Hi, generix, encountering similar issue here, could you be more concrete on how to “…switch to the correct kernel version in the grub menu”. I’m kind of a newbie using Ubuntu, many thanks!!!
What I have:
root@NUS:~# nvidia-smi
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
root@NUS:~# nvidia-settings
ERROR: NVIDIA driver is not loaded
ERROR: Unable to load info from any available system
root@NUS:~# dkms status
nvidia, 435.21: added
root@NUS:~# lspci -v | grep 3D
root@NUS:~# uname -r
5.4.0-42-generic
root@NUS:~# sudo lshw -C display
*-display UNCLAIMED
description: VGA compatible controller
product: GM204GL [Quadro M4000]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:03:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list
configuration: latency=0
resources: memory:f6000000-f6ffffff memory:e0000000-efffffff memory:f0000000-f1ffffff ioport:e000(size=128) memory:f7000000-f707ffff
What have done to install the driver:
root@NUS:~# ubuntu-drivers devices
== /sys/devices/pci0000:00/0000:00:02.0/0000:03:00.0 ==
modalias : pci:v000010DEd000013F1sv000010DEsd00001153bc03sc00i00
vendor : NVIDIA Corporation
model : GM204GL [Quadro M4000]
driver : nvidia-driver-390 - distro non-free
driver : nvidia-driver-415 - third-party free
driver : nvidia-driver-435 - distro non-free recommended
driver : xserver-xorg-video-nouveau - distro free builtin
root@NUS:~# sudo apt-get autoremove
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
root@NUS:~# sudo apt-get remove nvidia*
Note, selecting 'nvidia-kernel-common-418-server' for glob 'nvidia*'
Note, selecting 'nvidia-325-updates' for glob 'nvidia*'
Note, selecting 'nvidia-346-updates' for glob 'nvidia*'
Note, selecting 'nvidia-driver-binary' for glob 'nvidia*'
Note, selecting 'nvidia-331-dev' for glob 'nvidia*'
Note, selecting 'nvidia-304-updates-dev' for glob 'nvidia*'
Note, selecting 'nvidia-384-dev' for glob 'nvidia*'
Note, selecting 'nvidia-libopencl1-346-updates' for glob 'nvidia*'
Note, selecting 'nvidia-340-updates-uvm' for glob 'nvidia*'
Note, selecting 'nvidia-kernel-common' for glob 'nvidia*'
Note, selecting 'nvidia-331-updates-uvm' for glob 'nvidia*'
Note, selecting 'nvidia-cg-toolkit' for glob 'nvidia*'
Note, selecting 'nvidia-driver-libs-i386:i386' for glob 'nvidia*'
Note, selecting 'nvidia-dkms-440-server' for glob 'nvidia*'
Note, selecting 'nvidia-kernel-common-390' for glob 'nvidia*'
Note, selecting 'nvidia-kernel-common-410' for glob 'nvidia*'
Note, selecting 'nvidia-kernel-common-415' for glob 'nvidia*'
Note, selecting 'nvidia-kernel-common-418' for glob 'nvidia*'
Note, selecting 'nvidia-kernel-common-430' for glob 'nvidia*'
Note, selecting 'nvidia-kernel-common-435' for glob 'nvidia*'
Note, selecting 'nvidia-kernel-common-440' for glob 'nvidia*'
Note, selecting 'nvidia-kernel-common-450' for glob 'nvidia*'
Note, selecting 'nvidia-opencl-icd-340-updates' for glob 'nvidia*'
Note, selecting 'nvidia-384-updates' for glob 'nvidia*'
Note, selecting 'nvidia' for glob 'nvidia*'
Note, selecting 'nvidia-driver' for glob 'nvidia*'
Note, selecting 'nvidia-367-updates' for glob 'nvidia*'
Note, selecting 'nvidia-modprobe' for glob 'nvidia*'
Note, selecting 'nvidia-kernel-common-440-server' for glob 'nvidia*'
Note, selecting 'nvidia-texture-tools' for glob 'nvidia*'
Note, selecting 'nvidia-utils' for glob 'nvidia*'
Note, selecting 'nvidia-387-updates' for glob 'nvidia*'
Note, selecting 'nvidia-current-diagnostic' for glob 'nvidia*'
Note, selecting 'nvidia-legacy-340xx-vdpau-driver' for glob 'nvidia*'
Note, selecting 'nvidia-349-updates' for glob 'nvidia*'
Note, selecting 'nvidia-opencl-icd-304-updates' for glob 'nvidia*'
Note, selecting 'nvidia-310-updates' for glob 'nvidia*'
Note, selecting 'nvidia-331-updates' for glob 'nvidia*'
Note, selecting 'nvidia-352-dev' for glob 'nvidia*'
Note, selecting 'nvidia-legacy-304xx-vdpau-driver' for glob 'nvidia*'
Note, selecting 'nvidia-vdpau-driver' for glob 'nvidia*'
Note, selecting 'nvidia-346-dev' for glob 'nvidia*'
Note, selecting 'nvidia-libopencl1-331-updates' for glob 'nvidia*'
Note, selecting 'nvidia-utils-390' for glob 'nvidia*'
Note, selecting 'nvidia-smi' for glob 'nvidia*'
Note, selecting 'nvidia-opencl-icd-361-updates' for glob 'nvidia*'
Note, selecting 'nvidia-313-updates' for glob 'nvidia*'
Note, selecting 'nvidia-legacy-340xx-kernel-dkms' for glob 'nvidia*'
Note, selecting 'nvidia-334-updates' for glob 'nvidia*'
Note, selecting 'nvidia-utils-410' for glob 'nvidia*'
Note, selecting 'nvidia-utils-415' for glob 'nvidia*'
Note, selecting 'nvidia-utils-418' for glob 'nvidia*'
Note, selecting 'nvidia-utils-430' for glob 'nvidia*'
Note, selecting 'nvidia-utils-435' for glob 'nvidia*'
Note, selecting 'nvidia-utils-440' for glob 'nvidia*'
Note, selecting 'nvidia-utils-450' for glob 'nvidia*'
Note, selecting 'nvidia-331-uvm' for glob 'nvidia*'
Note, selecting 'nvidia-prime' for glob 'nvidia*'
Note, selecting 'nvidia-dkms-390' for glob 'nvidia*'
Note, selecting 'nvidia-kernel-dkms' for glob 'nvidia*'
Note, selecting 'nvidia-dkms-410' for glob 'nvidia*'
Note, selecting 'nvidia-dkms-415' for glob 'nvidia*'
Note, selecting 'nvidia-dkms-418' for glob 'nvidia*'
Note, selecting 'nvidia-dkms-430' for glob 'nvidia*'
Note, selecting 'nvidia-dkms-435' for glob 'nvidia*'
Note, selecting 'nvidia-dkms-440' for glob 'nvidia*'
Note, selecting 'nvidia-dkms-450' for glob 'nvidia*'
Note, selecting 'nvidia-current-updates' for glob 'nvidia*'
Note, selecting 'nvidia-340-dev' for glob 'nvidia*'
Note, selecting 'nvidia-nsight' for glob 'nvidia*'
Note, selecting 'nvidia-common' for glob 'nvidia*'
Note, selecting 'nvidia-opencl-icd-346-updates' for glob 'nvidia*'
Note, selecting 'nvidia-352-updates' for glob 'nvidia*'
Note, selecting 'nvidia-headless-no-dkms-390' for glob 'nvidia*'
Note, selecting 'nvidia-headless-no-dkms-410' for glob 'nvidia*'
Note, selecting 'nvidia-headless-no-dkms-415' for glob 'nvidia*'
Note, selecting 'nvidia-headless-no-dkms-418' for glob 'nvidia*'
Note, selecting 'nvidia-headless-no-dkms-430' for glob 'nvidia*'
Note, selecting 'nvidia-headless-no-dkms-435' for glob 'nvidia*'
Note, selecting 'nvidia-headless-no-dkms-440' for glob 'nvidia*'
Note, selecting 'nvidia-headless-no-dkms-450' for glob 'nvidia*'
Note, selecting 'nvidia-current-dev' for glob 'nvidia*'
Note, selecting 'nvidia-libopencl1-352-updates' for glob 'nvidia*'
Note, selecting 'nvidia-compute-utils-390' for glob 'nvidia*'
Note, selecting 'nvidia-compute-utils-410' for glob 'nvidia*'
Note, selecting 'nvidia-compute-utils-415' for glob 'nvidia*'
Note, selecting 'nvidia-compute-utils-418' for glob 'nvidia*'
Note, selecting 'nvidia-compute-utils-430' for glob 'nvidia*'
Note, selecting 'nvidia-compute-utils-435' for glob 'nvidia*'
Note, selecting 'nvidia-compute-utils-440' for glob 'nvidia*'
Note, selecting 'nvidia-compute-utils-450' for glob 'nvidia*'
Note, selecting 'nvidia-355-updates' for glob 'nvidia*'
Note, selecting 'nvidia-driver-libs-nonglvnd' for glob 'nvidia*'
Note, selecting 'nvidia-375-dev' for glob 'nvidia*'
Note, selecting 'nvidia-current' for glob 'nvidia*'
Note, selecting 'nvidia-profiler' for glob 'nvidia*'
Note, selecting 'nvidia-375-updates' for glob 'nvidia*'
Note, selecting 'nvidia-driver-390' for glob 'nvidia*'
Note, selecting 'nvidia-337-updates' for glob 'nvidia*'
Note, selecting 'nvidia-358-updates' for glob 'nvidia*'
Note, selecting 'nvidia-367-dev' for glob 'nvidia*'
Note, selecting 'nvidia-driver-410' for glob 'nvidia*'
Note, selecting 'nvidia-driver-415' for glob 'nvidia*'
Note, selecting 'nvidia-driver-418' for glob 'nvidia*'
Note, selecting 'nvidia-driver-430' for glob 'nvidia*'
Note, selecting 'nvidia-driver-435' for glob 'nvidia*'
Note, selecting 'nvidia-driver-440' for glob 'nvidia*'
Note, selecting 'nvidia-driver-450' for glob 'nvidia*'
Note, selecting 'nvidia-cuda-toolkit' for glob 'nvidia*'
Note, selecting 'nvidia-legacy-304xx-driver' for glob 'nvidia*'
Note, selecting 'nvidia-driver-libs' for glob 'nvidia*'
Note, selecting 'nvidia-kernel-source' for glob 'nvidia*'
Note, selecting 'nvidia-378-updates' for glob 'nvidia*'
Note, selecting 'nvidia-340-updates-dev' for glob 'nvidia*'
Note, selecting 'nvidia-319-updates' for glob 'nvidia*'
Note, selecting 'nvidia-304-dev' for glob 'nvidia*'
Note, selecting 'nvidia-331-updates-dev' for glob 'nvidia*'
Note, selecting 'nvidia-visual-profiler' for glob 'nvidia*'
Note, selecting 'nvidia-persistenced' for glob 'nvidia*'
Note, selecting 'nvidia-361-dev' for glob 'nvidia*'
Note, selecting 'nvidia-settings-binary' for glob 'nvidia*'
Note, selecting 'nvidia-361-updates-dev' for glob 'nvidia*'
Note, selecting 'nvidia-libopencl1-304' for glob 'nvidia*'
Note, selecting 'nvidia-libopencl1-331' for glob 'nvidia*'
Note, selecting 'nvidia-libopencl1-340' for glob 'nvidia*'
Note, selecting 'nvidia-libopencl1-346' for glob 'nvidia*'
Note, selecting 'nvidia-libopencl1-352' for glob 'nvidia*'
Note, selecting 'nvidia-libopencl1-361' for glob 'nvidia*'
Note, selecting 'nvidia-libopencl1-367' for glob 'nvidia*'
Note, selecting 'nvidia-libopencl1-375' for glob 'nvidia*'
Note, selecting 'nvidia-libopencl1-384' for glob 'nvidia*'
Note, selecting 'nvidia-352-updates-dev' for glob 'nvidia*'
Note, selecting 'nvidia-opencl-icd-331-updates' for glob 'nvidia*'
Note, selecting 'nvidia-opencl-icd-352-updates' for glob 'nvidia*'
Note, selecting 'nvidia-304-updates' for glob 'nvidia*'
Note, selecting 'nvidia-340-uvm' for glob 'nvidia*'
Note, selecting 'nvidia-headless-390' for glob 'nvidia*'
Note, selecting 'nvidia-legacy-340xx-driver' for glob 'nvidia*'
Note, selecting 'nvidia-libopencl1-304-updates' for glob 'nvidia*'
Note, selecting 'nvidia-headless-410' for glob 'nvidia*'
Note, selecting 'nvidia-headless-415' for glob 'nvidia*'
Note, selecting 'nvidia-headless-418' for glob 'nvidia*'
