I’m an unhappy owner of an optimus laptop, I run it under Linux Gentoo (kernel 3.17.4).
I managed to configure the system in order to use my nvidia card for offscreen computations as it is shown here:
http://us.download.nvidia.com/XFree86/Linux-x86/319.12/README/randr14.html
After I updated my xorg-server to 1.17.* it doesn’t work (1.17.0 and 1.17.1), Xorg fails to start.
I found a workaround consisting of choosing of xorg-x11 opengl implementation instead of nvidia’s one, but I’d like to use nvidia’s opengl.
The problem is: xorg server doesn’t start, crashing with such an error output:
[  4556.379]
X.Org X Server 1.17.1
Release Date: 2015-02-10
[  4556.384] X Protocol Version 11, Revision 0
[  4556.386] Build Operating System: Linux 3.17.4-gentoo x86_64 Gentoo
[  4556.387] Current Operating System: Linux szldlc 3.17.4-gentoo #2 SMP PREEMPT Thu Jan 22 15:14:07 CET 2015 x86_64
[  4556.387] Kernel command line: root=/dev/sdb2 video=uvesafb:mtrr:4,ywrap,1920x1080-32@100 acpi_osi=Linux acpi_backlight=vendor
[  4556.391] Build Date: 13 February 2015  03:24:53PM
[  4556.392]
[  4556.394] Current version of pixman: 0.32.6
[  4556.397] 	Before reporting problems, check http://wiki.x.org
	to make sure that you have the latest version.
[  4556.397] Markers: (--) probed, (**) from config file, (==) default setting,
	(++) from command line, (!!) notice, (II) informational,
	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[  4556.404] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Feb 13 17:05:09 2015
[  4556.405] (==) Using config file: "/etc/X11/xorg.conf"
[  4556.407] (==) Using config directory: "/etc/X11/xorg.conf.d"
[  4556.408] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[  4556.408] (==) ServerLayout "layout"
[  4556.408] (**) |-->Screen "nvidia" (0)
[  4556.408] (**) |   |-->Monitor "<default monitor>"
[  4556.409] (**) |   |-->Device "nvidia"
[  4556.409] (==) No monitor specified for screen "nvidia".
	Using a default monitor configuration.
[  4556.409] (**) |-->Inactive Device "intel"
[  4556.409] (==) Automatically adding devices
[  4556.409] (==) Automatically enabling devices
[  4556.409] (==) Automatically adding GPU devices
[  4556.409] (==) FontPath set to:
	/usr/share/fonts/misc/,
	/usr/share/fonts/TTF/,
	/usr/share/fonts/OTF/,
	/usr/share/fonts/Type1/,
	/usr/share/fonts/100dpi/,
	/usr/share/fonts/75dpi/
[  4556.409] (**) ModulePath set to "/usr/lib64/opengl/nvidia,/usr/lib64/xorg/modules,/usr/lib32/xorg/modules"
[  4556.409] (II) The server relies on udev to provide the list of input devices.
	If no devices become available, reconfigure udev or disable AutoAddDevices.
