Is there a good reference out there about what exactly the Xavier AGX can encode as far as video is concerned? The only spec that I can find is: “Encoder/Decoder (2x) 4Kp60 | HEVC/(2x) 4Kp60 | 12-bit support”
I’m trying to record 4x 4K 30fps cameras at the same time but am only able to process 15 frames per second reliably. I had assumed that the spec above meant that I could encode 120 4K frames per second so could have as many streams as I wanted as long as their total <= 120 fps. Am I wrong about that?