Note, selecting 'nvidia-headless-430' for glob 'nvidia*'
Note, selecting 'nvidia-headless-435' for glob 'nvidia*'
Note, selecting 'nvidia-headless-440' for glob 'nvidia*'
Note, selecting 'nvidia-headless-450' for glob 'nvidia*'
Note, selecting 'nvidia-cuda-dev' for glob 'nvidia*'
Note, selecting 'nvidia-cuda-doc' for glob 'nvidia*'
Note, selecting 'nvidia-340-updates' for glob 'nvidia*'
Note, selecting 'nvidia-361-updates' for glob 'nvidia*'
Note, selecting 'nvidia-libopencl1-dev' for glob 'nvidia*'
Note, selecting 'nvidia-opencl-dev' for glob 'nvidia*'
Note, selecting 'nvidia-legacy-304xx-kernel-dkms' for glob 'nvidia*'
Note, selecting 'nvidia-cg-dev' for glob 'nvidia*'
Note, selecting 'nvidia-dkms-418-server' for glob 'nvidia*'
Note, selecting 'nvidia-cg-doc' for glob 'nvidia*'
Note, selecting 'nvidia-libopencl1' for glob 'nvidia*'
Note, selecting 'nvidia-libopencl1-340-updates' for glob 'nvidia*'
Note, selecting 'nvidia-libopencl1-361-updates' for glob 'nvidia*'
Note, selecting 'nvidia-381-updates' for glob 'nvidia*'
Note, selecting 'nvidia-opencl-icd-304' for glob 'nvidia*'
Note, selecting 'nvidia-opencl-icd-331' for glob 'nvidia*'
Note, selecting 'nvidia-opencl-icd-340' for glob 'nvidia*'
Note, selecting 'nvidia-opencl-icd-346' for glob 'nvidia*'
Note, selecting 'nvidia-opencl-icd-352' for glob 'nvidia*'
Note, selecting 'nvidia-opencl-icd-361' for glob 'nvidia*'
Note, selecting 'nvidia-opencl-icd-367' for glob 'nvidia*'
Note, selecting 'nvidia-opencl-icd-375' for glob 'nvidia*'
Note, selecting 'nvidia-cuda-gdb' for glob 'nvidia*'
Note, selecting 'nvidia-experimental-304' for glob 'nvidia*'
Note, selecting 'nvidia-opencl-icd-384' for glob 'nvidia*'
Note, selecting 'nvidia-experimental-310' for glob 'nvidia*'
Note, selecting 'nvidia-experimental-313' for glob 'nvidia*'
Note, selecting 'nvidia-experimental-319' for glob 'nvidia*'
Note, selecting 'nvidia-experimental-325' for glob 'nvidia*'
Note, selecting 'nvidia-experimental-331' for glob 'nvidia*'
Note, selecting 'nvidia-experimental-334' for glob 'nvidia*'
Note, selecting 'nvidia-experimental-337' for glob 'nvidia*'
Note, selecting 'nvidia-experimental-340' for glob 'nvidia*'
Note, selecting 'nvidia-experimental-343' for glob 'nvidia*'
Note, selecting 'nvidia-experimental-346' for glob 'nvidia*'
Note, selecting 'nvidia-experimental-349' for glob 'nvidia*'
Note, selecting 'nvidia-experimental-352' for glob 'nvidia*'
Note, selecting 'nvidia-experimental-355' for glob 'nvidia*'
Note, selecting 'nvidia-experimental-358' for glob 'nvidia*'
Note, selecting 'nvidia-experimental-361' for glob 'nvidia*'
Note, selecting 'nvidia-experimental-364' for glob 'nvidia*'
Note, selecting 'nvidia-experimental-367' for glob 'nvidia*'
Note, selecting 'nvidia-experimental-375' for glob 'nvidia*'
Note, selecting 'nvidia-experimental-378' for glob 'nvidia*'
Note, selecting 'nvidia-experimental-381' for glob 'nvidia*'
Note, selecting 'nvidia-experimental-384' for glob 'nvidia*'
Note, selecting 'nvidia-experimental-387' for glob 'nvidia*'
Note, selecting 'nvidia-343-updates' for glob 'nvidia*'
Note, selecting 'nvidia-364-updates' for glob 'nvidia*'
Note, selecting 'nvidia-304' for glob 'nvidia*'
Note, selecting 'nvidia-310' for glob 'nvidia*'
Note, selecting 'nvidia-313' for glob 'nvidia*'
Note, selecting 'nvidia-319' for glob 'nvidia*'
Note, selecting 'nvidia-325' for glob 'nvidia*'
Note, selecting 'nvidia-331' for glob 'nvidia*'
Note, selecting 'nvidia-334' for glob 'nvidia*'
Note, selecting 'nvidia-337' for glob 'nvidia*'
Note, selecting 'nvidia-340' for glob 'nvidia*'
Note, selecting 'nvidia-343' for glob 'nvidia*'
Note, selecting 'nvidia-346' for glob 'nvidia*'
Note, selecting 'nvidia-349' for glob 'nvidia*'
Note, selecting 'nvidia-352' for glob 'nvidia*'
Note, selecting 'nvidia-355' for glob 'nvidia*'
Note, selecting 'nvidia-358' for glob 'nvidia*'
Note, selecting 'nvidia-kernel-source-390' for glob 'nvidia*'
Note, selecting 'nvidia-361' for glob 'nvidia*'
Note, selecting 'nvidia-364' for glob 'nvidia*'
Note, selecting 'nvidia-367' for glob 'nvidia*'
Note, selecting 'nvidia-375' for glob 'nvidia*'
Note, selecting 'nvidia-378' for glob 'nvidia*'
Note, selecting 'nvidia-381' for glob 'nvidia*'
Note, selecting 'nvidia-384' for glob 'nvidia*'
Note, selecting 'nvidia-387' for glob 'nvidia*'
Note, selecting 'nvidia-dkms-kernel' for glob 'nvidia*'
Note, selecting 'nvidia-390' for glob 'nvidia*'
Note, selecting 'nvidia-kernel-source-410' for glob 'nvidia*'
Note, selecting 'nvidia-kernel-source-415' for glob 'nvidia*'
Note, selecting 'nvidia-kernel-source-418' for glob 'nvidia*'
Note, selecting 'nvidia-346-updates-dev' for glob 'nvidia*'
Note, selecting 'nvidia-kernel-source-430' for glob 'nvidia*'
Note, selecting 'nvidia-kernel-source-435' for glob 'nvidia*'
Note, selecting 'nvidia-kernel-source-440' for glob 'nvidia*'
Note, selecting 'nvidia-kernel-source-450' for glob 'nvidia*'
Note, selecting 'nvidia-settings' for glob 'nvidia*'
Note, selecting 'nvidia-opencl-icd' for glob 'nvidia*'
Note, selecting 'nvidia-settings' instead of 'nvidia-settings-binary'
Package 'nvidia-libopencl1-dev' is not installed, so not removed
Package 'nvidia-libopencl1' is not installed, so not removed
Package 'nvidia-vdpau-driver' is not installed, so not removed
Package 'nvidia-legacy-340xx-vdpau-driver' is not installed, so not removed
Package 'nvidia-390' is not installed, so not removed
Package 'nvidia-driver' is not installed, so not removed
Package 'nvidia-legacy-340xx-driver' is not installed, so not removed
Package 'nvidia-legacy-304xx-driver' is not installed, so not removed
Package 'nvidia-kernel-dkms' is not installed, so not removed
Package 'nvidia-legacy-340xx-kernel-dkms' is not installed, so not removed
Package 'nvidia-legacy-304xx-kernel-dkms' is not installed, so not removed
Package 'nvidia' is not installed, so not removed
Package 'nvidia-current-updates' is not installed, so not removed
Package 'nvidia-experimental-304' is not installed, so not removed
Package 'nvidia-310' is not installed, so not removed
Package 'nvidia-310-updates' is not installed, so not removed
Package 'nvidia-experimental-310' is not installed, so not removed
Package 'nvidia-313' is not installed, so not removed
Package 'nvidia-313-updates' is not installed, so not removed
Package 'nvidia-experimental-313' is not installed, so not removed
Package 'nvidia-319' is not installed, so not removed
Package 'nvidia-319-updates' is not installed, so not removed
Package 'nvidia-experimental-319' is not installed, so not removed
Package 'nvidia-325' is not installed, so not removed
Package 'nvidia-325-updates' is not installed, so not removed
Package 'nvidia-experimental-325' is not installed, so not removed
Package 'nvidia-experimental-331' is not installed, so not removed
Package 'nvidia-334' is not installed, so not removed
Package 'nvidia-334-updates' is not installed, so not removed
Package 'nvidia-experimental-334' is not installed, so not removed
Package 'nvidia-337' is not installed, so not removed
Package 'nvidia-337-updates' is not installed, so not removed
Package 'nvidia-experimental-337' is not installed, so not removed
Package 'nvidia-experimental-340' is not installed, so not removed
Package 'nvidia-343' is not installed, so not removed
Package 'nvidia-343-updates' is not installed, so not removed
Package 'nvidia-experimental-343' is not installed, so not removed
Package 'nvidia-experimental-346' is not installed, so not removed
Package 'nvidia-349' is not installed, so not removed
Package 'nvidia-349-updates' is not installed, so not removed
Package 'nvidia-experimental-349' is not installed, so not removed
Package 'nvidia-experimental-352' is not installed, so not removed
Package 'nvidia-355' is not installed, so not removed
Package 'nvidia-355-updates' is not installed, so not removed
Package 'nvidia-experimental-355' is not installed, so not removed
Package 'nvidia-358' is not installed, so not removed
Package 'nvidia-358-updates' is not installed, so not removed
Package 'nvidia-experimental-358' is not installed, so not removed
Package 'nvidia-experimental-361' is not installed, so not removed
Package 'nvidia-364' is not installed, so not removed
Package 'nvidia-364-updates' is not installed, so not removed
Package 'nvidia-experimental-364' is not installed, so not removed
Package 'nvidia-367-updates' is not installed, so not removed
Package 'nvidia-experimental-367' is not installed, so not removed
Package 'nvidia-375-updates' is not installed, so not removed
Package 'nvidia-experimental-375' is not installed, so not removed
Package 'nvidia-378' is not installed, so not removed
Package 'nvidia-378-updates' is not installed, so not removed
Package 'nvidia-experimental-378' is not installed, so not removed
Package 'nvidia-381' is not installed, so not removed
Package 'nvidia-381-updates' is not installed, so not removed
Package 'nvidia-experimental-381' is not installed, so not removed
Package 'nvidia-384-updates' is not installed, so not removed
Package 'nvidia-experimental-384' is not installed, so not removed
Package 'nvidia-387' is not installed, so not removed
Package 'nvidia-387-updates' is not installed, so not removed
Package 'nvidia-experimental-387' is not installed, so not removed
Note, selecting 'libnvtt-bin' instead of 'nvidia-texture-tools'
Package 'nvidia-driver-libs' is not installed, so not removed
Package 'nvidia-driver-libs-nonglvnd' is not installed, so not removed
Package 'nvidia-driver-libs-i386:i386' is not installed, so not removed
Package 'nvidia-kernel-common-418-server' is not installed, so not removed
Package 'nvidia-kernel-common-440-server' is not installed, so not removed
Package 'nvidia-legacy-304xx-vdpau-driver' is not installed, so not removed
