When I run htop on the machine I only see CPU utilization for 4 cores. Additionally when I run the linux command
cat /proc/cpuinfo | awk '/^processor/{print $3}' | wc -l
, it returns 4 as well. Xavier’s specs state that it has 8 CPU cores.
What can be causing this discrepancy?
There are different modes for different performance/energy configurations.
These are managed by nvpmodel. You can look at current mode with:
sudo nvpmodel -q
and switch to maxn mode enabling all cores with:
sudo nvpmodel -m 0
You may have a look to /etc/nvpmodel.conf for details about default modes.
Here is also a table that lists the different nvpmodel power presets that are included with L4T for Xavier:
[url]https://docs.nvidia.com/jetson/l4t/Tegra%20Linux%20Driver%20Package%20Development%20Guide/power_management_jetson_xavier.html#wwpID0E0ML0HA[/url]
Here you can see the different clock frequencies and cores that are active for each particular preset.
You can also tweak and tailor your own presets by editing the /etc/nvpmodel.conf configuration file that HP mentioned.
