Our Jetson Nano custom carrier board has a extended network card that is the same as the Jetson Nano module:r8168;
The current module model is a 2025 new model with part number 699-13448-0002-402;
We have reflashed the L4T32.4.4 version of the system, and all of our software development is based on this software version. We do not want to switch to a new system.
There is a serious issue with this system:
The network card extended R8168 is not working properly, and even the system restarts when unplugging the network cable. Please help analyze the reason for the screenshot of the log.
Thank you for your answer. I have already used this patch, and the system can startup normally with it. But after startup, it was found that the network card was faulty.
