Could you let me know the way to use two encoder (NVENC) simultaneously for single video stream on Jetson AGX Xavier?
We know one encoder can handle up to 4K60p.
But we would like to handle 8K60p and we’re wondering if 8K60p can be handled by using two encdoer simultaneously.
It is not supported. There are two hardware blocks so we can run two encoding instances. But cannot run single encoding instance in higher frame rate. So you may try 2x 4Kp60.
