**• Hardware Platform (Jetson / GPU) - Jetson Xavier
**• DeepStream Version - 5.0
**• JetPack Version - 4.4
**• TensorRT Version -7.1.3 • NVIDIA GPU Driver Version (valid for GPU only)
**• Issue Type - I am trying to run YoloV3 model based on DeepStream sample application based on NVIDIA DeepStream SDK.
Please see the link below for more information;
I have also sucessfully manage to build the TRT-OSS application which I believe is required to run YoloV3 model.
When I tried running this command;
./apps/tao_detection/ds-tao-detection -c configs/yolov3_tao/pgie_yolov3_tao_config.txt -i sample_outdoor_car_1080p_10fps.h264 -d
We have new Deepstream 6.0 + JetPack 4.6 release, would you mind updating your software to the latest first?
The GitHub sample is also verified with Deepstream 6.0.
I am planning to upgrade to Deepstream 6.0 and I just found out that this will require Jetpack 4.6?
I believe currently the Jetson Xavier NX is configured with Jet pack 4.4 and hosts Deepstream 5.0 where I am able to run a few Deepstream test applications. Does, upgrading/flashing new Jetpack affect existing files and applications on Jetson? Do I need to do a back up before upgrading/flashing Jetpack 4.6?
I am concerned that I may lose existing files and Deepstream applications that are already hosted on Jetson.
