I install the driver but the system shows that the nvidia driver is not being used. I already tried a bunch of things like: purge and reinstall the driver, all the others avaiable drivers, even the .run download from the nvidia site, blacklist nouveau, ocl-icd-libopencl1, bumblebee and probably some others i can’t even remember now. All of this were done isolated and in combination with each other, by undoing the modificatons i had done or by formating and starting all from scratch.
I don’t thing the problem is a hardware one because everything works fine on windows.
Here are some information:
Notebool Dell Vostro 5470
Nvidia Geforce GT 740M
Ubuntu 18.04.4
uname -a
Linux darkstar 5.3.0-42-generic #34~18.04.1-Ubuntu SMP Fri Feb 28 13:42:26 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
lspci | egrep ‘VGA|3D|Display’
00:02.0 VGA compatible controller: Intel Corporation Haswell-ULT Integrated Graphics Controller (rev 09)
09:00.0 3D controller: NVIDIA Corporation GK208M [GeForce GT 740M] (rev a1)
sudo nvidia-smi
NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
glxinfo | grep render
direct rendering: Yes
GLX_MESA_multithread_makecurrent, GLX_MESA_query_renderer,
GLX_MESA_query_renderer, GLX_MESA_swap_control, GLX_OML_swap_method,
Extended renderer info (GLX_MESA_query_renderer):
OpenGL renderer string: Mesa DRI Intel(R) Haswell Mobile
GL_ARB_compute_shader, GL_ARB_conditional_render_inverted,
GL_NV_compute_shader_derivatives, GL_NV_conditional_render,
GL_EXT_read_format_bgra, GL_EXT_render_snorm, GL_EXT_robustness,
GL_NV_conditional_render, GL_NV_draw_buffers, GL_NV_fbo_color_attachments,
GL_OES_element_index_uint, GL_OES_fbo_render_mipmap,
sudo prime-select query
nvidia
About feature of gnome
Processor Intel® Core™ i7-4500U CPU @ 1.80GHz × 4
Graphics Intel® Haswell Mobile[nvidia-bug-report.log|attachment]
I folloed this instructions: " Please always include a copy of an nvidia-bug-report.log.gz file, which can be generated with the nvidia-bug-report.sh script shipped with the NVIDIA Linux/FreeBSD graphics drivers and installed in your PATH; the log file will be placed in the current working directory. Attach the log file by clicking the Upload
button in the post composition window."
But received this message: “Sorry, the file you are trying to upload is not authorized (authorized extensions: jpg, jpeg, png, gif, log).”
So i removed the .gz from the file nvidia-bug-report.log.gz
(upload://jPhdaPqTxmOv2wpfPDxBQaCnDhA.log) (76.4 KB) nvidia-bug-report.log (76.4 KB)