Package 'nvidia-340-updates-uvm' is not installed, so not removed
Package 'nvidia-346' is not installed, so not removed
Package 'nvidia-346-dev' is not installed, so not removed
Package 'nvidia-346-updates' is not installed, so not removed
Package 'nvidia-346-updates-dev' is not installed, so not removed
Package 'nvidia-352' is not installed, so not removed
Package 'nvidia-352-dev' is not installed, so not removed
Package 'nvidia-352-updates' is not installed, so not removed
Package 'nvidia-352-updates-dev' is not installed, so not removed
Package 'nvidia-361' is not installed, so not removed
Package 'nvidia-361-dev' is not installed, so not removed
Package 'nvidia-361-updates' is not installed, so not removed
Package 'nvidia-361-updates-dev' is not installed, so not removed
Package 'nvidia-367' is not installed, so not removed
Package 'nvidia-367-dev' is not installed, so not removed
Package 'nvidia-375' is not installed, so not removed
Package 'nvidia-375-dev' is not installed, so not removed
Package 'nvidia-cg-dev' is not installed, so not removed
Package 'nvidia-cg-doc' is not installed, so not removed
Package 'nvidia-cg-toolkit' is not installed, so not removed
Package 'nvidia-cuda-dev' is not installed, so not removed
Package 'nvidia-cuda-doc' is not installed, so not removed
Package 'nvidia-cuda-gdb' is not installed, so not removed
Package 'nvidia-cuda-toolkit' is not installed, so not removed
Package 'nvidia-libopencl1-346' is not installed, so not removed
Package 'nvidia-libopencl1-346-updates' is not installed, so not removed
Package 'nvidia-libopencl1-352' is not installed, so not removed
Package 'nvidia-libopencl1-352-updates' is not installed, so not removed
Package 'nvidia-libopencl1-361' is not installed, so not removed
Package 'nvidia-libopencl1-361-updates' is not installed, so not removed
Package 'nvidia-libopencl1-367' is not installed, so not removed
Package 'nvidia-libopencl1-375' is not installed, so not removed
Package 'nvidia-nsight' is not installed, so not removed
Package 'nvidia-opencl-dev' is not installed, so not removed
Package 'nvidia-opencl-icd-346' is not installed, so not removed
Package 'nvidia-opencl-icd-346-updates' is not installed, so not removed
Package 'nvidia-opencl-icd-352' is not installed, so not removed
Package 'nvidia-opencl-icd-352-updates' is not installed, so not removed
Package 'nvidia-opencl-icd-361' is not installed, so not removed
Package 'nvidia-opencl-icd-361-updates' is not installed, so not removed
Package 'nvidia-opencl-icd-367' is not installed, so not removed
Package 'nvidia-opencl-icd-375' is not installed, so not removed
Package 'nvidia-profiler' is not installed, so not removed
Package 'nvidia-visual-profiler' is not installed, so not removed
Package 'nvidia-331' is not installed, so not removed
Package 'nvidia-331-dev' is not installed, so not removed
Package 'nvidia-331-updates' is not installed, so not removed
Package 'nvidia-331-updates-dev' is not installed, so not removed
Package 'nvidia-331-updates-uvm' is not installed, so not removed
Package 'nvidia-331-uvm' is not installed, so not removed
Package 'nvidia-340' is not installed, so not removed
Package 'nvidia-340-dev' is not installed, so not removed
Package 'nvidia-340-updates' is not installed, so not removed
Package 'nvidia-340-updates-dev' is not installed, so not removed
Package 'nvidia-340-uvm' is not installed, so not removed
Package 'nvidia-compute-utils-390' is not installed, so not removed
Package 'nvidia-compute-utils-430' is not installed, so not removed
Package 'nvidia-compute-utils-440' is not installed, so not removed
Package 'nvidia-dkms-390' is not installed, so not removed
Package 'nvidia-dkms-430' is not installed, so not removed
Package 'nvidia-dkms-440' is not installed, so not removed
Package 'nvidia-driver-390' is not installed, so not removed
Package 'nvidia-driver-430' is not installed, so not removed
Package 'nvidia-driver-440' is not installed, so not removed
Package 'nvidia-headless-390' is not installed, so not removed
Package 'nvidia-headless-430' is not installed, so not removed
Package 'nvidia-headless-435' is not installed, so not removed
Package 'nvidia-headless-440' is not installed, so not removed
Package 'nvidia-headless-no-dkms-390' is not installed, so not removed
Package 'nvidia-headless-no-dkms-430' is not installed, so not removed
Package 'nvidia-headless-no-dkms-435' is not installed, so not removed
Package 'nvidia-headless-no-dkms-440' is not installed, so not removed
Package 'nvidia-kernel-common-390' is not installed, so not removed
Package 'nvidia-kernel-common-430' is not installed, so not removed
Package 'nvidia-kernel-common-440' is not installed, so not removed
Package 'nvidia-kernel-source-390' is not installed, so not removed
Package 'nvidia-kernel-source-430' is not installed, so not removed
Package 'nvidia-kernel-source-440' is not installed, so not removed
Package 'nvidia-opencl-icd-340' is not installed, so not removed
Package 'nvidia-utils-390' is not installed, so not removed
Package 'nvidia-utils-430' is not installed, so not removed
Package 'nvidia-utils-440' is not installed, so not removed
Package 'nvidia-common' is not installed, so not removed
Package 'nvidia-libopencl1-331' is not installed, so not removed
Package 'nvidia-libopencl1-331-updates' is not installed, so not removed
Package 'nvidia-libopencl1-340' is not installed, so not removed
Package 'nvidia-libopencl1-340-updates' is not installed, so not removed
Package 'nvidia-opencl-icd-331' is not installed, so not removed
Package 'nvidia-opencl-icd-331-updates' is not installed, so not removed
Package 'nvidia-opencl-icd-340-updates' is not installed, so not removed
Package 'nvidia-compute-utils-410' is not installed, so not removed
Package 'nvidia-dkms-410' is not installed, so not removed
Package 'nvidia-driver-410' is not installed, so not removed
Package 'nvidia-headless-410' is not installed, so not removed
Package 'nvidia-headless-no-dkms-410' is not installed, so not removed
Package 'nvidia-kernel-common-410' is not installed, so not removed
Package 'nvidia-kernel-source-410' is not installed, so not removed
Package 'nvidia-utils-410' is not installed, so not removed
Package 'nvidia-384' is not installed, so not removed
Package 'nvidia-384-dev' is not installed, so not removed
Package 'nvidia-libopencl1-384' is not installed, so not removed
Package 'nvidia-opencl-icd-384' is not installed, so not removed
Package 'nvidia-modprobe' is not installed, so not removed
Package 'nvidia-304' is not installed, so not removed
Package 'nvidia-304-dev' is not installed, so not removed
Package 'nvidia-304-updates' is not installed, so not removed
Package 'nvidia-304-updates-dev' is not installed, so not removed
Package 'nvidia-compute-utils-415' is not installed, so not removed
Package 'nvidia-compute-utils-418' is not installed, so not removed
Package 'nvidia-compute-utils-450' is not installed, so not removed
Package 'nvidia-current' is not installed, so not removed
Package 'nvidia-current-dev' is not installed, so not removed
Package 'nvidia-dkms-415' is not installed, so not removed
Package 'nvidia-dkms-418' is not installed, so not removed
Package 'nvidia-dkms-450' is not installed, so not removed
Package 'nvidia-driver-415' is not installed, so not removed
Package 'nvidia-driver-418' is not installed, so not removed
Package 'nvidia-driver-450' is not installed, so not removed
Package 'nvidia-headless-415' is not installed, so not removed
Package 'nvidia-headless-418' is not installed, so not removed
Package 'nvidia-headless-450' is not installed, so not removed
Package 'nvidia-headless-no-dkms-415' is not installed, so not removed
Package 'nvidia-headless-no-dkms-418' is not installed, so not removed
Package 'nvidia-headless-no-dkms-450' is not installed, so not removed
Package 'nvidia-kernel-common-415' is not installed, so not removed
Package 'nvidia-kernel-common-418' is not installed, so not removed
Package 'nvidia-kernel-common-450' is not installed, so not removed
Package 'nvidia-kernel-source-415' is not installed, so not removed
Package 'nvidia-kernel-source-418' is not installed, so not removed
Package 'nvidia-kernel-source-450' is not installed, so not removed
Package 'nvidia-libopencl1-304' is not installed, so not removed
Package 'nvidia-libopencl1-304-updates' is not installed, so not removed
Package 'nvidia-opencl-icd-304' is not installed, so not removed
Package 'nvidia-opencl-icd-304-updates' is not installed, so not removed
Package 'nvidia-utils-415' is not installed, so not removed
Package 'nvidia-utils-418' is not installed, so not removed
Package 'nvidia-utils-450' is not installed, so not removed
The following packages were automatically installed and are no longer required:
dkms libatomic1:i386 libbsd0:i386 libdrm-amdgpu1:i386 libdrm-intel1:i386
libdrm-nouveau2:i386 libdrm-radeon1:i386 libdrm2:i386 libedit2:i386
libelf1:i386 libexpat1:i386 libffi6:i386 libgl1:i386 libgl1-mesa-dri:i386
libglapi-mesa:i386 libglvnd0:i386 libglx-mesa0:i386 libglx0:i386
libllvm10:i386 libnvidia-cfg1-435 libnvidia-common-435
libnvidia-compute-435:i386 libnvidia-decode-435 libnvidia-decode-435:i386
libnvidia-encode-435 libnvidia-encode-435:i386 libnvidia-fbc1-435
libnvidia-fbc1-435:i386 libnvidia-gl-435 libnvidia-gl-435:i386
libnvidia-ifr1-435 libnvidia-ifr1-435:i386 libpciaccess0:i386
libsensors4:i386 libstdc++6:i386 libx11-6:i386 libx11-xcb1:i386 libxau6:i386
libxcb-dri2-0:i386 libxcb-dri3-0:i386 libxcb-glx0:i386 libxcb-present0:i386
libxcb-sync1:i386 libxcb1:i386 libxdamage1:i386 libxdmcp6:i386 libxext6:i386
libxfixes3:i386 libxnvctrl0 libxshmfence1:i386 libxxf86vm1:i386
screen-resolution-extra xserver-xorg-video-nvidia-435
Use 'sudo apt autoremove' to remove them.
