535.146.02 The last of us part 1 - error c0000005 - game doesnt run at all
Please update driver to be able to run that game
side thread:
@penteljapan
Thanks for highlighting the issue to us.
I have started downloading game and will attempt for local repro which will help us to debug issue.
Can you reproduce it at local repo?
I played half life 2 (native) and game crashed. Im strongly going forward to blame AMDGPU for switching between cards. Todays crash.
Jan 06 22:27:31 Crawler-E25 kernel: ================================================================================
Jan 06 22:27:31 Crawler-E25 kernel: UBSAN: array-index-out-of-bounds in /tmp/selfgz8635/NVIDIA-Linux-x86_64-535.146.02/kernel/nvidia-uvm/uvm_pmm_gpu.c:2364:28
Jan 06 22:27:31 Crawler-E25 kernel: index 0 is out of range for type 'uvm_gpu_chunk_t *[*]'
Jan 06 22:27:31 Crawler-E25 kernel: CPU: 7 PID: 4195 Comm: d3ddriverquery6 Tainted: P           OE      6.5.0-14-generic #14-Ubuntu
Jan 06 22:27:31 Crawler-E25 kernel: Hardware name: MEDION Crawler E25/NHxxEx, BIOS 1.07.01RME1_00002 06/23/2021
Jan 06 22:27:31 Crawler-E25 kernel: Call Trace:
Jan 06 22:27:31 Crawler-E25 kernel:  <TASK>
Jan 06 22:27:31 Crawler-E25 kernel:  dump_stack_lvl+0x48/0x70
Jan 06 22:27:31 Crawler-E25 kernel:  dump_stack+0x10/0x20
Jan 06 22:27:31 Crawler-E25 kernel:  __ubsan_handle_out_of_bounds+0xc6/0x110
Jan 06 22:27:31 Crawler-E25 kernel:  split_gpu_chunk+0x13f/0x410 [nvidia_uvm]
Jan 06 22:27:31 Crawler-E25 kernel:  uvm_pmm_gpu_alloc+0x2da/0x6d0 [nvidia_uvm]
Jan 06 22:27:31 Crawler-E25 kernel:  phys_mem_allocate+0xac/0x230 [nvidia_uvm]
Jan 06 22:27:31 Crawler-E25 kernel:  allocate_directory+0xb4/0x130 [nvidia_uvm]
Jan 06 22:27:31 Crawler-E25 kernel:  ? allocate_directory+0xb4/0x130 [nvidia_uvm]
Jan 06 22:27:31 Crawler-E25 kernel:  uvm_page_tree_init+0x133/0x450 [nvidia_uvm]
Jan 06 22:27:31 Crawler-E25 kernel:  uvm_gpu_retain_by_uuid+0x19df/0x2b80 [nvidia_uvm]
Jan 06 22:27:31 Crawler-E25 kernel:  ? filemap_get_entry+0xe5/0x160
Jan 06 22:27:31 Crawler-E25 kernel:  ? try_charge_memcg+0x74c/0x7d0
Jan 06 22:27:31 Crawler-E25 kernel:  uvm_va_space_register_gpu+0x47/0x740 [nvidia_uvm]
Jan 06 22:27:31 Crawler-E25 kernel:  ? srso_alias_return_thunk+0x5/0x7f
Jan 06 22:27:31 Crawler-E25 kernel:  uvm_api_register_gpu+0x5a/0x90 [nvidia_uvm]
Jan 06 22:27:31 Crawler-E25 kernel:  uvm_ioctl+0x1a26/0x1cd0 [nvidia_uvm]
Jan 06 22:27:31 Crawler-E25 kernel:  ? __mod_lruvec_state+0x36/0x50
Jan 06 22:27:31 Crawler-E25 kernel:  ? page_add_file_rmap+0x16e/0x1d0
Jan 06 22:27:31 Crawler-E25 kernel:  ? xas_find+0x74/0x1e0
