Unable to restore a jetson using a backup image in the new module
162_10.22.115.87_22_11_26_27.log (76.9 KB)
I am trying to restore a jetson using a backup image in the new module.
I use the following commad to back up the system.
sudo ./tools/backup_restore/l4t_backup_restore.sh -b jetson-xavier-nx-devkit-emmc
sudo ./tools/backup_restore/l4t_backup_restore.sh -r jetson-xavier-nx-devkit-emmc
but when the module was flashed , it is not working.can you suggest me on this? I am using stock BSP 35.1.0.
attach log.
which jetpack version you flashed and which module tested.
have you ever tested on NV devkit to reproduce this issue?
Jeffli,
the jetpack version is 5.0.2.And yes, I reproduced it on NV devkit
Hi 2419918682,
still check restore with -r to flash Xavier NX internally.
Could you try mass flash command like belows(mass flash num set 5 here, you can set 1/2/3… as needed):
1)create mfi
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --no-flash --external-device nvme0n1p1 -p “-c bootloader/t186ref/cfg/flash_t234_qspi.xml --no-systemimg” -c ./tools/kernel_flash/flash_l4t_external.xml --massflash 5 --showlogs --network usb0 jetson-xavier-nx-devkit nvme0n1p1
2)mash flash
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only --network usb0 --massflash 5 --showlogs
Hi Jeffli,
Using this method we can not achieve flashing.
hi 2419918682,
1)if you reply, please tell us failure details, which step you failed, mfi or flash, and log should provide
2)do you verify it on Xavier nx devkit with devkit module?
->1)if you reply, please tell us failure details, which step you failed, mfi or flash, and log should provide
In the flash step. attach log.
->2)do you verify it on Xavier nx devkit with devkit module?
Yes, I did
162_10.22.115.87_22_16_34_26.log (161.1 KB)
Hi 2419918682,
Could you help to update to latest JP5.1.1(R35.3.1) and try the l4t_backup_restore.sh again?
If the issue still exists, please provide the host side log of both backup and restore.
Hi 2419918682,
please update your flash status.
1)which ubuntu version on host? hope 20.04 at least
2)Could you try 35.3.1 just KevinFFF suggest?
