2025.4.1 Install Fails
I tried several times to install CUDA Toolkit 13.1.1 but each time it failed. However if I unchecked the Nsight Compute box of the installation it worked. I tried to install Nsight Compute 2020.4.1 separately but when I do I get a message that I need to have powershell installed which I do and it is in both environmental paths. Just to note I do have CUDA Toolkit 12.9 installed with Nsight Compute 2025.2.1
Hi, @dlwharton
Sorry for the issue you met.
Can you please uninstall Nsight Compute 2025.2.1 and install separate Nsight Compute 2025.4.1 directly from Getting Started with Nsight Compute | NVIDIA Developer
