550.78 Drivers performing less than the nouveau -clock stuck in P5-
I’ve installed an old Maxwell Quadro M2000M (MXM) and to my surprise the GPU clock never goes above 405 MHz.
$ nvidia-smi -q
==============NVSMI LOG==============
Timestamp                                 : Tue Jun 11 20:53:12 2024
Driver Version                            : 550.78
CUDA Version                              : 12.4
Attached GPUs                             : 1
GPU 00000000:01:00.0
    Product Name                          : Quadro M2000M
    Product Brand                         : Quadro
    Product Architecture                  : Maxwell
    Display Mode                          : Enabled
    Display Active                        : Enabled
    Persistence Mode                      : Enabled
    Addressing Mode                       : N/A
    MIG Mode
        Current                           : N/A
        Pending                           : N/A
    Accounting Mode                       : Disabled
    Accounting Mode Buffer Size           : 4000
    Driver Model
        Current                           : N/A
        Pending                           : N/A
    Serial Number                         : N/A
    GPU UUID                              : GPU-d8740058-fdf5-d397-047c-9fcef27c658c
    Minor Number                          : 0
    VBIOS Version                         : 82.07.9E.00.0B
    MultiGPU Board                        : No
    Board ID                              : 0x100
    Board Part Number                     : N/A
    GPU Part Number                       : 13B0-975-A2
    FRU Part Number                       : N/A
    Module ID                             : 1
    Inforom Version
        Image Version                     : N/A
        OEM Object                        : N/A
        ECC Object                        : N/A
        Power Management Object           : N/A
    Inforom BBX Object Flush
        Latest Timestamp                  : N/A
        Latest Duration                   : N/A
    GPU Operation Mode
        Current                           : N/A
        Pending                           : N/A
    GPU C2C Mode                          : N/A
    GPU Virtualization Mode
        Virtualization Mode               : None
        Host VGPU Mode                    : N/A
        vGPU Heterogeneous Mode           : N/A
    GPU Reset Status
        Reset Required                    : N/A
        Drain and Reset Recommended       : N/A
    GSP Firmware Version                  : N/A
    IBMNPU
        Relaxed Ordering Mode             : N/A
    PCI
        Bus                               : 0x01
        Device                            : 0x00
        Domain                            : 0x0000
        Base Classcode                    : 0x3
        Sub Classcode                     : 0x0
        Device Id                         : 0x13B010DE
        Bus Id                            : 00000000:01:00.0
        Sub System Id                     : 0x06D91028
        GPU Link Info
            PCIe Generation
                Max                       : 2
                Current                   : 2
                Device Current            : 2
                Device Max                : 3
                Host Max                  : 2
            Link Width
                Max                       : 16x
                Current                   : 16x
        Bridge Chip
            Type                          : N/A
            Firmware                      : N/A
        Replays Since Reset               : 0
        Replay Number Rollovers           : 0
        Tx Throughput                     : 0 KB/s
        Rx Throughput                     : 5 KB/s
        Atomic Caps Inbound               : N/A
        Atomic Caps Outbound              : N/A
    Fan Speed                             : N/A
    Performance State                     : P5
    Clocks Event Reasons
        Idle                              : Not Active
        Applications Clocks Setting       : Not Active
        SW Power Cap                      : Not Active
        HW Slowdown                       : Not Active
            HW Thermal Slowdown           : N/A
            HW Power Brake Slowdown       : N/A
        Sync Boost                        : Not Active
        SW Thermal Slowdown               : Not Active
        Display Clock Setting             : Not Active
    Sparse Operation Mode                 : N/A
    FB Memory Usage
        Total                             : 4096 MiB
        Reserved                          : 84 MiB
        Used                              : 492 MiB
        Free                              : 3522 MiB
    BAR1 Memory Usage
        Total                             : 256 MiB
        Used                              : 41 MiB
        Free                              : 215 MiB
    Conf Compute Protected Memory Usage
        Total                             : 0 MiB
        Used                              : 0 MiB
        Free                              : 0 MiB
    Compute Mode                          : Default
    Utilization
        Gpu                               : 1 %
        Memory                            : 4 %
        Encoder                           : 0 %
        Decoder                           : 0 %
        JPEG                              : N/A
        OFA                               : N/A
    Encoder Stats
        Active Sessions                   : 0
        Average FPS                       : 0
        Average Latency                   : 0
    FBC Stats
        Active Sessions                   : 0
        Average FPS                       : 0
        Average Latency                   : 0
    ECC Mode
        Current                           : N/A
        Pending                           : N/A
    ECC Errors
        Volatile
            Single Bit
                Device Memory             : N/A
                Register File             : N/A
