yoloV7 onnx triton inference
• Hardware Platform (Jetson / GPU) T4
• DeepStream Version
• JetPack Version (valid for Jetson only)*
• TensorRT Version 8.2
**• NVIDIA GPU Driver Version (valid for GPU only)**11.6
during inference i get below error :
WARNING: Overriding infer-config batch-size 0  with number of sources  1
Creating nvtracker
Adding elements to Pipeline
Linking elements in the Pipeline
yolov7.py:953: PyGIDeprecationWarning: GObject.MainLoop is deprecated; use GLib.MainLoop instead
  loop = GObject.MainLoop()
test---------
Now playing...: inputimages/horses.jpg
Starting pipeline
0:00:00.390670756 24187      0x3f42a30 WARN           nvinferserver gstnvinferserver_impl.cpp:287:validatePluginConfig:<primary-inference> warning: Configuration file batch-size reset to: 1
INFO: infer_grpc_backend.cpp:164 TritonGrpcBackend id:5 initialized for model: yolov7
python3: infer_cuda_utils.cpp:86: nvdsinferserver::CudaTensorBuf::CudaTensorBuf(const nvdsinferserver::InferDims&, nvdsinferserver::InferDataType, int, const string&, nvdsinferserver::InferMemType, int, bool): Assertion `!hasWildcard(dims)' failed.
Aborted (core dumped)```
  1. here is a sample GitHub - thanhlnbka/yolov7-triton-deepstream
  2. which sample are your application based on?
  3. how do you generate yolov7 model? could you share the model configuration file for triton and deepstream configuration file?
will check the above repo and get back to you .
Deepstream 6.1
i generally use deepstream_python_apps/apps/deepstream-ssd-parser at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub as the base code to work on .
Is this still an issue to support? Thanks
