My system is running Arch linux, with i3wm and using nvidia quadro k420 graphics card connected with display port to a hp z23n monitor. Since the past two months I have been getting Xid errors most of the times when I resume the system from hibernation. If I hibernate for a very short time, say a few minutes everything goes fine, but if the hibernation duration is longer, say 2+ hours, then at the time of resuming the system, it hangs and becomes jerky and the logs get filled with Xid errors. I tried disabling the compositor but still its the same, it fact at the time of writing this, the compositor is not running and I just woke up the system from hibernation, but had to reboot due to the Xid errors.
~❯ journalctl --since="2018-01-29" | grep Xid
Jan 29 01:53:19 aries kernel: NVRM: Xid (PCI:0000:01:00): 31, Ch 00000000, engmask 00000101, intr 10000000
Jan 29 01:53:26 aries kernel: NVRM: Xid (PCI:0000:01:00): 8, Channel 00000010
Jan 29 01:53:34 aries kernel: NVRM: Xid (PCI:0000:01:00): 8, Channel 00000010
Jan 29 13:07:20 aries kernel: NVRM: Xid (PCI:0000:01:00): 31, Ch 00000000, engmask 00000101, intr 10000000
Jan 29 13:07:26 aries kernel: NVRM: Xid (PCI:0000:01:00): 8, Channel 00000008
Jan 29 13:07:34 aries kernel: NVRM: Xid (PCI:0000:01:00): 8, Channel 0000000a
Jan 29 13:07:42 aries kernel: NVRM: Xid (PCI:0000:01:00): 8, Channel 0000000a
Also this card is just a couple months old, its a new system, so most likely it is not a thermal issue. And except for hibernation the system runs fine, there are no crashes or freezes while running the system only if I hibernate do I run into problems.
Would appreciate any help on this, thanks!
nvidia-bug-report.log.gz (196 KB)
