Should this be the case?
Huge fps drops and stuttering when using the 362 driver in games like cs:go, also lower fps noticeable in dota 2. When I use the 340 driver the better performance is very noticeable. No stuttering or big fps drops.
I just felt like I should point this out. Is my card that old now?
Also when using nvidia proprietary drivers i get terrible screen flickering in kde and fullscreen flicker also in ubuntu unity and xfce. When I’ve used linux in the past (back with 331 drivers) I would simply set compositor to opengl 3.1 and set full screen repaints to get rid of tearing. I never even had flickering.
But now I have to turn compositor off or set it to xrender to avoid the random flickering issue. And no documented trick seems to get rid of screen tearing. The opensource noveau driver doesn’t have a flicker or unfixable tearing issue.
Thanks for listening,
Rich.
