I’m using dht22 sensor which can measure temperature and humidity on my JetsonNX board.
But the problem is GPIO pin connection issue and I can’t find libraries about JetsonNx .
I wonder how to connect sensor with Xavier NX using GPIO pins.
Or Do I need use any converter??
There are two ways I tried to.
First, Even I tried to use NVidia-Jetson_DHT22-Python github, but there is no information with JetsonNX
So I added JetsonNX GPIO on /NVidia-Jetson-DHT22-Python/jetsonGPIO/jetsonGPIO.h but I got result “-399093.0, -39909.0,0” I connected to 13pin which means SPI1_SCK.
Second, I used adafruit_DHT library.
In the terminal I commanded
import adafruit_dht
import board
dht_device = adafruit_dht.DHT22(board.D27, use_pulseio=False)
temperature = dht_device.temperature
humidity = dht_device.humidity
print(temperature)
print(humidity)
Then I get
“/usr/local/lib/python3.6/dist-packages/Jetson.GPIO-2.0.17-py3.6.egg/Jetson/GPIO/gpio.py:370: UserWarning: Jetson.GPIO ignores setup()'s pull_up_down parameter
File “dhtcode2.py”, line 6, in
File “/home/humani/.local/lib/python3.6/site-packages/adafruit_dht.py”, line 259, in temperature
self.measure()
File “/home/humani/.local/lib/python3.6/site-packages/adafruit_dht.py”, line 211, in measure
raise RuntimeError(“DHT sensor not found, check wiring”)
RuntimeError: DHT sensor not found, check wiring
Exiting…
Cleaning up pins”
I think board.D27 = pin 13.
In these case What should I do??
