I followed this instruction:
DRIVE AGX Developer Kit HW Quick Start Guide.pdf
to connect internet. here is my connection:
and then I opened the networkmanager but i got nothing:
Here is my drive os version:
nvidia@tegra-ubuntu:~$ ifconfig
br0 Link encap:Ethernet HWaddr ea:c0:a7:8a:89:3f
inet6 addr: fe80::e8c0:a7ff:fe8a:893f/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:644 errors:0 dropped:0 overruns:0 frame:0
TX packets:494 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:91453 (91.4 KB) TX bytes:34866 (34.8 KB)
br0.200 Link encap:Ethernet HWaddr ea:c0:a7:8a:89:3f
inet addr:10.42.0.28 Bcast:10.42.0.255 Mask:255.255.255.0
RX packets:425 errors:0 dropped:0 overruns:0 frame:0
TX packets:436 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:29274 (29.2 KB) TX bytes:31758 (31.7 KB)
can0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
UP RUNNING NOARP MTU:16 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:96
can1 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
Interrupt:97
docker0 Link encap:Ethernet HWaddr 02:42:e1:a6:7e:4c
inet addr:172.17.0.1 Bcast:0.0.0.0 Mask:255.255.0.0
UP BROADCAST MULTICAST MTU:1500 Metric:1
collisions:0 txqueuelen:0
enp4s0 Link encap:Ethernet HWaddr 00:04:4b:cb:be:d9
eth0 Link encap:Ethernet HWaddr 00:04:4b:cb:be:d6
RX packets:1621 errors:0 dropped:1212 overruns:0 frame:0
TX packets:5527 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:116867 (116.8 KB) TX bytes:419946 (419.9 KB)
Interrupt:72
hv0 Link encap:Ethernet HWaddr 0a:86:4c:f8:e8:00
RX packets:47 errors:0 dropped:0 overruns:0 frame:0
TX packets:400 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:15298 (15.2 KB) TX bytes:78556 (78.5 KB)
Interrupt:7
hv1 Link encap:Ethernet HWaddr 0a:86:4c:f8:e9:00
RX packets:240 errors:0 dropped:0 overruns:0 frame:0
TX packets:593 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:34488 (34.4 KB) TX bytes:93040 (93.0 KB)
Interrupt:8
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:85 errors:0 dropped:0 overruns:0 frame:0
TX packets:85 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:6426 (6.4 KB) TX bytes:6426 (6.4 KB)
Dear @yueqiao.liu,
Can you restart the network manager and check ifconfig.
sudo /etc/init.d/network-manager restart
nvidia@tegra-ubuntu:~ sudo /etc/init.d/network-manager restart
Restarting network-manager (via systemctl): network-manager.service.
RX packets:7678 errors:0 dropped:0 overruns:0 frame:0
TX packets:5368 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:1196130 (1.1 MB) TX bytes:320140 (320.1 KB)
RX packets:5018 errors:0 dropped:0 overruns:0 frame:0
TX packets:5171 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:334918 (334.9 KB) TX bytes:339345 (339.3 KB)
Interrupt:96
Interrupt:97
enP2p1s0 Link encap:Ethernet HWaddr 00:04:4b:cb:be:db
inet6 addr: fe80::4547:cd66:3328:a1d1/64 Scope:Link
RX packets:22348 errors:0 dropped:18473 overruns:0 frame:0
TX packets:82373 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:1572606 (1.5 MB) TX bytes:6176019 (6.1 MB)
Interrupt:72
inet6 addr: fe80::4b70:ba25:aacf:12b0/64 Scope:Link
RX packets:622 errors:0 dropped:0 overruns:0 frame:0
TX packets:2450 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:211948 (211.9 KB) TX bytes:766330 (766.3 KB)
Interrupt:7
inet6 addr: fe80::1313:b63:139d:c2e5/64 Scope:Link
RX packets:3234 errors:0 dropped:0 overruns:0 frame:0
TX packets:5202 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:478558 (478.5 KB) TX bytes:971877 (971.8 KB)
Interrupt:8
RX packets:94 errors:0 dropped:0 overruns:0 frame:0
TX packets:94 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:7380 (7.3 KB) TX bytes:7380 (7.3 KB)
Dear @yueqiao.liu.
I am using 3/4 port using dualGBe dongle and I see no issue on DRIVE SW 10.0.
Could you double check if there is no issue with LAN cable/dualGBE dongle. Do you see blinking light at ethernet port.
Please check restarting network manager and ifconfig outputs on both Tegras and see if there is difference in ifconfig output on both Tegras.
If possible, please check re-flashing DRIVE SW 10.0 to avoid SW issues related to board state.
can you tell which network card was used with my connection? eth0?
I tried to connect my target device directly to host pc, and manually set ip address, but still not work. i can’t ping from my host pc to target.
Thank you for reply.
I have two purposes:
it is appreciated if you can tell me which instruction should i follow.
Dear @yueqiao.liu,
If you connect the target to host via USB debug port, you can access via minicom at /dev/ttyUSB2 from host.
Did you check re-flashing the target?
Dear @yueqiao.liu,
Is the issue resolved? if not, could you follow the thread Unabled to connect the nvidia drive to the internet
