is it possible to create a backup image of the NX module flashed om the emmc? I’m trying to use the L4T Jetpack flash script:
sudo ./flash.sh -r -k APP -G backup-floyd.img mmcblk0p1
but it errors out when dealing with the BCT. Is this because of the custom drivers with the BSP module?
hello venkatraman.bhat,
it looks correct command-line to back-up the system.img.
could you please share the report messages and the errors for referecen,
thanks
You are missing the device type. For example:
sudo ./flash.sh -r -k APP -G my_backup.img jetson-tx2 mmcblk0p1
…note this example names a “jetson-tx2” (you’d alter that for your Jetson type)
Thanks, I got that. Changing target platform to jetson-xavier-nx-devkit-emmc worked.
system
Closed
August 29, 2021, 3:44am
7