                L1 Cache                  : N/A
                L2 Cache                  : N/A
                Texture Memory            : N/A
                Texture Shared            : N/A
                CBU                       : N/A
                Total                     : N/A
            Double Bit
                Device Memory             : N/A
                Register File             : N/A
                L1 Cache                  : N/A
                L2 Cache                  : N/A
                CBU                       : N/A
                Total                     : N/A
        Aggregate
            Single Bit
                Device Memory             : N/A
                Register File             : N/A
                L1 Cache                  : N/A
                L2 Cache                  : N/A
                CBU                       : N/A
                Total                     : N/A
            Double Bit
                Device Memory             : N/A
                Register File             : N/A
                L1 Cache                  : N/A
                L2 Cache                  : N/A
                CBU                       : N/A
                Total                     : N/A
    Retired Pages
        Single Bit ECC                    : N/A
        Double Bit ECC                    : N/A
        Pending Page Blacklist            : N/A
    Remapped Rows                         : N/A
    Temperature
        GPU Current Temp                  : 45 C
        GPU T.Limit Temp                  : N/A
        GPU Shutdown Temp                 : 101 C
        GPU Slowdown Temp                 : 96 C
        GPU Max Operating Temp            : N/A
        GPU Target Temperature            : 92 C
        Memory Current Temp               : N/A
        Memory Max Operating Temp         : N/A
    GPU Power Readings
        Power Draw                        : N/A
        Current Power Limit               : 200.00 W
        Requested Power Limit             : 200.00 W
        Default Power Limit               : 200.00 W
        Min Power Limit                   : 0.00 W
        Max Power Limit                   : 200.00 W
    GPU Memory Power Readings
        Power Draw                        : N/A
    Module Power Readings
        Power Draw                        : N/A
        Current Power Limit               : N/A
        Requested Power Limit             : N/A
        Default Power Limit               : N/A
        Min Power Limit                   : N/A
        Max Power Limit                   : N/A
    Clocks
        Graphics                          : 405 MHz
        SM                                : 405 MHz
        Memory                            : 800 MHz
        Video                             : 405 MHz
    Applications Clocks
        Graphics                          : N/A
        Memory                            : N/A
    Default Applications Clocks
        Graphics                          : N/A
        Memory                            : N/A
    Deferred Clocks
        Memory                            : N/A
    Max Clocks
        Graphics                          : 1346 MHz
        SM                                : 1346 MHz
        Memory                            : 2505 MHz
        Video                             : 1211 MHz
    Max Customer Boost Clocks
        Graphics                          : N/A
    Clock Policy
        Auto Boost                        : N/A
        Auto Boost Default                : N/A
    Voltage
        Graphics                          : N/A
    Fabric
        State                             : N/A
        Status                            : N/A
        CliqueId                          : N/A
        ClusterUUID                       : N/A
        Health
            Bandwidth                     : N/A
    Processes
        GPU instance ID                   : N/A
        Compute instance ID               : N/A
        Process ID                        : 2008
            Type                          : G
            Used GPU Memory               : 90 MiB
        Process ID                        : 2274
            Type                          : G
            Used GPU Memory               : 135 MiB
        Process ID                        : 3760
            Type                          : G
            Used GPU Memory               : 195 MiB
        Process ID                        : 4607
            Type                          : G
            Used GPU Memory               : 0 MiB
To try our I’ve run the Unigine Valley-1.0 benchmark, and scored a mere 680 (with standard/medium setting). On the bright side, the GPU temperature was a chilling 45C the all time.
I’ve tried older drivers as low as 390 drivers, with similar issue. the card never goes above P5
$ nvidia-smi -q -d PERFORMANCE
Timestamp                                 : Tue Jun 11 20:44:45 2024
CUDA Version                              : 12.4
Attached GPUs                             : 1
        Idle                              : Not Active
Just for curiosity, I’ve removed the nvidia binary and tested the same benchmark with the opensource driver, where I can manually change the performance profile.
Well I got a staggering score of 1500 (with reasonable temperatures around 65C), however the detected GPU RAM was only 1 out of 4Gb, and overall is lacking vulkan support.
So I’d still prefer to run the nvidia 550, given the broken state of the nouveau right now, but I really would like to boost the performance of the card (it’s for light gaming and CAD processing).
I’ve also tried the benchmark on windows (dual boot), where the GPU clock is actually able to reach1346 MHz, but the overall score was around 1200, still a tiny less than the one from the opensource driver. To be fail, the computer is much more sluggish in windows (i5-2500S CPU), so that could be the reason of the poor performance
What can I change to try to make it better?
