I installed the nvidia-415 for mine gtx 1050 ti on a dell xps 9570.
Installation seems ok, and I selected Nvidia on prime, but on preferens/details I still seeing Intel UHD Graphics 630 as graphics.
I attach log and screenshots.
Thanks to all can help me.
nvidia-bug-report.log.gz (1.01 MB)
nvidia-bug-report2019-02-05.log.gz (1.03 MB)
Logout from your currenet session or restart pc to make this change effctive.
Btw , that Ubuntu system info screen always shows Intel on there. Ignore it.
When you run inxi -SMGxx command , output should be like that.
Graphics:
Device-1: Intel vendor: ASUSTeK driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:591b
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: ASUSTeK
driver: nvidia v: 415.27 bus ID: 01:00.0 chip ID: 10de:1c8d
Display: x11 server: X.Org 1.19.6 driver: modesetting,nvidia
unloaded: fbdev,nouveau,vesa resolution: 1920x1080~60Hz
OpenGL: renderer: GeForce GTX 1050/PCIe/SSE2 v: 4.6.0 NVIDIA 415.27
direct render: Yes
Important parts:
direct render: Yes
I have this output
System:
Host: tom-dell Kernel: 4.20.0-042000-generic x86_64 bits: 64 compiler: gcc
v: 8.2.0 Desktop: Gnome 3.30.1 wm: gnome-shell dm: GDM3
Distro: Ubuntu 18.10 (Cosmic Cuttlefish)
Machine:
Type: Laptop System: Dell product: XPS 15 9570 v: N/A
serial: <root required> Chassis: type: 10 serial: <root required>
Mobo: Dell model: 0D0T05 v: A00 serial: <root required> UEFI: Dell
v: 1.7.0 date: 12/25/2018
Graphics:
Device-1: Intel driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:3e9b
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] driver: nvidia
v: 415.27 bus ID: 01:00.0 chip ID: 10de:1c8c
Display: wayland server: X.Org 1.20.1 driver: modesetting,nvidia
unloaded: fbdev,nouveau,vesa compositor: gnome-shell
resolution: 2880x1620~60Hz, 3840x2160~60Hz
[u][b] OpenGL: renderer: Mesa DRI Intel UHD Graphics 630 (Coffeelake 3x8 GT2)
v: 4.5 Mesa 18.2.2 compat-v: 3.0 direct render: Yes[/b][/u]
First things first: Don’t use Wayland , use X.
Second: You’re still on Intel as we can see at renderer line.
Third: Open terminal and do this:
sudo prime-select nvidia
See if this will work or not.
already did.
Info: the nvidia profile is already set
Please make sure you disabled wayland:
[url]xorg - How to disable wayland in 17.10 in gdm3 login screen - Ask Ubuntu
If that doesn’t help, check if the file /lib/modprobe.d/nvidia-kms.conf exists and change
modeset=1 to modeset=0
and run sudo update-initramfs -u
I disabled it and now the boot loading stop on the Ubuntu loading before the logging
Check if using lightdm instead of gdm helps:
[url]How to change from GDM to LightDM? - Ask Ubuntu
I followed the installation and selected gdm3, but nothing seems changes
generix
February 1, 2019, 7:59am
11
I’m not sure what exactly you did now, you should have done
sorry for the attendance. I attached the file in the original post
I also got that problem. Anyone help me.
A simple resintall of nvidia drivers fixed my issue
sudo apt-get install --reinstall nvidia-driver-440
Hello I have similiar issue. after installing Cuda 10.1 i had this problem. I dont know should i install nvidia driver again. Because before cuda i already installed driver-455
@generix ty so much after following your instructions it worked perfect.
