Ethernet connection for Drive Agx
I want to connect Drive Agx XavierA to Internet but there is nothing under network list(version:Drive Software 9.0 Linux)
Following HARDWARE QUICK START GUIDE https://developer.nvidia.com/drive/documentation, I connected the Dual GbE Dongle to the Black 1&2 1 Gbps 802.3bp Ethernet Port for internet access but I still got nothing. The dongle is blinking so I suppose that the hardware should be working.
Could you give me some advice? Thank you.
Dear dong.liang,
Could you please run “sudo /etc/init.d/networking restart” or reboot the DriveAGX?
And please let me know the network info using ifconfig -a command. Thanks.
Please also check your DHCP server to ensure this device is enabled with an IP from the server.
Fabian
Do not connect to 1&2. it should be connected to 3&4 on my case.
Hi Dong,
May I assume the issue got resolved yet?
Fabian
I also have encountered the same problem. My Driver AGX Xavier cannot connect internet.
I have run “sudo /etc/init.d/networking restart”,but it is useless.
Even reboot device,but it’s still useless.
Please exactly specify how you connected the AGX to the internet.
Fabian
Hi FabianWeise
I used network cable connect to 10GbE 1 port,but it cannot connect internet.
The current version is Drive Software 9.0 Linux. it can connect internet when I flash the device to Drive Software 8.0 Linux.
I don’t know why.
I see your problem; you connected the AGX via the wrong interface.
DRIVE 9.0 comes as Hyperion Kit configuration, so the 10GbE ports 1 and 2 on the back panel are set to static. You can verify that under /etc/systemd/network/ as there all configuration files for the network are stored.
Originally, when building the target image, the network files are taken from /DriveSDK/drive-t186ref-linux/targetfs/<...>.
The conclusion is: Connect via the front panel via 1GbE or 100MbE; and else feel free to modify your network files under /etc/systemd/network to your needs as we do not restrict you from using the interface you want to connect to the internet, including the 10GbE ports on the back panel.
Fabian
I got all the connections right, the ethernet is connected to the Dual GbE Dongle to the Black 1&2 and I tried everything stated in the comments above in the terminal but still no connection.
Hi jolton94,
May I know which platform you’re using? Could you file a new topic with the problem?
Also, could you update you registration information with with private company/research email.
Connecting to port 3&4 works for me. Seems like that’s connected to Xavier B though.
Hi all
The issue has been solved。For the Drive Software 9.0. connecting network cable to 10GBE 3/4 interface on the front panel user can use internet.
Hi qiaoyu.zhang and kmyang,
Good to know issues resolved at you side, thanks.
Hi, I followed all the steps to connect with the front panel and tried 1/2 and 3/4 for 1GbE. It still doesn’t work. The network setting shows that NetworkManager needs to be running. I’m using Drive Software 9.0 on Drive AGX.
Hi @liangkai ,
If possible, please move to DRIVE OS 5.2.0 released recently. If you still have any Ethernet problem, please create a new topic. Thanks.
