1: software version: JetPack4.5.1 + custom board
description:
- when set nvpmodel m1 at MAXQ model;
- with htop, we can see six cpus are running,
- but with jtop or tegrastats, there are four cpus are running, another status are off.
so, how many cpus are running now? how many status nvpmodel have ? Does have some detail documents abouut nvpmodel for TX2 NX ?
Please check the l4t developer guide with power management section.
I like your avatar! Say hi for me.
If you run this command:
cat /proc/cpuinfo
…then do you see “isolcpus=1-2
”? The Denver cores would not normally be scheduled if this is running, except when you use taskset
to place an application on those cores. See:
https://forums.developer.nvidia.com/t/cpu-at-0-performance/177769/3
First, On behalf of my hairy baby thanks for your love.
Then, thank you for your reply, which has solved my problem .
1: CPU 1 -2 is isolcpus, so there are two cpu are free when i do CPU stress test .
2: CPU 1-2 can be scheduled by following command;
- sudo taskset -c 1 ./test_TestCpuInterface
- sudo taskset -c 2 ./test_TestCpuInterface
If this is a TX2 NX issue. Please file it on TX2 forum next time. TX2 NX and NX are using different SoC.
Could you please send me a link about tx2 nx forum ? I can’t find it in all forum websiet.
There is no TX2 NX forum. Only TX2 forum. Please send TX2 NX topic to TX2 fourm.
I get it, thank you very much.
