[32.3.1] gstreamer pipeline error and cmda_handle_timeout with OV5693
Looks similar to this topic:
I fail to reproduce this (running as user nvidia). My AGX Xavier is running R32.4.4:
gst-launch-1.0 -v nvarguscamerasrc ! 'video/x-raw(memory:NVMM),width=2592,height=1944' ! queue max-size-buffers=1 leaky=2 name=q1 ! tee name=t \
 t. ! queue name=q3 ! nvvidconv name=testLoc flip-method=2 left=1692 right=2172 top=900 bottom=1280 ! 'video/x-raw(memory:NVMM),width=480,height=380' ! nvoverlaysink name=displaySink async=false sync=false overlay-x=0 overlay-y=360 overlay-w=480 overlay-h=380 \
 t. ! queue name=q4 ! valve drop=true ! nvvidconv ! clockoverlay time-format=\"%D %H:%M:%S\" halignment=right ! nvjpegenc ! multifilesink name=testPicture async=true location=/home/nvidia/tmp/pic1.jpg \
 t. ! queue name=q5 ! nvvidconv name=b ! 'video/x-raw(memory:NVMM),width=(int)1920,height=(int)1080' ! nvivafilter cuda-process=true customer-lib-name="libnvsample_cudaprocess.so"  ! 'video/x-raw(memory:NVMM),width=(int)1920,height=(int)1080, format=NV12' ! nvv4l2h264enc maxperf-enable=1 bitrate=8000000 ! 'video/x-h264, stream-format=(string)byte-stream' ! h264parse ! valve drop=true ! splitmuxsink name=testVideoSink async-handling=true location=/home/nvidia/tmp/tmpFile.h264
You may try to upgrade. Seems you’re using OV5693 sensor, it should be supported in upgrades.
