710显卡nvidia-smi
我使用的是七彩虹的gt710显卡,使用的是ubuntu22.04,驱动为NVIDIA-Linux-x86_64-470.129.06.run
问题:
运行烤机软件后使用watch -n 2 -d nvidia-smi 命令查看显卡负载,负载保持在44w不会变化,且下面没有显示正在运行的程序
尝试过重装系统和更换驱动版本都没有解决这个问题,想问一下710显卡驱动不支持显卡负载显示吗
I am using a rainbow gt710 graphics card, using ubuntu22.04, the driver is NVIDIA-Linux-x86_64-470.129.06.run
Question:
After running the oven software, use the watch-n 2-d nvidia-smi command to view the graphics card load, the load remains unchanged at 44w, and no running programs are displayed below
Tried to reinstall the system and replace the driver version did not solve this problem, would you like to ask the 710 graphics card driver does not support the graphics card load display