Jan 06 22:27:31 Crawler-E25 kernel:  ? _raw_spin_lock_irqsave+0xe/0x20
Jan 06 22:27:31 Crawler-E25 kernel:  ? thread_context_non_interrupt_add+0x13a/0x2c0 [nvidia_uvm]
Jan 06 22:27:31 Crawler-E25 kernel:  uvm_unlocked_ioctl_entry.part.0+0x7b/0xf0 [nvidia_uvm]
Jan 06 22:27:31 Crawler-E25 kernel:  ? __seccomp_filter+0xf1/0x570
Jan 06 22:27:31 Crawler-E25 kernel:  uvm_unlocked_ioctl_entry+0x6b/0x90 [nvidia_uvm]
Jan 06 22:27:31 Crawler-E25 kernel:  __x64_sys_ioctl+0xa3/0xf0
Jan 06 22:27:31 Crawler-E25 kernel:  do_syscall_64+0x5c/0x90
Jan 06 22:27:31 Crawler-E25 kernel:  ? handle_mm_fault+0xad/0x360
Jan 06 22:27:31 Crawler-E25 kernel:  ? do_user_addr_fault+0x238/0x6b0
Jan 06 22:27:31 Crawler-E25 kernel:  ? exit_to_user_mode_prepare+0x30/0xb0
Jan 06 22:27:31 Crawler-E25 kernel:  ? irqentry_exit_to_user_mode+0x17/0x20
Jan 06 22:27:31 Crawler-E25 kernel:  ? irqentry_exit+0x43/0x50
Jan 06 22:27:31 Crawler-E25 kernel:  ? exc_page_fault+0x94/0x1b0
Jan 06 22:27:31 Crawler-E25 kernel:  entry_SYSCALL_64_after_hwframe+0x6e/0xd8
Jan 06 22:27:31 Crawler-E25 kernel: RIP: 0033:0x7fe212f238ef
Jan 06 22:27:31 Crawler-E25 kernel: Code: 00 48 89 44 24 18 31 c0 48 8d 44 24 60 c7 04 24 10 00 00 00 48 89 44 24 08 48 8d 44 24 20 48 89 44 24 10 b8 10 00 00 00 0f 05 <89> c2 3d 00 f0 ff>
Jan 06 22:27:31 Crawler-E25 kernel: RSP: 002b:000000000021d700 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
Jan 06 22:27:31 Crawler-E25 kernel: RAX: ffffffffffffffda RBX: 00007fe1f7cff860 RCX: 00007fe212f238ef
Jan 06 22:27:31 Crawler-E25 kernel: RDX: 000000000021d7a0 RSI: 0000000000000025 RDI: 0000000000000020
Jan 06 22:27:31 Crawler-E25 kernel: RBP: 000000000021d800 R08: 00007fe1f7cff8f0 R09: 0000000000000000
Jan 06 22:27:31 Crawler-E25 kernel: R10: 00007fe212e143c0 R11: 0000000000000246 R12: 000000007edcffa6
Jan 06 22:27:31 Crawler-E25 kernel: R13: 00007fe1f7cff8f0 R14: 000000000021d7a0 R15: 0000000000000020
Jan 06 22:27:31 Crawler-E25 kernel:  </TASK>
Jan 06 22:27:31 Crawler-E25 kernel: UBSAN: array-index-out-of-bounds in /tmp/selfgz8635/NVIDIA-Linux-x86_64-535.146.02/kernel/nvidia-uvm/uvm_pmm_gpu.c:2038:44
Jan 06 22:27:31 Crawler-E25 kernel:  uvm_pmm_gpu_alloc+0x2f5/0x6d0 [nvidia_uvm]
Jan 06 22:27:31 Crawler-E25 kernel: UBSAN: array-index-out-of-bounds in /tmp/selfgz8635/NVIDIA-Linux-x86_64-535.146.02/kernel/nvidia-uvm/uvm_pmm_gpu.c:746:68
Jan 06 22:27:31 Crawler-E25 kernel:  num_subchunks+0x36/0x80 [nvidia_uvm]
Jan 06 22:27:31 Crawler-E25 kernel:  uvm_pmm_gpu_alloc+0x343/0x6d0 [nvidia_uvm]
Jan 06 22:27:27 Crawler-E25 systemd[1]: run-user-115.mount: Deactivated successfully.
