Xavier NX backup and recovery occur error
sudo ./tools/backup_restore/l4t_backup_restore.sh -e nvme0n1 -r jetson-xavier-nx-devkit-emmc
log is as follows:
新建文本文档 (2).txt (62.7 KB)
function set_board_spec {
BOARD_SPEC=$(awk ‘{print $1}’ /etc/board_spec.txt)
where is the file “/etc/board_spec.txt”
Hi zhj18115188906,
Are you using the devkit or custom board for Xavier NX?
What’s the Jetpack version in use?(R35.4.1?!)
nvrestore_partitions.sh: You are trying to flash images from a board model that does not
match the current board you're flashing onto.
Could you share the result of the following command on your board?
$ cat /etc/nv_boot_control.conf
