I have a Jetson Xavier NX 8GB eMMC production module that previously worked
normally, and now fails DRAM initialization at the exact same point through
every possible path. Before going to RMA I would like to confirm whether any
recovery path exists, and what ALIASCHECKER reason 0x1c / aux_info 0x06
specifically indicates.
Module
- P3668-0001 (699-13668-0001-301), Rev G.0, 8GB, eMMC
- EEPROM reads consistently: Board ID 3668, FAB 301, SKU 0001, Rev G.0
- Chip: T194, SKU 0xde, minor rev 2, BootROM rev 0xf, RAMCODE 1
- ECID: 0x88021911644571431400000006018180
Carrier / host
- Carrier for flashing: Waveshare JETSON-IO-BASE-A (P3509-compatible),
powered by its specified 5V/4A barrel adapter - Host: Ubuntu 18.04, AMD, native (no VM)
- Recovery USB (0955:7e19) enumerates reliably; BootROM RCM, MB1 applet,
MB2 applet all run; EEPROM/chip_info dump succeeds every time
History
- The module previously ran Linux normally (most recently kernel
5.10.120-tegra reached userspace on this carrier). - Since then, every flash attempt fails, and now cold boot fails too.
Failure signature (identical in every case)
Host side always:
Sending bct_bootrom [100%] → OK
Sending bct_mb1 [100%] → OK
Sending bct_mem [100%]
Error: Return value 8
Command tegrarcm_v2 --download bct_bootrom br_bct_BR.bct
–download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
–download bct_mem mem_rcm_sigheader.bct.encrypt
Device UART always:
E> FAILED: Thermal config
E> FAILED: MEMIO rail config
E> Task 50 failed (err: 0x7979061c)
E> Top caller module: ALIASCHECKER, error module: ALIASCHECKER,
reason: 0x1c, aux_info: 0x06
What I have tried (all fail identically at bct_mem)
- Clean stock R32.7.0 tree (fresh download, fresh directory, no
modified cfg/DTB, no env overrides): Return value 8 - Clean stock R35.5.0 tree (same conditions): Return value 8
- SDK Manager JetPack 5.1.6 (R35.6.4), full auto-detect
(nv-auto-config selected jetson-xavier-nx-devkit-emmc from EEPROM,
passed --ramcode 1 automatically): Return value 8 - Re-running the saved flashcmd.txt directly (which used default
ramcode 0): Return value 8 — so both RAMCODE 1 and 0 fail - flash.sh was always run alone in a fresh recovery session (no manual
tegrarcm/EEPROM reads consumed the RCM session beforehand)
Cold boot result (no host involved)
With no recovery jumper, the existing QSPI bootchain (MB1
1.5.1.9-t194-41334769-73a9b7ef, BCT from QSPI: “Qspi flash params
source = brbct”) — i.e. the exact bits that used to boot this module
successfully — now fails with the same error and auto-resets to
recovery:
[0000.203] E> FAILED: Thermal config
[0000.211] E> FAILED: MEMIO rail config
[0000.220] E> Task 50 failed (err: 0x7979061c)
[0000.224] E> Top caller module: ALIASCHECKER, error module:
ALIASCHECKER, reason: 0x1c, aux_info: 0x06
[0000.263] I> Reset to recovery mode
So the same failure occurs with four different BCT sources (R32.7.0,
R35.5.0, R35.6.4, and the old QSPI-stored BCT that previously worked),
two different MB1 generations, both RAMCODE values, manual flash.sh and
SDK Manager auto-detect, and with no host/USB involvement at all in the
cold boot case.
I have seen topic 285769 where the same signature on Xavier NX led to an
RMA verdict after 32.7.4 and 35.5 both failed.
Questions
- What exactly does ALIASCHECKER reason 0x1c with aux_info 0x06 mean at
MB1 level? Which check fails (address alias probe? rank/row mapping?) - Given that BootROM/MB1/MB2/EEPROM all work and only DRAM init fails,
is there ANY software/firmware-level recovery path for this state, or
is this conclusively a module memory subsystem failure requiring RMA? - Is there any additional diagnostic you would like me to run to
confirm either way?
Attached: host flash logs for attemps,
SDKM_logs_JetPack_5.1.6_Linux_for_Jetson_Xavier_NX_2026-07-17_19-49-23.zip (614.8 KB)
and the
full cold-boot UART capture.
Thank you.
The cold boot UART log is below:
[0000.082] I> Qspi initialized successfully
[0000.086] I> Active Boot chain : 0
[0000.089] I> Boot-device: QSPI
[0000.092] I> Qspi flash params source = brbct
[0000.098] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.106] I> Temperature = 24000
[0000.109] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.113] W> Skipping boost for clk: BPMP_APB
[0000.117] W> Skipping boost for clk: AXI_CBB
[0000.121] W> Skipping boost for clk: AON_CPU_NIC
[0000.125] W> Skipping boost for clk: CAN1
[0000.129] W> Skipping boost for clk: CAN2
[0000.133] I> Boot-device: QSPI
[0000.136] I> Boot-device: QSPI
[0000.139] I> Qspi flash params source = mb1bct
[0000.143] I> Qspi using bpmp-dma
[0000.146] I> Qspi clock source : pllc_out0
[0000.150] I> Qspi reinitialized
[0000.153] I> Qspi flash params source = mb1bct
[0000.158] I> ECC region[0]: Start:0x0, End:0x0
[0000.162] I> ECC region[1]: Start:0x0, End:0x0
[0000.166] I> ECC region[2]: Start:0x0, End:0x0
[0000.171] I> ECC region[3]: Start:0x0, End:0x0
[0000.175] I> ECC region[4]: Start:0x0, End:0x0
[0000.179] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.185] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.189] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.194] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.198] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.224] E> Top caller module: ALIASCHECKER, error module: ALIASCHECKER, reason: 0x1c, aux_info: 0x06
[0000.233] I> MB1(1.5.1.9-t194-41334769-73a9b7ef) BIT boot status dump :
0000000000011111111110111111111111111111111100111110000000000000000000000000000000000000000000000000000000000000000000000000000011011000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