Jan 06 22:27:27 Crawler-E25 systemd[1]: user-runtime-dir@115.service: Deactivated successfully.
Jan 06 22:27:27 Crawler-E25 systemd[1]: Stopped user-runtime-dir@115.service - User Runtime Directory /run/user/115.
Jan 06 22:27:27 Crawler-E25 systemd[1]: Removed slice user-115.slice - User Slice of UID 115.
Jan 06 22:27:27 Crawler-E25 systemd[1]: user-115.slice: Consumed 1.713s CPU time.
Jan 06 22:27:27 Crawler-E25 pressure-vessel-wrap[3798]: x86_64-linux-gnu-capsule-capture-libs: warning: Dependencies of libnvidia-pkcs11.so.535.146.02 not found, ignoring: Missing depende>
Jan 06 22:27:28 Crawler-E25 Discord[2751]: [2751:0106/222728.110361:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 2 times!
Jan 06 22:27:28 Crawler-E25 plasma-systemmonitor[2177]: qrc:/main.qml:25: TypeError: Cannot read property 'title' of null
Jan 06 22:27:28 Crawler-E25 plasma-systemmonitor[2177]: qrc:/main.qml:81: TypeError: Cannot read property 'edit' of null
Jan 06 22:27:28 Crawler-E25 plasma-systemmonitor[2177]: qrc:/GlobalMenu.qml:32: TypeError: Cannot read property 'edit' of null
Jan 06 22:27:28 Crawler-E25 plasma-systemmonitor[2177]: file:///usr/lib/x86_64-linux-gnu/qt5/qml/org/kde/ksysguard/page/EditablePage.qml?page=overview.page:256:5: QML Loader: Binding loop>
Jan 06 22:27:28 Crawler-E25 plasma-systemmonitor[2177]: file:///usr/lib/x86_64-linux-gnu/qt5/qml/org/kde/kirigami.2/templates/InlineMessage.qml:265:13: QML SelectableLabel: Binding loop d>
Jan 06 22:27:28 Crawler-E25 plasma-systemmonitor[2177]: file:///usr/lib/x86_64-linux-gnu/qt5/qml/org/kde/kirigami.2/private/globaltoolbar/ToolBarPageHeader.qml:80:13: QML Binding: Binding>
Jan 06 22:27:28 Crawler-E25 plasma-systemmonitor[2177]: file:///usr/lib/x86_64-linux-gnu/qt5/qml/org/kde/kirigami.2/private/globaltoolbar/ToolBarPageHeader.qml:86:13: QML Binding: Binding>
Jan 06 22:27:28 Crawler-E25 env[3047]: [3047:3047:0106/222728.891225:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 2 times!
Jan 06 22:27:29 Crawler-E25 kvirc[2162]: WARNING: receiving an invalid IRC message from server.
Jan 06 22:27:30 Crawler-E25 plasma-systemmonitor[2177]: qrc:/main.qml:25: TypeError: Cannot read property 'title' of null
Jan 06 22:27:30 Crawler-E25 plasma-systemmonitor[2177]: qrc:/main.qml:81: TypeError: Cannot read property 'edit' of null
Jan 06 22:27:30 Crawler-E25 plasma-systemmonitor[2177]: qrc:/GlobalMenu.qml:32: TypeError: Cannot read property 'edit' of null
Jan 06 22:27:30 Crawler-E25 plasma-systemmonitor[2177]: file:///usr/lib/x86_64-linux-gnu/qt5/qml/org/kde/ksysguard/page/EditablePage.qml?page=overview.page:256:5: QML Loader: Binding loop>
