Please provide the following info (check/uncheck the boxes after creating this topic): Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.0
[V] DRIVE OS Linux 5.2.0 and DriveWorks 3.5
other DRIVE OS version
other
SDK Manager Version
[V] 1.6.1.8175
1.6.0.8170
other
Host Machine Version
[V] native Ubuntu 18.04
other
I successfully connected the target to internet using the Dual GbE Dongle. However now I want to also use the ethernet ports on the back of the target. I also want to set them for a different IP address and subnet mask. How do I enable them?
When I plug a cable inside 10GBE 1 or 2, I don’t get an IP address. Also, when I plug in a cable, no leds turn on the 10GBE 1 or 2 RJ45 connector. Any ideas?
Here are my outputs:
nvidia@tegra-ubuntu:~$ ip a l
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: dummy0: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether 36:66:3c:d1:fd:13 brd ff:ff:ff:ff:ff:ff
3: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 00:04:4b:f6:6e:ea brd ff:ff:ff:ff:ff:ff
inet 10.115.199.36/24 brd 10.115.199.255 scope global dynamic eth0
valid_lft 238sec preferred_lft 238sec
inet6 fe80::204:4bff:fef6:6eea/64 scope link
4: enp4s0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
link/ether 00:04:4b:f6:6e:ed brd ff:ff:ff:ff:ff:ff
5: enP4p1s0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
link/ether 00:04:4b:f6:6e:ef brd ff:ff:ff:ff:ff:ff
6: can0: <NOARP,ECHO> mtu 16 qdisc noop state DOWN group default qlen 10
link/can
7: can1: <NOARP,ECHO> mtu 16 qdisc pfifo_fast state DOWN group default qlen 10
link/can
8: eth0.200@eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
inet 10.42.0.28/24 brd 10.42.0.255 scope global eth0.200
nvidia@tegra-ubuntu:~$ ifconfig
enP4p1s0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 00:04:4b:f6:6e:ef txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
enp4s0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 00:04:4b:f6:6e:ed txqueuelen 1000 (Ethernet)
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 10.115.199.36 netmask 255.255.255.0 broadcast 10.115.199.255
inet6 fe80::204:4bff:fef6:6eea prefixlen 64 scopeid 0x20<link>
ether 00:04:4b:f6:6e:ea txqueuelen 1000 (Ethernet)
RX packets 5505563 bytes 5392037698 (5.3 GB)
RX errors 0 dropped 2 overruns 0 frame 0
TX packets 323714 bytes 460391107442267 (460.3 TB)
eth0.200: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 10.42.0.28 netmask 255.255.255.0 broadcast 10.42.0.255
RX packets 30005 bytes 1434871 (1.4 MB)
TX packets 6167 bytes 362995 (362.9 KB)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 442 bytes 109578 (109.5 KB)
TX packets 442 bytes 109578 (109.5 KB)
