Hi:
Our Xavier will restart suddenly during normal work. Please see the attachment system log, want found the root cause,thanks
syslog (346.2 KB)
hello rico.deng,
I did not see obvious failures to make system reboot.
may I know what’s your use-case, please describe the environment setups and also the actual use-case.
how long could you reproduce this issue, is such reboot issue happened frequently.
could you please setup an environment and execute $ dmesg --follow to gather the latest kernel logs and reproduce the issue.
thanks
dmsg-20210115.log (64.8 KB)
use $dmesg command to get the lastest msg upload to analysis.
hello feng.you,
is that also contain the behavior to make system reboot? I did not see any failure according to your logs.
may I know what’s your actual use-case, thanks
Hi Jerry&Feng:
thanks we will try this first