Jan 06 22:27:31 Crawler-E25 kernel: UBSAN: array-index-out-of-bounds in /tmp/selfgz8635/NVIDIA-Linux-x86_64-535.146.02/kernel/nvidia-uvm/uvm_pmm_gpu.c:2044:63
Jan 06 22:27:31 Crawler-E25 kernel: index 1 is out of range for type 'uvm_gpu_chunk_t *[*]'
Jan 06 22:27:31 Crawler-E25 kernel:  uvm_pmm_gpu_alloc+0x32e/0x6d0 [nvidia_uvm]
Jan 06 22:27:31 Crawler-E25 kernel: UBSAN: array-index-out-of-bounds in /tmp/selfgz8635/NVIDIA-Linux-x86_64-535.146.02/kernel/nvidia-uvm/uvm_pmm_gpu.c:2614:71
Jan 06 22:27:31 Crawler-E25 kernel: CPU: 6 PID: 4208 Comm: cuda-EvtHandlr Tainted: P           OE      6.5.0-14-generic #14-Ubuntu
Jan 06 22:27:31 Crawler-E25 kernel:  free_chunk_with_merges+0xa4/0x180 [nvidia_uvm]
Jan 06 22:27:31 Crawler-E25 kernel:  free_chunk+0xa4/0xd0 [nvidia_uvm]
Jan 06 22:27:31 Crawler-E25 kernel:  uvm_pmm_gpu_free+0xbf/0xf0 [nvidia_uvm]
Jan 06 22:27:31 Crawler-E25 kernel:  phys_mem_deallocate+0x33/0xd0 [nvidia_uvm]
Jan 06 22:27:31 Crawler-E25 kernel:  uvm_page_tree_deinit+0xbe/0x300 [nvidia_uvm]
Jan 06 22:27:31 Crawler-E25 kernel:  ? _nv037639rm+0x153/0x1d0 [nvidia]
Jan 06 22:27:31 Crawler-E25 kernel:  remove_gpu+0x260/0x610 [nvidia_uvm]
Jan 06 22:27:31 Crawler-E25 kernel:  uvm_gpu_release_locked+0x2a/0x70 [nvidia_uvm]
Jan 06 22:27:31 Crawler-E25 kernel:  uvm_va_space_destroy+0x586/0x6c0 [nvidia_uvm]
Jan 06 22:27:31 Crawler-E25 kernel:  uvm_release.isra.0+0xa5/0x140 [nvidia_uvm]
Jan 06 22:27:31 Crawler-E25 kernel:  uvm_release_entry.part.0.isra.0+0x54/0xa0 [nvidia_uvm]
Jan 06 22:27:31 Crawler-E25 kernel:  uvm_release_entry+0x2e/0x40 [nvidia_uvm]
Jan 06 22:27:31 Crawler-E25 kernel:  __fput+0xfc/0x2c0
Jan 06 22:27:31 Crawler-E25 kernel:  ____fput+0xe/0x20
Jan 06 22:27:31 Crawler-E25 kernel:  task_work_run+0x61/0xa0
Jan 06 22:27:31 Crawler-E25 kernel:  do_exit+0x55d/0x6f0
Jan 06 22:27:31 Crawler-E25 kernel:  do_group_exit+0x35/0x90
Jan 06 22:27:31 Crawler-E25 kernel:  get_signal+0x8d8/0x940
Jan 06 22:27:31 Crawler-E25 kernel:  arch_do_signal_or_restart+0x39/0x120
Jan 06 22:27:31 Crawler-E25 kernel:  exit_to_user_mode_loop+0x9a/0x130
Jan 06 22:27:31 Crawler-E25 kernel:  exit_to_user_mode_prepare+0xa5/0xb0
Jan 06 22:27:31 Crawler-E25 kernel:  syscall_exit_to_user_mode+0x29/0x60
Jan 06 22:27:31 Crawler-E25 kernel:  do_syscall_64+0x68/0x90
Jan 06 22:27:31 Crawler-E25 kernel:  ? ksys_read+0xe6/0x100
Jan 06 22:27:31 Crawler-E25 kernel:  ? syscall_exit_to_user_mode+0x37/0x60
Jan 06 22:27:31 Crawler-E25 kernel:  ? do_syscall_64+0x68/0x90
Jan 06 22:27:31 Crawler-E25 kernel:  ? exit_to_user_mode_prepare+0x9b/0xb0
Jan 06 22:27:31 Crawler-E25 kernel:  ? ret_from_fork+0x29/0x70
Jan 06 22:27:31 Crawler-E25 kernel: RIP: 0033:0x7fe212f1a18f
Jan 06 22:27:31 Crawler-E25 kernel: Code: Unable to access opcode bytes at 0x7fe212f1a165.
