Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.6.0.8170
other
Host Machine Version
native Ubuntu 18.04
other
Hello, I am trying to communicate two xavier devices using the 10GbE interfaces (marked in the attached picture as C). Unfortunately, after obtaining the ip addresses of the two 10GbE interfaces using sudo lshw -class network, I can’t seem to ping them. These are the outputs of sudo lshw -class network for each xavier
Xavier1A
nvidia@xavier1a:~$ sudo lshw -class network
*-network
description: Ethernet interface
product: AQC107 NBase-T/IEEE 802.3bz Ethernet Controller [AQtion]
vendor: Aquantia Corp.
physical id: 0
bus info: pci@0000:04:00.0
logical name: enp4s0
version: 02
serial: 00:04:4b:f6:6d:a4
capacity: 10Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pciexpress pm msix msi vpd bus_master cap_list rom ethernet physical tp 100bt-fd 1000bt-fd 10000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=atlantic driverversion=2.2.3.0 duplex=full firmware=3.1.73 ip=192.168.0.10 latency=0 link=no multicast=yes port=twisted pair
resources: irq:78 memory:38240000-3824ffff memory:38250000-38250fff memory:38400000-387fffff memory:38200000-3823ffff
Xavier1B
*-network description: Ethernet interface product: AQC107 NBase-T/IEEE 802.3bz Ethernet Controller [AQtion] vendor: Aquantia Corp. physical id: 0
bus info: pci@0000:03:00.0
logical name: enp3s0
version: 02
serial: 00:04:4b:f6:6d:a5
capacity: 10Gbit/s
width: 64 bits
clock: 33MHz
configuration: autonegotiation=on broadcast=yes driver=atlantic driverversion=2.2.3.0 duplex=full firmware=3.1.73 ip=192.168.0.11 latency=0 link=no multicast=yes port=twisted pair
With this information, running ping 192.168.0.11 (Xavier1A trying to reach Xavier1B’s interface) fails.
Any ideas?
