vtcrno
June 12, 2018, 8:52pm
1
Hi All,
I have very strange issues after upgrading the kernel to 4.17.
The issue start happens after installing latest drivers 390 and new kernel 4.17. Everything works normally until I add Memory or Core clocks.
After that my Linux has been restarted each time when I changed clocks.
[ 68.932599] NVRM: Xid (PCI:0000:05:00): 13, Graphics SM Warp Exception on (GPC 1, TPC 0): Misaligned Address
[ 68.932604] NVRM: Xid (PCI:0000:05:00): 13, Graphics Exception: ESR 0x50c648=0x14000f 0x50c650=0x0 0x50c644=0xd3eff2 0x50c64c=0x17f
[ 68.952118] NVRM: Xid (PCI:0000:05:00): 43, Ch 00000010, engmask 00000101
I tried with beta drivers but the issue is same.
The only difference and weird thing are that now I’m getting error Xid are 13 and 43, but before installing beta drivers (396.24.02) drivers Xid error was only 31 at drivers 390 stable.
nvidia-bug-report.log.gz (119 KB)
Use maximum
Coolbits 28
Bit 1 is undefined, bit 2 tries to force SLI, so don’t use them.
What command line are you using to set clocks?
vtcrno
June 14, 2018, 6:21pm
3
I’m using 31 coolbits, is that too much?
Clocking via terminal:
nvidia-settings -a [gpu:0]/GPUMemoryTransferRateOffset[3]=1000
nvidia-settings -a [gpu:0]/GPUGraphicsClockOffset[3]=120
vtcrno
June 14, 2018, 7:02pm
5
Something is changed in 390.xx and the old set doesn’t work anymore?
I’m trying now with 28 bits, will update the ticket in next 30minutes.
vtcrno
June 14, 2018, 8:22pm
7
Same,
[ 1402.243411] NVRM: Xid (PCI:0000:05:00): 79, GPU has fallen off the bus.
[ 1402.343749] NVRM: Xid (PCI:0000:05:00): 62, ffffffff(ffffffff) ffffffff ffffffff
[ 184.916644] NVRM: Xid (PCI:0000:05:00): 13, Graphics SM Warp Exception on (GPC 1, TPC 0): Misaligned Address
[ 184.916649] NVRM: Xid (PCI:0000:05:00): 13, Graphics Exception: ESR 0x50c648=0x5000f 0x50c650=0x20 0x50c644=0xd3eff2 0x50c64c=0x17f
[ 184.928566] NVRM: Xid (PCI:0000:05:00): 43, Ch 00000010, engmask 00000101
But the errors are a little different.
XID 79 means the gpu was overheating, underpowered or otherwise overstretched so said bye-bye.
