I have rebooted the unit and i get black screen from all the hdmi outputs, also i don’t have ssh connection to the unit.
I am able to connect to minicom via usb connected to the “debug” usb port and i am able to see basic shell commands.
I am getting video output via “XB” hdmi port and it looks like it is the output for xavier B device, i can’t get a valid network ip , it seems that networkmanger.service is not running.
So the question is how do I start the “first” device? and how can we flash it ?
I managed to set the device in recovery mode but i still can’t find the correct sdk via the sdk manager tool.
Dear @adi4,
As I understand, you seem to have issue with accessing Tegra A.
Are you able to access Tegra A via minicom serial console?
What is the current DRIVE SW version installed on target?
what is the output of lsusb on host when you connect target and host via USB cable?
Dear @adi4,
Please confirm usb cable is connected between host and debug port of target?
If so, you should be able to access target from host using minicom.
Please run tegrarecovery x1 off & tegrareset x1 & tegrarecovery x2 off & tegrareset x2 commands on Aurix console.
Please use sudo minicom -D /dev/ttyUSB2 to accessTegraA and sudo minicom -D /dev/ttyUSB6 to access TegraB from host
We realized that we don’t have Drive product option in the SDK manager. Yesterday we applied to get this product category.
We didn’t get this confirmed yet.
In addition:
Drive OS version: 5.1.6.1-16902563
We can’t ping to Tegra A (10.42.0.28) from Tegra B (Getting FROM 10.42.0.29 icmp_seq=1 Destination Host Unreachable)
We connect the Tegra to the internet via port 10GbE2, but we still don’t have internet connection
