Hardware Platform (Jetson / GPU): Jetson Xavier AGX
DeepStream Version: 5.0
JetPack Version (valid for Jetson only) 4.4
TensorRT Version 7.1.3-1+cuda10.2
Hi I followed the instructions posted over here: DeepStream SDK FAQ - #7 by bcao
And for some reason I dont understand I get this outout in shell but no visual output like the video with the marked detections…
Unknown or legacy key specified 'is-classifier' for group [property]
Opening in BLOCKING MODE
0:00:03.976461743 698 0x26425b60 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1701> [UID = 1]: deserialized trt engine from :/xavier_ssd/deepstream/deepstream-5.0/sources/objectDetector_Yolo/yolov4_1_3_608_608_fp16.engine
INFO: [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input 3x608x608
1 OUTPUT kFLOAT boxes 22743x1x4
2 OUTPUT kFLOAT confs 22743x80
0:00:03.976671001 698 0x26425b60 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1805> [UID = 1]: Use deserialized engine model: /xavier_ssd/deepstream/deepstream-5.0/sources/objectDetector_Yolo/yolov4_1_3_608_608_fp16.engine
0:00:03.997042392 698 0x26425b60 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/xavier_ssd/deepstream/deepstream-5.0/sources/objectDetector_Yolo/config_infer_primary_yoloV4.txt sucessfully
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
** INFO: <bus_callback:181>: Pipeline ready
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
** INFO: <bus_callback:167>: Pipeline running
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
H264: Profile = 66, Level = 0
avg bitrate=0 for CBR, force to CQP mode
**PERF: FPS 0 (Avg)
**PERF: 28.07 (26.81)
**PERF: 28.44 (28.37)
**PERF: 28.54 (28.38)
**PERF: 28.36 (28.39)
**PERF: 28.41 (28.39)
**PERF: 28.52 (28.43)
**PERF: 28.35 (28.42)
**PERF: 28.40 (28.42)
**PERF: 28.45 (28.41)
**PERF: 28.39 (28.41)
Any suggestions what I’m doing wrong?