The following packages will be REMOVED:
nvidia-compute-utils-435 nvidia-dkms-435 nvidia-driver-435
nvidia-kernel-common-435 nvidia-kernel-source-435 nvidia-prime
nvidia-settings nvidia-utils-435
0 upgraded, 0 newly installed, 8 to remove and 0 not upgraded.
After this operation, 39.5 MB disk space will be freed.
Do you want to continue? [Y/n] Y
(Reading database ... 338229 files and directories currently installed.)
Removing nvidia-driver-435 (435.21-0ubuntu0.18.04.2) ...
Removing nvidia-compute-utils-435 (435.21-0ubuntu0.18.04.2) ...
Removing nvidia-dkms-435 (435.21-0ubuntu0.18.04.2) ...
Removing all DKMS Modules
Done.
INFO:Disable nvidia
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/dell_latitude
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/put_your_quirks_here
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/lenovo_thinkpad
update-initramfs: deferring update (trigger activated)
Removing nvidia-kernel-common-435 (435.21-0ubuntu0.18.04.2) ...
Removing nvidia-kernel-source-435 (435.21-0ubuntu0.18.04.2) ...
Removing nvidia-prime (0.8.8.2) ...
Removing nvidia-settings (450.51.05-0ubuntu1) ...
Removing nvidia-utils-435 (435.21-0ubuntu0.18.04.2) ...
Processing triggers for desktop-file-utils (0.23-1ubuntu3.18.04.2) ...
Processing triggers for initramfs-tools (0.130ubuntu3.9) ...
update-initramfs: Generating /boot/initrd.img-5.4.0-42-generic
I: The initramfs will attempt to resume from /dev/sda6
I: (UUID=ac47a98c-8560-4626-8c8e-ebae77b4278d)
I: Set the RESUME variable to override this.
Processing triggers for libc-bin (2.27-3ubuntu1.2) ...
/sbin/ldconfig.real: /usr/local/cuda-10.1/targets/x86_64-linux/lib/libcudnn.so.7 is not a symbolic link
Processing triggers for man-db (2.8.3-2ubuntu0.1) ...
Processing triggers for gnome-menus (3.13.3-11ubuntu1.1) ...
Processing triggers for mime-support (3.60ubuntu1) ...
root@NUS:~# sudo apt-get purge cuda*
Note, selecting 'cuda-cusparse-cross-qnx-10-0' for glob 'cuda*'
Note, selecting 'cuda-nsight-compute-11-0' for glob 'cuda*'
Note, selecting 'cuda-nvprof-11-0' for glob 'cuda*'
Note, selecting 'cuda-npp-cross-qnx-10-0' for glob 'cuda*'
Note, selecting 'cuda-nvprune-10-0' for glob 'cuda*'
Note, selecting 'cuda-nvprune-10-1' for glob 'cuda*'
Note, selecting 'cuda-nvprune-10-2' for glob 'cuda*'
Note, selecting 'cuda-nvprune-11-0' for glob 'cuda*'
Note, selecting 'cuda-nvgraph-10-0' for glob 'cuda*'
Note, selecting 'cuda-nvgraph-10-1' for glob 'cuda*'
Note, selecting 'cuda-nvgraph-10-2' for glob 'cuda*'
Note, selecting 'cuda-cublas-dev-10-0' for glob 'cuda*'
Note, selecting 'cuda-drivers-418' for glob 'cuda*'
Note, selecting 'cuda-drivers-440' for glob 'cuda*'
Note, selecting 'cuda-drivers-450' for glob 'cuda*'
Note, selecting 'cuda-gdb-10-0' for glob 'cuda*'
Note, selecting 'cuda-gdb-10-1' for glob 'cuda*'
Note, selecting 'cuda-gdb-10-2' for glob 'cuda*'
Note, selecting 'cuda-nsight-compute--10-0' for glob 'cuda*'
Note, selecting 'cuda-gdb-11-0' for glob 'cuda*'
Note, selecting 'cuda-visual-tools-10-0' for glob 'cuda*'
Note, selecting 'cuda-visual-tools-10-1' for glob 'cuda*'
Note, selecting 'cuda-visual-tools-10-2' for glob 'cuda*'
Note, selecting 'cuda-curand-dev-10-0' for glob 'cuda*'
Note, selecting 'cuda-curand-dev-10-1' for glob 'cuda*'
Note, selecting 'cuda-curand-dev-10-2' for glob 'cuda*'
Note, selecting 'cuda-cupti-10-0' for glob 'cuda*'
Note, selecting 'cuda-cupti-10-1' for glob 'cuda*'
Note, selecting 'cuda-cupti-10-2' for glob 'cuda*'
Note, selecting 'cuda-curand-cross-qnx-10-0' for glob 'cuda*'
Note, selecting 'cuda-visual-tools-11-0' for glob 'cuda*'
Note, selecting 'cuda-libraries-dev-10-0' for glob 'cuda*'
Note, selecting 'cuda-libraries-dev-10-1' for glob 'cuda*'
Note, selecting 'cuda-libraries-dev-10-2' for glob 'cuda*'
Note, selecting 'cuda-cublas-cross-qnx-10-0' for glob 'cuda*'
Note, selecting 'cuda-cupti-11-0' for glob 'cuda*'
Note, selecting 'cuda-drivers-branch' for glob 'cuda*'
Note, selecting 'cuda-repo-ubuntu1204' for glob 'cuda*'
Note, selecting 'cuda-nvjpeg-10-0' for glob 'cuda*'
Note, selecting 'cuda-nvjpeg-10-1' for glob 'cuda*'
Note, selecting 'cuda-nvjpeg-10-2' for glob 'cuda*'
Note, selecting 'cuda-nvrtc-dev-10-0' for glob 'cuda*'
Note, selecting 'cuda-nvrtc-dev-10-1' for glob 'cuda*'
Note, selecting 'cuda-nvrtc-dev-10-2' for glob 'cuda*'
Note, selecting 'cuda-libraries-dev-11-0' for glob 'cuda*'
Note, selecting 'cuda-nvrtc-dev-11-0' for glob 'cuda*'
Note, selecting 'cuda-minimal-build-10-0' for glob 'cuda*'
Note, selecting 'cuda-minimal-build-10-1' for glob 'cuda*'
Note, selecting 'cuda-minimal-build-10-2' for glob 'cuda*'
Note, selecting 'cuda-drivers' for glob 'cuda*'
Note, selecting 'cuda-repo-ubuntu1404' for glob 'cuda*'
Note, selecting 'cuda-repo-ubuntu1410' for glob 'cuda*'
Note, selecting 'cuda-minimal-build-11-0' for glob 'cuda*'
Note, selecting 'cuda-cufft-cross-qnx-10-0' for glob 'cuda*'
Note, selecting 'cuda-repo-ubuntu1504' for glob 'cuda*'
Note, selecting 'cuda-license-7-5' for glob 'cuda*'
Note, selecting 'cuda-cupti-dev-10-2' for glob 'cuda*'
Note, selecting 'cuda-libraries-10-0' for glob 'cuda*'
Note, selecting 'cuda-libraries-10-1' for glob 'cuda*'
Note, selecting 'cuda-libraries-10-2' for glob 'cuda*'
Note, selecting 'cuda-runtime-10-0' for glob 'cuda*'
Note, selecting 'cuda-runtime-10-1' for glob 'cuda*'
Note, selecting 'cuda-runtime-10-2' for glob 'cuda*'
Note, selecting 'cuda-cusolver-10-0' for glob 'cuda*'
Note, selecting 'cuda-cusolver-10-1' for glob 'cuda*'
Note, selecting 'cuda-cusolver-10-2' for glob 'cuda*'
Note, selecting 'cuda-cupti-dev-11-0' for glob 'cuda*'
Note, selecting 'cuda-libraries-11-0' for glob 'cuda*'
Note, selecting 'cuda-repo-ubuntu1804' for glob 'cuda*'
Note, selecting 'cuda-runtime-11-0' for glob 'cuda*'
Note, selecting 'cuda-drivers-diagnostic' for glob 'cuda*'
Note, selecting 'cuda-cusparse-dev-10-0' for glob 'cuda*'
Note, selecting 'cuda-cusparse-dev-10-1' for glob 'cuda*'
Note, selecting 'cuda-cusparse-dev-10-2' for glob 'cuda*'
Note, selecting 'cuda-sanitizer-11-0' for glob 'cuda*'
Note, selecting 'cuda-nvrtc-10-0' for glob 'cuda*'
Note, selecting 'cuda-nvrtc-10-1' for glob 'cuda*'
Note, selecting 'cuda-nvrtc-10-2' for glob 'cuda*'
Note, selecting 'cuda-nvjpeg-dev-10-0' for glob 'cuda*'
Note, selecting 'cuda-nvjpeg-dev-10-1' for glob 'cuda*'
Note, selecting 'cuda-nvjpeg-dev-10-2' for glob 'cuda*'
Note, selecting 'cuda-cufft-10-0' for glob 'cuda*'
Note, selecting 'cuda-cufft-10-1' for glob 'cuda*'
Note, selecting 'cuda-cufft-10-2' for glob 'cuda*'
Note, selecting 'cuda-nsight-systems-10-1' for glob 'cuda*'
Note, selecting 'cuda-nsight-systems-10-2' for glob 'cuda*'
Note, selecting 'cuda-nvrtc-11-0' for glob 'cuda*'
Note, selecting 'cuda-cusparse-10-0' for glob 'cuda*'
Note, selecting 'cuda-cusparse-10-1' for glob 'cuda*'
Note, selecting 'cuda-cusparse-10-2' for glob 'cuda*'
Note, selecting 'cuda-nsight-systems-11-0' for glob 'cuda*'
Note, selecting 'cuda-npp-10-0' for glob 'cuda*'
Note, selecting 'cuda-npp-10-1' for glob 'cuda*'
Note, selecting 'cuda-npp-10-2' for glob 'cuda*'
Note, selecting 'cuda-tools-10-0' for glob 'cuda*'
Note, selecting 'cuda-tools-10-1' for glob 'cuda*'
Note, selecting 'cuda-tools-10-2' for glob 'cuda*'
Note, selecting 'cuda-nvtx-10-0' for glob 'cuda*'
Note, selecting 'cuda-nvtx-10-1' for glob 'cuda*'
Note, selecting 'cuda-nvtx-10-2' for glob 'cuda*'
