dear,
i modify driver &dts for support YUV sensor, but err as follow:
modify:
camera_common.c
MEDIA_BUS_FMT_UYVY8_2X8,
V4L2_COLORSPACE_SRGB,
V4L2_PIX_FMT_UYVY,
sensor_common.c
else if (strncmp(pixel_t, "yuv_yuyv8", size) == 0)
*format = V4L2_PIX_FMT_UYVY;
capture video cmd:
v4l2-ctl -d /dev/video0 -w --verbose --set-fmt-video=width=1920,height=1080 --stream-mmap --stream-count=1 --set-ctrl bypass_mode=0 --stream-to=/tmp/stream.raw
--stream-to=/tmp/stream.yuvtream-mmap --stream-count=1 --set-ctrl bypass_mode=0 -
Opening in BLOCKING MODE
VIDIOC_QUERYCAP: ok
VIDIOC_S_EXT_CTRLS: ok
VIDIOC_G_FMT: ok
libv4l2: error setting pixformat: Invalid argument
VIDIOC_S_FMT: failed: Invalid argument
VIDIOC_REQBUFS: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_STREAMON: ok
[ 296.626888] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 134, err_data 131072
[ 299.185530] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 299.185719] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 299.185907] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
Index : 1
Type : Video Capture
Flags : mapped, error
Field : None
Sequence : 1
Length : 4658048
Bytesused: 4658048
Timestamp: 0.000000s (Monotonic, End-of-Frame)
Index : 1
Flags : mapped, error[ 299.188072] tegra194-vi5 15c10000.vi: unexpected response from camera processor
Field : None
Sequence : 0[ 299.188291] tegra194-vi5 15c10000.vi: vi capture setup failed
Length : 4658048
Bytesused: 4658048[ 299.188435] tegra194-vi5 15c10000.vi: fatal: error recovery failed
Index : 2
Field : None
Sequence : 2
Length : 4658048
Bytesused: 4658048
Index : 3
Field : None
Sequence : 3
Length : 4658048
Bytesused: 4658048
Index : 0
