And (obviously) does not work for the tx1 platform. I downloaded then the JetPack 3.1 and when I go to download the components for the TX1 it finds only 24.2.1…
Am I missing something obvious?
This used to be there, so it looks like the web page lost something. Some files are in common between a TX1 and TX2, e.g., the sample root file system, but driver package itself differs between the two unless something has changed.
I see only this for a TX2:
Tegra186_Linux_R28.1.0_aarch64.tbz2
The file which used to be there, but which is now missing, is: Tegra210_Linux_R28.1.0_aarch64.tbz2
Can someone verify whether the web page has broken or if we have lost the TX1 R28.1 downloads?
Just for the sake of trivia, each Tegra chip has a series of chips defining an architecture. Then there are a series of actual implementations within a series (e.g., one implementation may be dual core, the other quad core…both are the same architecuture).
A TX1 is t21x architecture/series, a TX2 is t18x architecture/series. A t210 is the quad core implementation on the module everyone knows for a TX1, the t186 is the quad core module which fits the developer board (there would be a different implementation on Shield TV, but architecture would match).