Note, selecting 'cuda-tools-11-0' for glob 'cuda*'
Note, selecting 'cuda-nvtx-11-0' for glob 'cuda*'
Note, selecting 'cuda-cudart-10-0' for glob 'cuda*'
Note, selecting 'cuda-cudart-10-1' for glob 'cuda*'
Note, selecting 'cuda-cudart-10-2' for glob 'cuda*'
Note, selecting 'cuda-license-10-0' for glob 'cuda*'
Note, selecting 'cuda-license-10-1' for glob 'cuda*'
Note, selecting 'cuda-license-10-2' for glob 'cuda*'
Note, selecting 'cuda-nvdisasm-10-0' for glob 'cuda*'
Note, selecting 'cuda-nvdisasm-10-1' for glob 'cuda*'
Note, selecting 'cuda-nvdisasm-10-2' for glob 'cuda*'
Note, selecting 'cuda-samples-10-0' for glob 'cuda*'
Note, selecting 'cuda-samples-10-1' for glob 'cuda*'
Note, selecting 'cuda-samples-10-2' for glob 'cuda*'
Note, selecting 'cuda-documentation-10-0' for glob 'cuda*'
Note, selecting 'cuda-documentation-10-1' for glob 'cuda*'
Note, selecting 'cuda-documentation-10-2' for glob 'cuda*'
Note, selecting 'cuda-cusolver-cross-qnx-10-0' for glob 'cuda*'
Note, selecting 'cuda-cudart-11-0' for glob 'cuda*'
Note, selecting 'cuda-nvdisasm-11-0' for glob 'cuda*'
Note, selecting 'cuda-samples-11-0' for glob 'cuda*'
Note, selecting 'cuda-cross-qnx' for glob 'cuda*'
Note, selecting 'cuda-documentation-11-0' for glob 'cuda*'
Note, selecting 'cuda-compat-10-0' for glob 'cuda*'
Note, selecting 'cuda-compat-10-1' for glob 'cuda*'
Note, selecting 'cuda-compat-10-2' for glob 'cuda*'
Note, selecting 'cuda-compat-11-0' for glob 'cuda*'
Note, selecting 'cuda-nvcc-10-0' for glob 'cuda*'
Note, selecting 'cuda-nvcc-10-1' for glob 'cuda*'
Note, selecting 'cuda-nvcc-10-2' for glob 'cuda*'
Note, selecting 'cuda-repo-ubuntu1404-7-5-local' for glob 'cuda*'
Note, selecting 'cuda-nvvp-10-0' for glob 'cuda*'
Note, selecting 'cuda-nvvp-10-1' for glob 'cuda*'
Note, selecting 'cuda-nvvp-10-2' for glob 'cuda*'
Note, selecting 'cuda-cross-qnx-10-0' for glob 'cuda*'
Note, selecting 'cuda-repo-ubuntu1804-10-1-local-10.1.243-418.87.00' for glob 'cuda*'
Note, selecting 'cuda-nvcc-11-0' for glob 'cuda*'
Note, selecting 'cuda-nvvp-11-0' for glob 'cuda*'
Note, selecting 'cuda-toolkit-10-0' for glob 'cuda*'
Note, selecting 'cuda-toolkit-10-1' for glob 'cuda*'
Note, selecting 'cuda-toolkit-10-2' for glob 'cuda*'
Note, selecting 'cuda-nvgraph-dev-10-0' for glob 'cuda*'
Note, selecting 'cuda-nvgraph-dev-10-1' for glob 'cuda*'
Note, selecting 'cuda-nvgraph-dev-10-2' for glob 'cuda*'
Note, selecting 'cuda-toolkit-11-0' for glob 'cuda*'
Note, selecting 'cuda-cudart-dev-10-0' for glob 'cuda*'
Note, selecting 'cuda-cudart-dev-10-1' for glob 'cuda*'
Note, selecting 'cuda-cudart-dev-10-2' for glob 'cuda*'
Note, selecting 'cuda-nvml-dev-10-0' for glob 'cuda*'
Note, selecting 'cuda-nvml-dev-10-1' for glob 'cuda*'
Note, selecting 'cuda-nvml-dev-10-2' for glob 'cuda*'
Note, selecting 'cuda-cudart-dev-11-0' for glob 'cuda*'
Note, selecting 'cuda-nvml-dev-11-0' for glob 'cuda*'
Note, selecting 'cuda-gpu-library-advisor-10-0' for glob 'cuda*'
Note, selecting 'cuda-gpu-library-advisor-10-1' for glob 'cuda*'
Note, selecting 'cuda-cublas-10-0' for glob 'cuda*'
Note, selecting 'cuda-core-10-0' for glob 'cuda*'
Note, selecting 'cuda-core-10-1' for glob 'cuda*'
Note, selecting 'cuda-core-10-2' for glob 'cuda*'
Note, selecting 'cuda-cusolver-dev-10-0' for glob 'cuda*'
Note, selecting 'cuda-cusolver-dev-10-1' for glob 'cuda*'
Note, selecting 'cuda-cusolver-dev-10-2' for glob 'cuda*'
Note, selecting 'cuda-driver-cross-qnx-10-0' for glob 'cuda*'
Note, selecting 'cuda-sanitizer-api-10-1' for glob 'cuda*'
Note, selecting 'cuda-sanitizer-api-10-2' for glob 'cuda*'
Note, selecting 'cuda-compiler-10-0' for glob 'cuda*'
Note, selecting 'cuda-compiler-10-1' for glob 'cuda*'
Note, selecting 'cuda-compiler-10-2' for glob 'cuda*'
Note, selecting 'cuda-demo-suite-10-0' for glob 'cuda*'
Note, selecting 'cuda-demo-suite-10-1' for glob 'cuda*'
Note, selecting 'cuda-demo-suite-10-2' for glob 'cuda*'
Note, selecting 'cuda-npp-dev-10-0' for glob 'cuda*'
Note, selecting 'cuda-npp-dev-10-1' for glob 'cuda*'
Note, selecting 'cuda-npp-dev-10-2' for glob 'cuda*'
Note, selecting 'cuda-compiler-11-0' for glob 'cuda*'
Note, selecting 'cuda-demo-suite-11-0' for glob 'cuda*'
Note, selecting 'cuda-nsight-10-0' for glob 'cuda*'
Note, selecting 'cuda-nsight-10-1' for glob 'cuda*'
Note, selecting 'cuda-nsight-10-2' for glob 'cuda*'
Note, selecting 'cuda-curand-10-0' for glob 'cuda*'
Note, selecting 'cuda-curand-10-1' for glob 'cuda*'
Note, selecting 'cuda-curand-10-2' for glob 'cuda*'
Note, selecting 'cuda-command-line-tools-10-0' for glob 'cuda*'
Note, selecting 'cuda-command-line-tools-10-1' for glob 'cuda*'
Note, selecting 'cuda-command-line-tools-10-2' for glob 'cuda*'
Note, selecting 'cuda-cufft-dev-10-0' for glob 'cuda*'
Note, selecting 'cuda-cufft-dev-10-1' for glob 'cuda*'
Note, selecting 'cuda-cufft-dev-10-2' for glob 'cuda*'
Note, selecting 'cuda-nsight-11-0' for glob 'cuda*'
Note, selecting 'cuda-driver-dev-10-0' for glob 'cuda*'
Note, selecting 'cuda-driver-dev-10-1' for glob 'cuda*'
Note, selecting 'cuda-driver-dev-10-2' for glob 'cuda*'
Note, selecting 'cuda-repo-ubuntu1504-7-5-local' for glob 'cuda*'
Note, selecting 'cuda-10-0' for glob 'cuda*'
Note, selecting 'cuda-10-1' for glob 'cuda*'
Note, selecting 'cuda-10-2' for glob 'cuda*'
Note, selecting 'cuda-command-line-tools-11-0' for glob 'cuda*'
Note, selecting 'cuda-driver-dev-11-0' for glob 'cuda*'
Note, selecting 'cuda-misc-headers-cross-qnx-10-0' for glob 'cuda*'
Note, selecting 'cuda-11-0' for glob 'cuda*'
Note, selecting 'cuda-memcheck-10-0' for glob 'cuda*'
Note, selecting 'cuda-memcheck-10-1' for glob 'cuda*'
Note, selecting 'cuda-memcheck-10-2' for glob 'cuda*'
Note, selecting 'cuda' for glob 'cuda*'
Note, selecting 'cuda-memcheck-11-0' for glob 'cuda*'
Note, selecting 'cuda-cudart-cross-qnx-10-0' for glob 'cuda*'
Note, selecting 'cuda-gdb-src-10-0' for glob 'cuda*'
Note, selecting 'cuda-gdb-src-10-1' for glob 'cuda*'
Note, selecting 'cuda-gdb-src-10-2' for glob 'cuda*'
Note, selecting 'cuda-misc-headers-10-0' for glob 'cuda*'
Note, selecting 'cuda-misc-headers-10-1' for glob 'cuda*'
Note, selecting 'cuda-misc-headers-10-2' for glob 'cuda*'
Note, selecting 'cuda-gdb-src-11-0' for glob 'cuda*'
Note, selecting 'cuda-cuobjdump-10-0' for glob 'cuda*'
Note, selecting 'cuda-cuobjdump-10-1' for glob 'cuda*'
Note, selecting 'cuda-cuobjdump-10-2' for glob 'cuda*'
Note, selecting 'cuda-cuobjdump-11-0' for glob 'cuda*'
Note, selecting 'cuda-nsight-compute-10-0' for glob 'cuda*'
Note, selecting 'cuda-nsight-compute-10-1' for glob 'cuda*'
Note, selecting 'cuda-nsight-compute-10-2' for glob 'cuda*'
Note, selecting 'cuda-nvprof-10-0' for glob 'cuda*'
Note, selecting 'cuda-nvprof-10-1' for glob 'cuda*'
Note, selecting 'cuda-nvprof-10-2' for glob 'cuda*'
Package 'cuda-license-7-5' is not installed, so not removed
Package 'cuda-repo-ubuntu1204' is not installed, so not removed
Package 'cuda-repo-ubuntu1404' is not installed, so not removed
Package 'cuda-repo-ubuntu1404-7-5-local' is not installed, so not removed
Package 'cuda-repo-ubuntu1410' is not installed, so not removed
Package 'cuda-repo-ubuntu1504' is not installed, so not removed
Package 'cuda-repo-ubuntu1504-7-5-local' is not installed, so not removed
Package 'cuda-cudart-cross-qnx-10-0' is not installed, so not removed
Package 'cuda-driver-cross-qnx-10-0' is not installed, so not removed