[  4556.409] (II) Loader magic: 0x800c40
[  4556.409] (II) Module ABI versions:
[  4556.409] 	X.Org ANSI C Emulation: 0.4
[  4556.409] 	X.Org Video Driver: 19.0
[  4556.409] 	X.Org XInput driver : 21.0
[  4556.409] 	X.Org Server Extension : 9.0
[  4556.409] (II) xfree86: Adding drm device (/dev/dri/card1)
[  4556.409] (II) xfree86: Adding drm device (/dev/dri/card0)
[  4556.410] (--) PCI:*(0:0:2:0) 8086:0166:1558:6500 rev 9, Mem @ 0xf7400000/4194304, 0xd0000000/268435456, I/O @ 0x0000f000/64
[  4556.410] (--) PCI: (0:1:0:0) 10de:1292:1558:6500 rev 161, Mem @ 0xf6000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
[  4556.410] (II) LoadModule: "glx"
[  4556.410] (II) Loading /usr/lib64/opengl/nvidia/extensions/libglx.so
[  4556.418] (II) Module glx: vendor="NVIDIA Corporation"
[  4556.418] 	compiled for 4.0.2, module version = 1.0.0
[  4556.418] 	Module class: X.Org Server Extension
[  4556.418] (II) NVIDIA GLX Module  346.35  Sat Jan 10 20:53:39 PST 2015
[  4556.418] (II) LoadModule: "nvidia"
[  4556.418] (II) Loading /usr/lib64/xorg/modules/drivers/nvidia_drv.so
[  4556.419] (II) Module nvidia: vendor="NVIDIA Corporation"
[  4556.419] 	compiled for 4.0.2, module version = 1.0.0
[  4556.419] 	Module class: X.Org Video Driver
[  4556.419] (II) LoadModule: "modesetting"
[  4556.419] (II) Loading /usr/lib64/xorg/modules/drivers/modesetting_drv.so
[  4556.419] (II) Module modesetting: vendor="X.Org Foundation"
[  4556.419] 	compiled for 1.17.1, module version = 1.17.1
[  4556.419] 	ABI class: X.Org Video Driver, version 19.0
[  4556.419] (II) NVIDIA dlloader X Driver  346.35  Sat Jan 10 20:32:18 PST 2015
[  4556.419] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[  4556.419] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[  4556.419] (--) using VT number 7
[  4556.424] (II) Loading sub module "fb"
[  4556.424] (II) LoadModule: "fb"
[  4556.424] (II) Loading /usr/lib64/xorg/modules/libfb.so
[  4556.424] (II) Module fb: vendor="X.Org Foundation"
[  4556.424] 	compiled for 1.17.1, module version = 1.0.0
[  4556.424] 	ABI class: X.Org ANSI C Emulation, version 0.4
[  4556.424] (II) Loading sub module "wfb"
[  4556.424] (II) LoadModule: "wfb"
[  4556.424] (II) Loading /usr/lib64/xorg/modules/libwfb.so
[  4556.424] (II) Module wfb: vendor="X.Org Foundation"
[  4556.424] (II) Loading sub module "ramdac"
[  4556.424] (II) LoadModule: "ramdac"
[  4556.424] (II) Module "ramdac" already built-in
[  4556.425] (II) modeset(1): using drv /dev/dri/card0
[  4556.425] (II) modeset(G0): using drv /dev/dri/card0
[  4556.425] (EE) Screen 1 deleted because of no matching config section.
[  4556.425] (II) UnloadModule: "modesetting"
[  4556.425] (II) NVIDIA(0): Creating default Display subsection in Screen section
	"nvidia" for depth/fbbpp 24/32
[  4556.425] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[  4556.425] (==) NVIDIA(0): RGB weight 888
[  4556.425] (==) NVIDIA(0): Default visual is TrueColor
[  4556.425] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[  4556.425] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[  4556.425] (**) NVIDIA(0): Enabling 2D acceleration
[  4556.525] (II) NVIDIA(GPU-0): Found DRM driver nvidia-drm (20130102)
[  4556.526] (II) NVIDIA(0): NVIDIA GPU GeForce GT 740M (GK208) at PCI:1:0:0 (GPU-0)
[  4556.526] (--) NVIDIA(0): Memory: 1048576 kBytes
[  4556.526] (--) NVIDIA(0): VideoBIOS: 80.28.22.00.31
[  4556.526] (II) NVIDIA(0): Detected PCI Express Link width: 8X
[  4556.526] (--) NVIDIA(0): Valid display device(s) on GeForce GT 740M at PCI:1:0:0
[  4556.526] (--) NVIDIA(0):     none
[  4556.526] (II) NVIDIA(0): Validated MetaModes:
[  4556.526] (II) NVIDIA(0):     "NULL"
[  4556.526] (II) NVIDIA(0): Virtual screen size determined to be 640 x 480
[  4556.526] (WW) NVIDIA(0): Unable to get display device for DPI computation.