Jan 06 22:27:31 Crawler-E25 kernel: RSP: 002b:00007fe1fd3fed50 EFLAGS: 00000293 ORIG_RAX: 0000000000000007
Jan 06 22:27:31 Crawler-E25 kernel: RAX: fffffffffffffdfc RBX: 00000000ffffffff RCX: 00007fe212f1a18f
Jan 06 22:27:31 Crawler-E25 kernel: RDX: 00000000ffffffff RSI: 0000000000000002 RDI: 000000007ec5b430
Jan 06 22:27:31 Crawler-E25 kernel: RBP: 00007fe1fd3fee20 R08: 0000000000000000 R09: 0000000000000007
Jan 06 22:27:31 Crawler-E25 kernel: R10: 000000007ec51940 R11: 0000000000000293 R12: 0000000000000000
Jan 06 22:27:31 Crawler-E25 kernel: R13: 00000000ffffffff R14: 000000007ec5b430 R15: 000000007edd7e40
Jan 06 22:27:31 Crawler-E25 kernel: UBSAN: array-index-out-of-bounds in /tmp/selfgz8635/NVIDIA-Linux-x86_64-535.146.02/kernel/nvidia-uvm/uvm_pmm_gpu.c:829:45
Jan 06 22:27:31 Crawler-E25 kernel:  merge_gpu_chunk+0x57/0x1d0 [nvidia_uvm]
Jan 06 22:27:31 Crawler-E25 kernel:  free_chunk_with_merges+0x13d/0x180 [nvidia_uvm]
Jan 06 22:27:31 Crawler-E25 kernel: UBSAN: array-index-out-of-bounds in /tmp/selfgz8635/NVIDIA-Linux-x86_64-535.146.02/kernel/nvidia-uvm/uvm_pmm_gpu.c:857:39
Jan 06 22:27:31 Crawler-E25 kernel:  merge_gpu_chunk+0xc6/0x1d0 [nvidia_uvm]
lsd@Crawler-E25:~$ sudo journalctl --since "22:23:00"
Jan 26 22:23:18 Crawler-E25 wpa_supplicant[987]: wlp2s0: WPA: Group rekeying completed with e4:f4:c6:a9:49:c8 [GTK=CCMP]
Jan 26 22:23:19 Crawler-E25 kwin_wayland_wrapper[1774]: kwin_xwl: Could not create a source from 0x55cbb53deb50 0
Jan 26 22:23:21 Crawler-E25 kernel: traps: steamwebhelper[36210] trap invalid opcode ip:7f0e35ccc09b sp:7ffed9ff4610 error:0 in libcef.so[7f0e31afb000+7770000]
Jan 26 22:23:22 Crawler-E25 plasmashell[45368]: steamwebhelper.sh[45368]: Runtime for steamwebhelper: defaulting to /home/lsd/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
Jan 26 22:23:22 Crawler-E25 plasmashell[45368]: steamwebhelper.sh[45368]: glibc >= 2.34, partially disabling sandbox until CEF supports clone3()
Jan 26 22:23:22 Crawler-E25 xdg-desktop-portal-kde[2805]: xdp-kde-settings: Namespace  "org.gnome.desktop.interface"  is not supported
Jan 26 22:23:24 Crawler-E25 plasmashell[5879]: BuildCompleteAppOverviewChange: 191 apps
Jan 26 22:23:24 Crawler-E25 plasmashell[5879]: RegisterForAppOverview 1: 7ms
Jan 26 22:23:24 Crawler-E25 plasmashell[5879]: RegisterForAppOverview 2: 7ms
Jan 26 22:23:25 Crawler-E25 pressure-vessel-wrap[46447]: x86_64-linux-gnu-capsule-capture-libs: warning: Dependencies of libnvidia-pkcs11.so.535.154.05 not found, ignoring: Missing depend>
Jan 26 22:23:25 Crawler-E25 plasmashell[5879]: src/tier1/fileio.cpp (3991) : Assertion Failed: statvfs64 failed for /media/lsd/362CBBA642F61AA6/SteamLibrary, errno 2 No such file or direc>
Jan 26 22:23:26 Crawler-E25 plasmashell[1872]: kpipewire_logging: Window not available PipeWireSourceItem_QML_1006(0x5576bc1fddd0, parent=0x5576bdf3a840, geometry=0,0 138x61)
Jan 26 22:23:26 Crawler-E25 plasmashell[46559]: realpath errno 2
Jan 26 22:23:26 Crawler-E25 plasmashell[5879]: src/tier1/fileio.cpp (4022) : disk-free command failed
Jan 26 22:23:26 Crawler-E25 pipewire[1627]: mod.client-node: 0x559f22c0c7c0: unknown peer 0x559f22e441a0 fd:141
Jan 26 22:23:26 Crawler-E25 plasmashell[1872]: kpipewire_logging: Window not available PipeWireSourceItem_QML_1006(0x5576befe5ab0, parent=0x5576bad43720, geometry=0,0 124x54)
Jan 26 22:23:26 Crawler-E25 plasmashell[46565]: fsync: up and running.
