Thank you for your feedback.
I tested several configurations:
YOLOv8 trained on PC
Export to ONNX (different opset versions)
Conversion ONNX → TensorRT engine on Jetson TX2
Multiple preprocessing versions (RGB/BGR, resize vs letterbox)
Different postprocessing attempts (with and without NMS logic, confidence variations)
TensorRT FP16 engine on TX2
The GPU and TensorRT are working correctly, but the output remains unstable or incorrect.
At this stage, I suspect a mismatch between YOLOv8 output format and my TensorRT postprocessing implementation.
this is my code import tensorrt as trt
import pycuda.driver as cuda
import pycuda.autoinit
import numpy as np
import cv2
ENGINE_PATH = “best2.engine”
IMAGE_PATH = “test.jpg”
IMG_SIZE = 640
CONF_THRESH = 0.3
TRT_LOGGER = trt.Logger(trt.Logger.WARNING)
LOAD ENGINE
with open(ENGINE_PATH, “rb”) as f:
runtime = trt.Runtime(TRT_LOGGER)
engine = runtime.deserialize_cuda_engine(f.read())
context = engine.create_execution_context()
print(“✅ Engine loaded”)
LETTERBOX (IMPORTANT FIX)
def letterbox(img, new_shape=640):
h, w = img.shape[:2]
scale = min(new_shape / h, new_shape / w)
nh, nw = int(h * scale), int(w * scale)
resized = cv2.resize(img, (nw, nh))
canvas = np.full((new_shape, new_shape, 3), 114, dtype=np.uint8)
top = (new_shape - nh) // 2
left = (new_shape - nw) // 2
canvas[top:top+nh, left:left+nw] = resized
return canvas, scale, top, left
img = cv2.imread(IMAGE_PATH)
if img is None:
print(“❌ Image not found”)
exit()
orig = img.copy()
h0, w0 = orig.shape[:2]
img, scale, pad_y, pad_x = letterbox(img, IMG_SIZE)
BGR → RGB
img = cv2.cvtColor(img, cv2.COLOR_BGR2RGB)
Normalize
img = img.astype(np.float32) / 255.0
CHW format
img = np.transpose(img, (2, 0, 1))
img = np.expand_dims(img, axis=0)
img = np.ascontiguousarray(img)
GPU
d_input = cuda.mem_alloc(img.nbytes)
output = np.empty((1, 10000, 6), dtype=np.float32) # adjust if needed
d_output = cuda.mem_alloc(output.nbytes)
bindings = [int(d_input), int(d_output)]
cuda.memcpy_htod(d_input, img)
context.execute_v2(bindings)
cuda.memcpy_dtoh(output, d_output)
print(“✅ Inference done”)
POSTPROCESS (FIXED)
preds = output[0]
detected = False
best_conf = 0.0
for det in preds:
# YOLOv8 format most common:
x, y, w, h, conf, cls_id = det
# ignore invalid
if conf < CONF_THRESH:
continue
detected = True
best_conf = max(best_conf, conf)
# Undo letterbox
x1 = (x - w / 2)
y1 = (y - h / 2)
x2 = (x + w / 2)
y2 = (y + h / 2)
# remove padding + scale back
x1 = int((x1 - pad_x) / scale)
y1 = int((y1 - pad_y) / scale)
x2 = int((x2 - pad_x) / scale)
y2 = int((y2 - pad_y) / scale)
# clamp
x1 = max(0, min(w0, x1))
y1 = max(0, min(h0, y1))
x2 = max(0, min(w0, x2))
y2 = max(0, min(h0, y2))
cv2.rectangle(orig, (x1, y1), (x2, y2), (0, 255, 0), 2)
cv2.putText(orig,
f"OBJ {conf:.2f}",
(x1, y1 - 10),
cv2.FONT_HERSHEY_SIMPLEX,
0.7,
(0, 255, 0),
2)
RESULT
if detected:
print(“🦀 OBJECT DETECTED | CONF:”, best_conf)
else:
print(“❌ NO DETECTION”)
cv2.imwrite(“result.jpg”, orig)
print(“✅ Saved result.jpg”)