Package 'cuda-misc-headers-cross-qnx-10-0' is not installed, so not removed
Package 'cuda-cusolver-cross-qnx-10-0' is not installed, so not removed
Package 'cuda-cublas-cross-qnx-10-0' is not installed, so not removed
Package 'cuda-cufft-cross-qnx-10-0' is not installed, so not removed
Package 'cuda-curand-cross-qnx-10-0' is not installed, so not removed
Package 'cuda-cusparse-cross-qnx-10-0' is not installed, so not removed
Package 'cuda-npp-cross-qnx-10-0' is not installed, so not removed
Package 'cuda-10-0' is not installed, so not removed
Package 'cuda-10-1' is not installed, so not removed
Package 'cuda-10-2' is not installed, so not removed
Package 'cuda-command-line-tools-10-0' is not installed, so not removed
Package 'cuda-command-line-tools-10-2' is not installed, so not removed
Package 'cuda-compat-10-0' is not installed, so not removed
Package 'cuda-compiler-10-0' is not installed, so not removed
Package 'cuda-compiler-10-2' is not installed, so not removed
Package 'cuda-core-10-0' is not installed, so not removed
Package 'cuda-core-10-1' is not installed, so not removed
Package 'cuda-core-10-2' is not installed, so not removed
Package 'cuda-cross-qnx-10-0' is not installed, so not removed
Package 'cuda-cross-qnx' is not installed, so not removed
Package 'cuda-cublas-10-0' is not installed, so not removed
Package 'cuda-cublas-dev-10-0' is not installed, so not removed
Package 'cuda-cudart-10-0' is not installed, so not removed
Package 'cuda-cudart-10-2' is not installed, so not removed
Package 'cuda-cudart-dev-10-0' is not installed, so not removed
Package 'cuda-cudart-dev-10-2' is not installed, so not removed
Package 'cuda-cufft-10-0' is not installed, so not removed
Package 'cuda-cufft-10-2' is not installed, so not removed
Package 'cuda-cufft-dev-10-0' is not installed, so not removed
Package 'cuda-cufft-dev-10-2' is not installed, so not removed
Package 'cuda-cuobjdump-10-0' is not installed, so not removed
Package 'cuda-cuobjdump-10-2' is not installed, so not removed
Package 'cuda-cupti-10-0' is not installed, so not removed
Package 'cuda-cupti-10-2' is not installed, so not removed
Package 'cuda-cupti-dev-10-2' is not installed, so not removed
Package 'cuda-curand-10-0' is not installed, so not removed
Package 'cuda-curand-10-2' is not installed, so not removed
Package 'cuda-curand-dev-10-0' is not installed, so not removed
Package 'cuda-curand-dev-10-2' is not installed, so not removed
Package 'cuda-cusolver-10-0' is not installed, so not removed
Package 'cuda-cusolver-10-2' is not installed, so not removed
Package 'cuda-cusolver-dev-10-0' is not installed, so not removed
Package 'cuda-cusolver-dev-10-2' is not installed, so not removed
Package 'cuda-cusparse-10-0' is not installed, so not removed
Package 'cuda-cusparse-10-2' is not installed, so not removed
Package 'cuda-cusparse-dev-10-0' is not installed, so not removed
Package 'cuda-cusparse-dev-10-2' is not installed, so not removed
Package 'cuda-demo-suite-10-0' is not installed, so not removed
Package 'cuda-demo-suite-10-1' is not installed, so not removed
Package 'cuda-demo-suite-10-2' is not installed, so not removed
Package 'cuda-demo-suite-11-0' is not installed, so not removed
Package 'cuda-documentation-10-0' is not installed, so not removed
Package 'cuda-documentation-10-2' is not installed, so not removed
Package 'cuda-driver-dev-10-0' is not installed, so not removed
Package 'cuda-driver-dev-10-2' is not installed, so not removed
Package 'cuda-drivers-diagnostic' is not installed, so not removed
Package 'cuda-gdb-10-0' is not installed, so not removed
Package 'cuda-gdb-10-2' is not installed, so not removed
Package 'cuda-gdb-src-10-0' is not installed, so not removed
Package 'cuda-gdb-src-10-1' is not installed, so not removed
Package 'cuda-gdb-src-10-2' is not installed, so not removed
Package 'cuda-gpu-library-advisor-10-0' is not installed, so not removed
Package 'cuda-libraries-10-0' is not installed, so not removed
Package 'cuda-libraries-10-1' is not installed, so not removed
Package 'cuda-libraries-10-2' is not installed, so not removed
Package 'cuda-libraries-dev-10-0' is not installed, so not removed
Package 'cuda-libraries-dev-10-2' is not installed, so not removed
Package 'cuda-license-10-0' is not installed, so not removed
Package 'cuda-memcheck-10-0' is not installed, so not removed
Package 'cuda-memcheck-10-2' is not installed, so not removed
Package 'cuda-minimal-build-10-0' is not installed, so not removed
Package 'cuda-minimal-build-10-1' is not installed, so not removed
Package 'cuda-minimal-build-10-2' is not installed, so not removed
Package 'cuda-misc-headers-10-0' is not installed, so not removed
Package 'cuda-misc-headers-10-2' is not installed, so not removed
Package 'cuda-npp-10-0' is not installed, so not removed
Package 'cuda-npp-10-2' is not installed, so not removed
Package 'cuda-npp-dev-10-0' is not installed, so not removed
Package 'cuda-npp-dev-10-2' is not installed, so not removed
Package 'cuda-nsight-10-0' is not installed, so not removed
Package 'cuda-nsight-10-2' is not installed, so not removed
Package 'cuda-nsight-compute--10-0' is not installed, so not removed
Package 'cuda-nsight-compute-10-0' is not installed, so not removed
Package 'cuda-nsight-compute-10-2' is not installed, so not removed
Package 'cuda-nsight-systems-10-2' is not installed, so not removed
Package 'cuda-nvcc-10-0' is not installed, so not removed
Package 'cuda-nvcc-10-2' is not installed, so not removed
Package 'cuda-nvdisasm-10-0' is not installed, so not removed
Package 'cuda-nvdisasm-10-2' is not installed, so not removed
Package 'cuda-nvgraph-10-0' is not installed, so not removed
Package 'cuda-nvgraph-10-2' is not installed, so not removed
Package 'cuda-nvgraph-dev-10-0' is not installed, so not removed
Package 'cuda-nvgraph-dev-10-2' is not installed, so not removed
Package 'cuda-nvjpeg-10-0' is not installed, so not removed
Package 'cuda-nvjpeg-10-2' is not installed, so not removed
Package 'cuda-nvjpeg-dev-10-0' is not installed, so not removed
Package 'cuda-nvjpeg-dev-10-2' is not installed, so not removed
Package 'cuda-nvml-dev-10-0' is not installed, so not removed
Package 'cuda-nvml-dev-10-2' is not installed, so not removed
Package 'cuda-nvml-dev-11-0' is not installed, so not removed
Package 'cuda-nvprof-10-0' is not installed, so not removed
Package 'cuda-nvprof-10-2' is not installed, so not removed
Package 'cuda-nvprune-10-0' is not installed, so not removed
Package 'cuda-nvprune-10-2' is not installed, so not removed
Package 'cuda-nvprune-11-0' is not installed, so not removed
Package 'cuda-nvrtc-10-0' is not installed, so not removed
Package 'cuda-nvrtc-10-2' is not installed, so not removed
Package 'cuda-nvrtc-dev-10-0' is not installed, so not removed
Package 'cuda-nvrtc-dev-10-2' is not installed, so not removed
Package 'cuda-nvtx-10-0' is not installed, so not removed
Package 'cuda-nvtx-10-2' is not installed, so not removed
Package 'cuda-nvtx-11-0' is not installed, so not removed
Package 'cuda-nvvp-10-0' is not installed, so not removed
Package 'cuda-nvvp-10-2' is not installed, so not removed
Package 'cuda-repo-ubuntu1804' is not installed, so not removed
Package 'cuda-runtime-10-0' is not installed, so not removed
Package 'cuda-runtime-10-1' is not installed, so not removed
Package 'cuda-runtime-10-2' is not installed, so not removed
