Where is R24.1?
I don’t see it in https://developer.nvidia.com/embedded/downloads. If not there, then where?
See:
https://developer.nvidia.com/embedded/linux-tegra
Still It seems CUDA is not available for R24.1 … when can we expect it ?
That’s what I did. Then I click on “Jetson TX1 Developer Kit User Guide”, which on page 4 tells me to go to https://developer.nvidia.com/embedded-computing, and when I click on the “download” square, I end up in the link I posted above.
Anyone? Anyone?
As linuxdev linked, use the direct links from that page:
Drivers: http://developer.nvidia.com/embedded/dlc/l4t-jetson-tx1-driver-package-24-1
Filesystem: http://developer.nvidia.com/embedded/dlc/l4t-sample-root-filesystem-24-1
FS Sources: http://developer.nvidia.com/embedded/dlc/l4t-sample-root-filesystem-sources-24-1
Kernel Sources: http://developer.nvidia.com/embedded/dlc/l4t-24-1-kernel-sources
and so on and so forth…
Can we have someone from nVidia tell us why the advertised links in the official downloads page are not working? Is 24R1 supported or not?
Your links above have extra characters in them which cause them not to resolve correctly. The links above from linuxdev and RNZNobody are correct.
https://developer.nvidia.com/embedded/linux-tegra The CUDA packages for R24.1 and Jetpack will be released in the near future.
The R24.1 packages have now all been released, see here —https://devtalk.nvidia.com/default/topic/941913/jetson-tx1/jetpack-2-2-l4t-r24-1-64-bit-and-32-bit-cuda-released/