Jan 26 22:23:26 Crawler-E25 plasmashell[46565]: wine: RLIMIT_NICE is <= 20, unable to use setpriority safely
Jan 26 22:23:27 Crawler-E25 kwin_wayland_wrapper[1774]: kwin_screencast: Dropping a screencast frame because the compositor is slow
Jan 26 22:23:28 Crawler-E25 kwin_wayland_wrapper[1774]: kwin_screencast: Dropping a screencast frame because the compositor is slow
Jan 26 22:23:29 Crawler-E25 plasmashell[5879]: /bin/sh\0-c\0/home/lsd/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=1888930 -- /home/lsd/.local/share/Steam/ubuntu12_32/steam-lau>
Jan 26 22:23:29 Crawler-E25 plasmashell[46692]: ERROR: ld.so: object '/home/lsd/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class>
Jan 26 22:23:30 Crawler-E25 plasmashell[46693]: ERROR: ld.so: object '/home/lsd/.local/share/Steam/ubuntu12_64/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class>
Jan 26 22:23:30 Crawler-E25 plasmashell[46694]: ERROR: ld.so: object '/home/lsd/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class>
Jan 26 22:23:30 Crawler-E25 plasmashell[46695]: ERROR: ld.so: object '/home/lsd/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class>
Jan 26 22:23:30 Crawler-E25 pressure-vessel-wrap[46694]: x86_64-linux-gnu-capsule-capture-libs: warning: Dependencies of libnvidia-pkcs11.so.535.154.05 not found, ignoring: Missing depend>
Jan 26 22:23:31 Crawler-E25 plasmashell[46810]: fsync: up and running.
Jan 26 22:23:31 Crawler-E25 plasmashell[46810]: wine: RLIMIT_NICE is <= 20, unable to use setpriority safely
Jan 26 22:23:34 Crawler-E25 plasmashell[46808]: Setting breakpad minidump AppID = 1888930
Jan 26 22:23:34 Crawler-E25 plasmashell[46808]: Steam_SetMinidumpSteamID:  Caching Steam ID:  76561198929852059 [API loaded no]
Jan 26 22:23:35 Crawler-E25 systemd-logind[959]: The system will reboot now!
Jan 26 22:23:35 Crawler-E25 plasmashell[1872]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x7f4898047bf0) QQmlContext(0x5576bbb6f1f0) QUrl("file:///usr/share/plasma/plasmoids/or>
Jan 26 22:23:35 Crawler-E25 systemd-logind[959]: System is rebooting.
Jan 26 22:23:35 Crawler-E25 systemd[1]: unattended-upgrades.service: Deactivated successfully.
