tegrabct_v2 --chip 0x19 0 --sdram /home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/4224/tmp7pmGSh1.cfg --membct /home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/4224/tmp7pmGSh1_1.bct /home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/4224/tmp7pmGSh1_2.bct /home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/4224/tmp7pmGSh1_3.bct /home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/4224/tmp7pmGSh1_4.bct
[ 4.6226 ] Packing sdram param for instance[0]
[ 4.7481 ] Packing sdram param for instance[1]
[ 4.7490 ] Packing sdram param for instance[2]
[ 4.7501 ] Packing sdram param for instance[3]
[ 4.7516 ] Packing sdram param for instance[4]
[ 4.7530 ] Packing sdram param for instance[5]
[ 4.7538 ] Packing sdram param for instance[6]
[ 4.7543 ] Packing sdram param for instance[7]
[ 4.7543 ] Packing sdram param for instance[8]
[ 4.7545 ] Packing sdram param for instance[9]
[ 4.7545 ] Packing sdram param for instance[10]
[ 4.7545 ] Packing sdram param for instance[11]
[ 4.7546 ] Packing sdram param for instance[12]
[ 4.7546 ] Packing sdram param for instance[13]
[ 4.7546 ] Packing sdram param for instance[14]
[ 4.7546 ] Packing sdram param for instance[15]
[ 4.7547 ]
[ 4.7547 ] Getting sector size from pt
[ 4.7571 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[ 4.7746 ]
[ 4.7748 ] BlockSize read from layout is 200
[ 4.7772 ] tegrahost_v2 --chip 0x19 0 --blocksize 512 --magicid MEMB --addsigheader_multi /home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/4224/tmp7pmGSh1_1.bct /home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/4224/tmp7pmGSh1_2.bct /home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/4224/tmp7pmGSh1_3.bct /home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/4224/tmp7pmGSh1_4.bct
[ 4.7800 ] adding BCH for /home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/4224/tmp7pmGSh1_1.bct
[ 4.7986 ]
[ 4.8011 ] tegrahost_v2 --chip 0x19 --align mem_coldboot.bct
[ 4.8111 ]
[ 4.8130 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --appendsigheader mem_coldboot.bct zerosbk
[ 4.8155 ] Header already present for mem_coldboot.bct
[ 4.8307 ]
[ 4.8350 ] tegrasign_v2 --key None --list mem_coldboot_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 4.8373 ] Assuming zero filled SBK key
[ 4.8466 ]
[ 4.8493 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_coldboot_sigheader.bct.encrypt mem_coldboot_sigheader.bct.hash zerosbk
[ 4.8621 ]
[ 4.8626 ] Generating recovery mem-bct
[ 4.8650 ] tegrabct_v2 --chip 0x19 0 --sdram /home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/4224/tmp7pmGSh1.cfg --membct /home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/4224/tmp7pmGSh1_1.bct /home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/4224/tmp7pmGSh1_2.bct /home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/4224/tmp7pmGSh1_3.bct /home/ouqc/lab/Xavier/L4T/flash/Linux_for_Tegra/bootloader/4224/tmp7pmGSh1_4.bct
[ 4.8676 ] Packing sdram param for instance[0]
[ 4.9780 ] Packing sdram param for instance[1]
[ 4.9787 ] Packing sdram param for instance[2]
[ 4.9796 ] Packing sdram param for instance[3]
[ 4.9803 ] Packing sdram param for instance[4]
[ 4.9812 ] Packing sdram param for instance[5]
[ 4.9819 ] Packing sdram param for instance[6]
[ 4.9829 ] Packing sdram param for instance[7]
[ 4.9839 ] Packing sdram param for instance[8]
[ 4.9861 ] Packing sdram param for instance[9]
[ 4.9861 ] Packing sdram param for instance[10]
[ 4.9861 ] Packing sdram param for instance[11]
[ 4.9862 ] Packing sdram param for instance[12]
[ 4.9862 ] Packing sdram param for instance[13]
[ 4.9862 ] Packing sdram param for instance[14]
[ 4.9862 ] Packing sdram param for instance[15]
[ 4.9863 ]
[ 4.9895 ] tegrahost_v2 --chip 0x19 --align mem_rcm.bct
[ 4.9943 ]
[ 4.9970 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --appendsigheader mem_rcm.bct zerosbk
[ 4.9991 ] adding BCH for mem_rcm.bct
[ 5.0106 ]
[ 5.0132 ] tegrasign_v2 --key None --list mem_rcm_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 5.0189 ] Assuming zero filled SBK key
[ 5.0189 ]
[ 5.0231 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_rcm_sigheader.bct.encrypt mem_rcm_sigheader.bct.hash zerosbk
[ 5.0266 ]
[ 5.0306 ] Copying signatures
[ 5.0328 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 6.9691 ]
[ 6.9692 ] Boot Rom communication
[ 6.9712 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml
[ 6.9729 ] BootRom is not running
[ 12.0036 ]
