Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”):
Software Version
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.6.0.8170
1.5.1.7815
1.5.0.7774
other
Host Machine Version
native Ubuntu 18.04
other
Hello everyone
I have successfully followed the steps to create an NTB connection to enable Xavier-to-Xavier communication using PCIe. Currently, I have a virtual ethernet connection between two Xavier’s on the same board (Non-Crosslink comm), and since it is a virtual ethernet communication, I can transfer data between them using a standard socket.
What I would like to achieve is to create a communication between the two Xavier’s using shared memory (or in NTB driver terminology: a “Memory Window”). Most probably, I would have to use another kernel module other than the specified ntb_netdev to create a non-virtual-ethernet link, so my question is: Is there any nvidia API that allows us to share memory between Xavier’s that can be used in this case? I am trying to avoid getting to low into Linux driver/kernel module development. Any insight is greatly appreciated.
