Logs are attached. It is high time that these Xid errors are fixed. Quite often after resuming system from hibernation Xid 31 error is encountered. It would be good if this issue is fixed once and for all.
nvidia-bug-report.log.gz (83.7 KB)
I would appreciate if anyone could look into this. I just got the Xid errors again, but I couldnt take the log report this time because the system froze, and had to be shut down. On seeing the journal logs, I noticed that first Xid 31 is produced and then Xid 8. Please have a look at the logs attached above. Im currently using driver 396.45, these errors only occur upon resuming from hibernation, not on resuming from suspend.