Package 'cuda-samples-10-0' is not installed, so not removed
Package 'cuda-samples-10-2' is not installed, so not removed
Package 'cuda-sanitizer-api-10-2' is not installed, so not removed
Package 'cuda-toolkit-10-0' is not installed, so not removed
Package 'cuda-toolkit-10-2' is not installed, so not removed
Package 'cuda-tools-10-0' is not installed, so not removed
Package 'cuda-tools-10-2' is not installed, so not removed
Package 'cuda-visual-tools-10-0' is not installed, so not removed
Package 'cuda-visual-tools-10-2' is not installed, so not removed
Package 'cuda-compat-10-1' is not installed, so not removed
Package 'cuda-drivers-418' is not installed, so not removed
Package 'cuda-compat-10-2' is not installed, so not removed
Package 'cuda-drivers-440' is not installed, so not removed
Package 'cuda-compat-11-0' is not installed, so not removed
Package 'cuda-drivers-450' is not installed, so not removed
Package 'cuda-drivers' is not installed, so not removed
Package 'cuda-11-0' is not installed, so not removed
Package 'cuda' is not installed, so not removed
Package 'cuda-command-line-tools-11-0' is not installed, so not removed
Package 'cuda-compiler-11-0' is not installed, so not removed
Package 'cuda-cudart-11-0' is not installed, so not removed
Package 'cuda-cudart-dev-11-0' is not installed, so not removed
Package 'cuda-cuobjdump-11-0' is not installed, so not removed
Package 'cuda-cupti-11-0' is not installed, so not removed
Package 'cuda-cupti-dev-11-0' is not installed, so not removed
Package 'cuda-documentation-11-0' is not installed, so not removed
Package 'cuda-driver-dev-11-0' is not installed, so not removed
Package 'cuda-gdb-11-0' is not installed, so not removed
Package 'cuda-gdb-src-11-0' is not installed, so not removed
Package 'cuda-libraries-11-0' is not installed, so not removed
Package 'cuda-libraries-dev-11-0' is not installed, so not removed
Package 'cuda-memcheck-11-0' is not installed, so not removed
Package 'cuda-minimal-build-11-0' is not installed, so not removed
Package 'cuda-nsight-11-0' is not installed, so not removed
Package 'cuda-nsight-compute-11-0' is not installed, so not removed
Package 'cuda-nsight-systems-11-0' is not installed, so not removed
Package 'cuda-nvcc-11-0' is not installed, so not removed
Package 'cuda-nvdisasm-11-0' is not installed, so not removed
Package 'cuda-nvprof-11-0' is not installed, so not removed
Package 'cuda-nvrtc-11-0' is not installed, so not removed
Package 'cuda-nvrtc-dev-11-0' is not installed, so not removed
Package 'cuda-nvvp-11-0' is not installed, so not removed
Package 'cuda-runtime-11-0' is not installed, so not removed
Package 'cuda-samples-11-0' is not installed, so not removed
Package 'cuda-sanitizer-11-0' is not installed, so not removed
Package 'cuda-toolkit-11-0' is not installed, so not removed
Package 'cuda-tools-11-0' is not installed, so not removed
Package 'cuda-visual-tools-11-0' is not installed, so not removed
nsight-compute-2019.5.0 nsight-systems-2019.5.2 screen-resolution-extra
cuda-command-line-tools-10-1* cuda-compiler-10-1* cuda-cudart-10-1*
cuda-cudart-dev-10-1* cuda-cufft-10-1* cuda-cufft-dev-10-1*
cuda-cuobjdump-10-1* cuda-cupti-10-1* cuda-curand-10-1*
cuda-curand-dev-10-1* cuda-cusolver-10-1* cuda-cusolver-dev-10-1*
cuda-cusparse-10-1* cuda-cusparse-dev-10-1* cuda-documentation-10-1*
cuda-driver-dev-10-1* cuda-gdb-10-1* cuda-gpu-library-advisor-10-1*
cuda-libraries-dev-10-1* cuda-license-10-1* cuda-license-10-2*
cuda-memcheck-10-1* cuda-misc-headers-10-1* cuda-npp-10-1*
cuda-npp-dev-10-1* cuda-nsight-10-1* cuda-nsight-compute-10-1*
cuda-nsight-systems-10-1* cuda-nvcc-10-1* cuda-nvdisasm-10-1*
cuda-nvgraph-10-1* cuda-nvgraph-dev-10-1* cuda-nvjpeg-10-1*
cuda-nvjpeg-dev-10-1* cuda-nvml-dev-10-1* cuda-nvprof-10-1*
cuda-nvprune-10-1* cuda-nvrtc-10-1* cuda-nvrtc-dev-10-1* cuda-nvtx-10-1*
cuda-nvvp-10-1* cuda-repo-ubuntu1804-10-1-local-10.1.243-418.87.00*
cuda-samples-10-1* cuda-sanitizer-api-10-1* cuda-toolkit-10-1*
cuda-tools-10-1* cuda-visual-tools-10-1* libcublas-dev* libcublas10*
0 upgraded, 0 newly installed, 49 to remove and 0 not upgraded.
After this operation, 5,191 MB disk space will be freed.
(Reading database ... 337730 files and directories currently installed.)
Removing cuda-toolkit-10-1 (10.1.243-1) ...
Removing cuda-tools-10-1 (10.1.243-1) ...
Removing cuda-command-line-tools-10-1 (10.1.243-1) ...
Removing cuda-compiler-10-1 (10.1.243-1) ...
Removing cuda-cupti-10-1 (10.1.243-1) ...
Removing cuda-visual-tools-10-1 (10.1.243-1) ...
Removing cuda-libraries-dev-10-1 (10.1.243-1) ...
Removing cuda-documentation-10-1 (10.1.243-1) ...
Removing cuda-samples-10-1 (10.1.243-1) ...
Removing cuda-cufft-dev-10-1 (10.1.243-1) ...
Removing cuda-cufft-10-1 (10.1.243-1) ...
Removing cuda-gdb-10-1 (10.1.243-1) ...
Removing cuda-cuobjdump-10-1 (10.1.243-1) ...
Removing cuda-curand-dev-10-1 (10.1.243-1) ...
Removing cuda-curand-10-1 (10.1.243-1) ...
Removing cuda-cusolver-dev-10-1 (10.1.243-1) ...
Removing cuda-cusolver-10-1 (10.1.243-1) ...
Removing cuda-cusparse-dev-10-1 (10.1.243-1) ...
Removing cuda-cusparse-10-1 (10.1.243-1) ...
Removing cuda-gpu-library-advisor-10-1 (10.1.243-1) ...
Removing libcublas-dev (10.2.2.89-1) ...
Removing libcublas10 (10.2.2.89-1) ...
Removing cuda-license-10-2 (10.2.89-1) ...
Removing cuda-memcheck-10-1 (10.1.243-1) ...
Removing cuda-nvcc-10-1 (10.1.243-1) ...
Removing cuda-misc-headers-10-1 (10.1.243-1) ...
Removing cuda-npp-dev-10-1 (10.1.243-1) ...
Removing cuda-npp-10-1 (10.1.243-1) ...
Removing cuda-nsight-10-1 (10.1.243-1) ...
Removing cuda-nsight-compute-10-1 (10.1.243-1) ...
Removing cuda-nsight-systems-10-1 (10.1.243-1) ...
Removing cuda-nvdisasm-10-1 (10.1.243-1) ...
Removing cuda-nvgraph-dev-10-1 (10.1.243-1) ...
Removing cuda-nvgraph-10-1 (10.1.243-1) ...
Removing cuda-nvjpeg-dev-10-1 (10.1.243-1) ...
Removing cuda-nvjpeg-10-1 (10.1.243-1) ...
Removing cuda-nvml-dev-10-1 (10.1.243-1) ...
Removing cuda-nvprof-10-1 (10.1.243-1) ...
Removing cuda-nvprune-10-1 (10.1.243-1) ...
dpkg: warning: while removing cuda-nvprune-10-1, directory '/usr/local/cuda-10.1/bin' not empty so not removed
Removing cuda-nvrtc-dev-10-1 (10.1.243-1) ...
Removing cuda-nvrtc-10-1 (10.1.243-1) ...
Removing cuda-nvtx-10-1 (10.1.243-1) ...
Removing cuda-nvvp-10-1 (10.1.243-1) ...
Removing cuda-repo-ubuntu1804-10-1-local-10.1.243-418.87.00 (1.0-1) ...
Removing cuda-sanitizer-api-10-1 (10.1.243-1) ...
Removing cuda-cudart-dev-10-1 (10.1.243-1) ...
Removing cuda-cudart-10-1 (10.1.243-1) ...
Removing cuda-driver-dev-10-1 (10.1.243-1) ...
dpkg: warning: while removing cuda-driver-dev-10-1, directory '/usr/local/cuda-10.1/targets/x86_64-linux/lib' not empty so not removed
Removing cuda-license-10-1 (10.1.243-1) ...
(Reading database ... 325627 files and directories currently installed.)
Purging configuration files for cuda-cupti-10-1 (10.1.243-1) ...
Purging configuration files for cuda-cudart-10-1 (10.1.243-1) ...
Purging configuration files for cuda-nvcc-10-1 (10.1.243-1) ...
Purging configuration files for cuda-cusolver-10-1 (10.1.243-1) ...
Purging configuration files for cuda-repo-ubuntu1804-10-1-local-10.1.243-418.87.00 (1.0-1) ...
Purging configuration files for cuda-nvtx-10-1 (10.1.243-1) ...
Purging configuration files for cuda-curand-10-1 (10.1.243-1) ...
Purging configuration files for cuda-nvgraph-10-1 (10.1.243-1) ...
