Hey everyone,
I am trying to use the Xavier to communicate with a SPI device on a relatively low frequency (<3 MHz). Unfortunately I am unable to change the SPI clock speed of the Xavier.
What I tried so far:
- Use SPI_IOC_WR_MAX_SPEED_HZ:
uint32_t speed = 1000000;
ioctl(spi_file, SPI_IOC_WR_MAX_SPEED_HZ, &speed);
This returns successfully, but the clock speed measured on the pin stays unchanged at 8.333MHz.
cat /sys/kernel/debug/clk/clk_summary | grep spi
Outputs 1000000 requested and 960000 actual speed though.
- Use SPI_IOC_MESSAGE:
struct spi_ioc_transfer tr = {
.tx_buf = (unsigned long)tx,
.rx_buf = (unsigned long)rx,
.len = len,
.delay_usecs = delay,
.speed_hz = 1000000,
.bits_per_word = bits,
ioctl(spi_file, SPI_IOC_MESSAGE(1), &tr);
Same result. Returns successfully but the measured clock speed does not change.
Just to be sure I tried py-spidev, a python binding for spidev.
Same result. -
Changing
spi-max-frequencyas described in this helpful answer:
This esults in the Xavier not booting to desktop anymore. The device is booting straight to bash with the errordc hdmi hotplug init couldnt get regulator vdd hdmi 5v0. Really not sure what to make of that and if that’s related at all. The HDMI cable is plugged in the whole time and the device comes up again after I reflash.
I found similar sounding problems on older platforms but without a solution to the issue.