[  4556.526] (==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
[  4556.526] (==) modeset(G0): Depth 24, (==) framebuffer bpp 32
[  4556.526] (==) modeset(G0): RGB weight 888
[  4556.526] (==) modeset(G0): Default visual is TrueColor
[  4556.526] (II) Loading sub module "glamoregl"
[  4556.526] (II) LoadModule: "glamoregl"
[  4556.526] (II) Loading /usr/lib64/xorg/modules/libglamoregl.so
[  4556.528] (II) Module glamoregl: vendor="X.Org Foundation"
[  4556.528] 	compiled for 1.17.1, module version = 1.0.0
[  4556.528] 	ABI class: X.Org ANSI C Emulation, version 0.4
[  4556.528] (II) glamor: OpenGL accelerated X.org driver based.
[  4556.552] (EE)
[  4556.552] (EE) Backtrace:
[  4556.552] (EE) 0: /usr/bin/X (xorg_backtrace+0x48) [0x57fa38]
[  4556.552] (EE) 1: /usr/bin/X (0x400000+0x183969) [0x583969]
[  4556.552] (EE) 2: /lib64/libc.so.6 (0x7f07e41b5000+0x34ec0) [0x7f07e41e9ec0]
[  4556.552] (EE) 3: /usr/lib64/libX11.so.6 (_XSend+0x1b) [0x7f07dc2add0b]
[  4556.552] (EE) 4: /usr/lib64/libX11.so.6 (_XFlush+0x15) [0x7f07dc2ae1b5]
[  4556.552] (EE) 5: /usr/lib64/libX11.so.6 (_XGetRequest+0x55) [0x7f07dc2b0bc5]
[  4556.552] (EE) 6: /usr/lib64/libX11.so.6 (XQueryExtension+0x3d) [0x7f07dc2a4add]
[  4556.552] (EE) 7: /usr/lib64/libX11.so.6 (XInitExtension+0x22) [0x7f07dc299202]
[  4556.552] (EE) 8: /usr/lib64/libXext.so.6 (XextAddDisplay+0x4f) [0x7f07dc067d3f]
[  4556.552] (EE) 9: /usr/lib64/libnvidia-glsi.so.346.35 (0x7f07dc5a7000+0x63017) [0x7f07dc60a017]
[  4556.552] (EE) 10: /usr/lib64/libnvidia-glsi.so.346.35 (0x7f07dc5a7000+0x4484) [0x7f07dc5ab484]
[  4556.552] (EE) 11: /usr/lib64/opengl/nvidia/lib/libEGL.so.1 (0x7f07dca39000+0x2381e) [0x7f07dca5c81e]
[  4556.552] (EE) 12: /usr/lib64/opengl/nvidia/lib/libEGL.so.1 (0x7f07dca39000+0x2417a) [0x7f07dca5d17a]
[  4556.552] (EE) 13: /usr/lib64/opengl/nvidia/lib/libEGL.so.1 (0x7f07dca39000+0x2c946) [0x7f07dca65946]
[  4556.552] (EE) 14: /usr/lib64/xorg/modules/libglamoregl.so (glamor_egl_init+0x89) [0x7f07de271399]
[  4556.552] (EE) 15: /usr/lib64/xorg/modules/drivers/modesetting_drv.so (0x7f07de8fd000+0x6949) [0x7f07de903949]
[  4556.552] (EE) 16: /usr/bin/X (InitOutput+0xbd1) [0x477771]
[  4556.552] (EE) 17: /usr/bin/X (0x400000+0x3a91b) [0x43a91b]
[  4556.553] (EE) 18: /lib64/libc.so.6 (__libc_start_main+0xf5) [0x7f07e41d6ad5]
[  4556.553] (EE) 19: /usr/bin/X (0x400000+0x2620e) [0x42620e]
[  4556.553] (EE)
[  4556.553] (EE) Segmentation fault at address 0x0
[  4556.553] (EE)
Fatal server error:
[  4556.553] (EE) Caught signal 11 (Segmentation fault). Server aborting
[  4556.553] (EE)
[  4556.553] (EE)
Please consult the The X.Org Foundation support
	 at http://wiki.x.org
 for help.
[  4556.553] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[  4556.553] (EE)
[  4556.561] (EE) Server terminated with error (1). Closing log file.
Do I do something wrong or the driver/xorg is buggy?
nvidia-bug-report.log.gz (57.1 KB)