Purging configuration files for cuda-cudart-dev-10-1 (10.1.243-1) ...
dpkg: warning: while removing cuda-cudart-dev-10-1, directory '/usr/local/cuda-10.1/targets/x86_64-linux/include' not empty so not removed
Purging configuration files for cuda-cusparse-10-1 (10.1.243-1) ...
Purging configuration files for cuda-nvjpeg-10-1 (10.1.243-1) ...
Purging configuration files for cuda-sanitizer-api-10-1 (10.1.243-1) ...
dpkg: warning: while removing cuda-sanitizer-api-10-1, directory '/usr/local/cuda-10.1/extras' not empty so not removed
Purging configuration files for cuda-cufft-10-1 (10.1.243-1) ...
Purging configuration files for cuda-nvprof-10-1 (10.1.243-1) ...
Purging configuration files for cuda-nvrtc-10-1 (10.1.243-1) ...
Purging configuration files for libcublas10 (10.2.2.89-1) ...
Purging configuration files for cuda-npp-10-1 (10.1.243-1) ...
Purging configuration files for cuda-visual-tools-10-1 (10.1.243-1) ...
Purging configuration files for cuda-toolkit-10-1 (10.1.243-1) ...
root@NUS:~# sudo add-apt-repository ppa:graphics-drivers/ppa
Fresh drivers from upstream, currently shipping Nvidia.
## Current Status
Current long-lived branch release: `nvidia-430` (430.40)
Dropped support for Fermi series (https://nvidia.custhelp.com/app/answers/detail/a_id/4656)
Old long-lived branch release: `nvidia-390` (390.129)
For GF1xx GPUs use `nvidia-390` (390.129)
For G8x, G9x and GT2xx GPUs use `nvidia-340` (340.107)
For NV4x and G7x GPUs use `nvidia-304` (304.137) End-Of-Life!
Support timeframes for Unix legacy GPU releases:
https://nvidia.custhelp.com/app/answers/detail/a_id/3142
## What we're working on right now:
- Normal driver updates
- Help Wanted: Mesa Updates for Intel/AMD users, ping us if you want to help do this work, we're shorthanded.
## WARNINGS:
This PPA is currently in testing, you should be experienced with packaging before you dive in here:
Volunteers welcome!
### How you can help:
## Install PTS and benchmark your gear:
sudo apt-get install phoronix-test-suite
Run the benchmark:
phoronix-test-suite default-benchmark openarena xonotic tesseract gputest unigine-valley
and then say yes when it asks you to submit your results to openbechmarking.org. Then grab a cup of coffee, it takes a bit for the benchmarks to run. Depending on the version of Ubuntu you're using it might preferable for you to grabs PTS from upstream directly: http://www.phoronix-test-suite.com/?k=downloads
## Share your results with the community:
Post a link to your results (or any other feedback to): https://launchpad.net/~graphics-drivers-testers
Remember to rerun and resubmit the benchmarks after driver upgrades, this will allow us to gather a bunch of data on performance that we can share with everybody.
If you run into old documentation referring to other PPAs, you can help us by consolidating references to this PPA.
If someone wants to go ahead and start prototyping on `software-properties-gtk` on what the GUI should look like, please start hacking!
## Help us Help You!
We use the donation funds to get the developers hardware to test and upload these drivers, please consider donating to the "community" slider on the donation page if you're loving this PPA:
http://www.ubuntu.com/download/desktop/contribute
More info: https://launchpad.net/~graphics-drivers/+archive/ubuntu/ppa
Press [ENTER] to continue or Ctrl-c to cancel adding it.
Hit:1 https://cloud.r-project.org/bin/linux/ubuntu bionic-cran35/ InRelease
Hit:2 http://sg.archive.ubuntu.com/ubuntu bionic InRelease
Hit:3 http://security.ubuntu.com/ubuntu bionic-security InRelease
Ign:4 http://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64 InRelease
Hit:5 http://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64 Release
Hit:6 http://ppa.launchpad.net/graphics-drivers/ppa/ubuntu bionic InRelease
Hit:7 http://sg.archive.ubuntu.com/ubuntu bionic-updates InRelease
Hit:8 http://security.ubuntu.com/ubuntu xenial-security InRelease
Hit:9 http://sg.archive.ubuntu.com/ubuntu bionic-backports InRelease
Hit:11 https://packagecloud.io/github/git-lfs/ubuntu bionic InRelease
Reading package lists... Done
root@NUS:~# sudo apt install nvidia-driver-435
Building dependency tree
The following additional packages will be installed:
nvidia-compute-utils-435 nvidia-dkms-435 nvidia-kernel-common-435
nvidia-kernel-source-435 nvidia-prime nvidia-settings nvidia-utils-435
The following NEW packages will be installed:
0 upgraded, 8 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/14.2 MB of archives.
After this operation, 39.5 MB of additional disk space will be used.
Selecting previously unselected package nvidia-compute-utils-435.
(Reading database ... 325621 files and directories currently installed.)
Preparing to unpack .../0-nvidia-compute-utils-435_435.21-0ubuntu0.18.04.2_amd64.deb ...
Unpacking nvidia-compute-utils-435 (435.21-0ubuntu0.18.04.2) ...
Selecting previously unselected package nvidia-kernel-source-435.
Preparing to unpack .../1-nvidia-kernel-source-435_435.21-0ubuntu0.18.04.2_amd64.deb ...
Unpacking nvidia-kernel-source-435 (435.21-0ubuntu0.18.04.2) ...
Selecting previously unselected package nvidia-kernel-common-435.
Preparing to unpack .../2-nvidia-kernel-common-435_435.21-0ubuntu0.18.04.2_amd64.deb ...
Unpacking nvidia-kernel-common-435 (435.21-0ubuntu0.18.04.2) ...
Selecting previously unselected package nvidia-dkms-435.
Preparing to unpack .../3-nvidia-dkms-435_435.21-0ubuntu0.18.04.2_amd64.deb ...
Unpacking nvidia-dkms-435 (435.21-0ubuntu0.18.04.2) ...
Selecting previously unselected package nvidia-utils-435.
Preparing to unpack .../4-nvidia-utils-435_435.21-0ubuntu0.18.04.2_amd64.deb ...
Unpacking nvidia-utils-435 (435.21-0ubuntu0.18.04.2) ...
Selecting previously unselected package nvidia-driver-435.
Preparing to unpack .../5-nvidia-driver-435_435.21-0ubuntu0.18.04.2_amd64.deb ...
Unpacking nvidia-driver-435 (435.21-0ubuntu0.18.04.2) ...
Selecting previously unselected package nvidia-prime.
Preparing to unpack .../6-nvidia-prime_0.8.8.2_all.deb ...
Unpacking nvidia-prime (0.8.8.2) ...
Selecting previously unselected package nvidia-settings.
Preparing to unpack .../7-nvidia-settings_450.51.05-0ubuntu1_amd64.deb ...
Unpacking nvidia-settings (450.51.05-0ubuntu1) ...
Setting up nvidia-compute-utils-435 (435.21-0ubuntu0.18.04.2) ...
Warning: The home dir /nonexistent you specified can't be accessed: No such file or directory
Adding system user `nvidia-persistenced' (UID 122) ...
Adding new group `nvidia-persistenced' (GID 127) ...
Adding new user `nvidia-persistenced' (UID 122) with group `nvidia-persistenced' ...
Not creating home directory `/nonexistent'.
Setting up nvidia-prime (0.8.8.2) ...
Setting up nvidia-settings (450.51.05-0ubuntu1) ...
Setting up nvidia-utils-435 (435.21-0ubuntu0.18.04.2) ...
Setting up nvidia-kernel-common-435 (435.21-0ubuntu0.18.04.2) ...
Setting up nvidia-kernel-source-435 (435.21-0ubuntu0.18.04.2) ...
Setting up nvidia-dkms-435 (435.21-0ubuntu0.18.04.2) ...
INFO:Enable nvidia
Loading new nvidia-435.21 DKMS files...
Building for 5.4.0-42-generic
Building for architecture x86_64
Building initial module for 5.4.0-42-generic
ERROR: Cannot create report: [Errno 17] File exists: '/var/crash/nvidia-dkms-435.0.crash'
Error! Bad return status for module build on kernel: 5.4.0-42-generic (x86_64)
Consult /var/lib/dkms/nvidia/435.21/build/make.log for more information.
Setting up nvidia-driver-435 (435.21-0ubuntu0.18.04.2) ...
root@NUS:~# sudo apt install --reinstall nvidia-driver-435
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
Need to get 0 B/413 kB of archives.
After this operation, 0 B of additional disk space will be used.
(Reading database ... 326120 files and directories currently installed.)
Preparing to unpack .../nvidia-driver-435_435.21-0ubuntu0.18.04.2_amd64.deb ...
Unpacking nvidia-driver-435 (435.21-0ubuntu0.18.04.2) over (435.21-0ubuntu0.18.04.2) ...
root@NUS:~# sudo dkms install nvidia/435.21 --all
root@NUS:~# dkms status
nvidia, 435.21: added
And attached my nvidia-bug-report.log
nvidia-bug-report.log.gz (103.3 KB)
BTW, I have also checked my grub file in /etc/default, these are what I have in my grub file:
# If you change this file, run 'update-grub' afterwards to update
# /boot/grub/grub.cfg.
# For full documentation of the options in this file, see:
# info -f grub -n 'Simple configuration'
GRUB_DEFAULT=0
GRUB_TIMEOUT_STYLE=hidden
GRUB_TIMEOUT=10
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
GRUB_CMDLINE_LINUX=""
# Uncomment to enable BadRAM filtering, modify to suit your needs
# This works with Linux (no patch required) and with any kernel that obtains
# the memory map information from GRUB (GNU Mach, kernel of FreeBSD ...)
#GRUB_BADRAM="0x01234567,0xfefefefe,0x89abcdef,0xefefefef"
# Uncomment to disable graphical terminal (grub-pc only)
#GRUB_TERMINAL=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `vbeinfo'
#GRUB_GFXMODE=640x480
# Uncomment if you don't want GRUB to pass "root=UUID=xxx" parameter to Linux
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entries
#GRUB_DISABLE_RECOVERY="true"
# Uncomment to get a beep at grub start
#GRUB_INIT_TUNE="480 440 1"
And I do not have a /etc/X11/xorg.conf and /etc/modprobe.d/blacklist-nvidia.conf file on my computer.
I have rebooted my computer after the reinstallation for several times already. Makes no difference.
Any help would be highly appreciated!