In steam commandline forced
PROTON_LOG=1 %command% __NV_PRIME_RENDER_OFFLOAD 1
steam-1888930.log (389.6 KB)
fresh install still same, drivers from january 2024
steam-1888930.log (395.9 KB)
nvidia bootlog
amd bootlog (WORKed untill i changed videocard in preferences, now it doesnt run at all)
świeże uruchomienie.log (4.4 MB)
spoken with someone whos familiar with computing and he said all errors are related to nvidia driver, please consider that :
dymmy.txt (2.7 KB)
steam-1888930.log (381.3 KB)
NVIDIA-SMI 550.54.14
less errors but still needs work
Feb 25 12:28:27 Crawler-E25 pressure-vessel-wrap[5302]: x86_64-linux-gnu-capsule-capture-libs: warning: Dependencies of libnvidia-pkcs11.so.550.54.14 not found, ignoring: Missing dependen>
 warning: Dependencies of libnvidia-pkcs11.so.550.54.14 not found, ignoring: Missing dependencies: Could not find "libcrypto.so.1.1" in LD_LIBRARY_PATH "/usr/lib/x86_64-linux-gnu/libfaker>
ies: Could not find "libcrypto.so.1.1" in LD_LIBRARY_PATH "/usr/lib/x86_64-linux-gnu/libfakeroot:/lib/i386-linux-gnu:/usr/local/lib:/lib/x86_64-linux-gnu:/lib:/home/lsd/.local/share/Steam>
ot:/lib/i386-linux-gnu:/usr/local/lib:/lib/x86_64-linux-gnu:/lib:/home/lsd/.local/share/Steam/steamapps/common/The Last of Us Part I", ld.so.cache, DT_RUNPATH or fallback /lib:/usr/lib
Feb 25 18:26:17 Crawler-E25 pressure-vessel-wrap[18141]: x86_64-linux-gnu-capsule-capture-libs: warning: Dependencies of libnvidia-pkcs11.so.550.54.14 not found, ignoring: Missing dependencies: Could not find "libcrypto.so.1.1" in LD_LIBRARY_PATH "/home/lsd/.local/share/Steam/ubuntu12_32:/home/lsd/.local/share/Steam/ubuntu12_32/panorama:/usr/lib/x86_64-linux-gnu/libfakeroot:/lib/i386-linux-gnu:/usr/local/lib:/lib/x86_64-linux-gnu:/lib", ld.so.cache, DT_RUNPATH or fallback /lib:/usr/lib
Feb 25 18:26:18 Crawler-E25 steam[18250]: fsync: up and running.
Feb 25 18:26:18 Crawler-E25 steam[18250]: wine: RLIMIT_NICE is <= 20, unable to use setpriority safely
Feb 25 18:26:21 Crawler-E25 steam[3170]: /bin/sh\0-c\0PROTON_LOG=1 /home/lsd/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=1888930 -- /home/lsd/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/home/lsd/.local/share/Steam/steamapps/common/SteamLinuxRuntime_sniper'/_v2-entry-point --verb=waitforexitandrun -- '/home/lsd/.local/share/Steam/steamapps/common/Proton - Experimental'/proton waitforexitandrun  '/home/lsd/.local/share/Steam/steamapps/common/The Last of Us Part I/launcher.e>
Feb 25 18:26:21 Crawler-E25 steam[18329]: ERROR: ld.so: object '/home/lsd/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
Feb 25 18:26:21 Crawler-E25 steam[18330]: ERROR: ld.so: object '/home/lsd/.local/share/Steam/ubuntu12_64/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
Feb 25 18:26:21 Crawler-E25 steam[18331]: ERROR: ld.so: object '/home/lsd/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
Feb 25 18:26:21 Crawler-E25 steam[18332]: ERROR: ld.so: object '/home/lsd/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
Feb 25 18:26:22 Crawler-E25 pressure-vessel-wrap[18331]: x86_64-linux-gnu-capsule-capture-libs: warning: Dependencies of libnvidia-pkcs11.so.550.54.14 not found, ignoring: Missing dependencies: Could not find "libcrypto.so.1.1" in LD_LIBRARY_PATH "/usr/lib/x86_64-linux-gnu/libfakeroot:/lib/i386-linux-gnu:/usr/local/lib:/lib/x86_64-linux-gnu:/lib:/home/lsd/.local/share/Steam/steamapps/common/The Last of Us Part I", ld.so.cache, DT_RUNPATH or fallback /lib:/usr/lib
first run after shwitchng viideocard
1szeuruchomienie.log (1.9 MB)
after is that
brown_brothers.log (739.9 KB)
@amrits
Game runs but it crashes with XID 109, please see here, seems to be a driver bug.
