I’m new to Jetson Nano, so I’d like to confirm something that may be trivial:
The Jetson Nano has 3x USB 2.0 ports and 1x USB 3.0 port, is that correct?
If I want 3x USB 2.0 connectors on my board, I can simply route the USB0_D+ / USB0_D- pins to USB connector 1, USB1_D+ / USB1_D- pins to USB connector 2 and USB2_D+ / USB2_D- pins to USB connector 3?
If I want more than 1 USB 3.0 on my board, I have to use a USB HUB IC on the USB 3.0 port, is that correct?
Thanks for your help. One last question: I see that the Jetson Nano schematics uses the TPS259530DSG IC (Electronic fuse and protection) to provide 5V to the USB’s VBUS pins. I assume it’s just an additional protection against faulty USB devices plugged into the Jetson Nano, and that it’s not really mandatory. Is that correct? Is it ok if I simply route my board’s 5V to the USB’s VBUS pins? Or that’s not recommended?
