I now want to use clothprim for simulation and training, which requires me to reset the scene every time. But I found that every time I use the world.clear() function, the cuda memory will increase by 40MiB, eventually causing cuda out of memory. I also find that self.my_world.scene.add(self.cloth) may cause this issue, if I comment out this line of code and it will not cause memory leaks. Below is my code, modified from the isaacsim.core.api cloth.py.
Isaac Sim Version 4.5.0, Operating System Ubuntu 20.04, GPU 2080Ti, Driver Version 535.183.01
from isaacsim import SimulationApp
simulation_app = SimulationApp({"headless": False})
import argparse
import sys
import carb
import numpy as np
import torch
from isaacsim.core.api import World
from isaacsim.core.api.materials.particle_material import ParticleMaterial
from isaacsim.core.prims import ClothPrim, SingleClothPrim, SingleParticleSystem
from isaacsim.storage.native import get_assets_root_path
from omni.physx.scripts import deformableUtils, physicsUtils
from pxr import Gf, UsdGeom
parser = argparse.ArgumentParser()
parser.add_argument("--test", default=False, action="store_true", help="Run in test mode")
args, unknown = parser.parse_known_args()
assets_root_path = get_assets_root_path()
if assets_root_path is None:
carb.log_error("Could not find Isaac Sim assets folder")
simulation_app.close()
sys.exit()
class ParticleClothExample:
def __init__(self):
self._array_container = torch.Tensor
self.my_world = World(
stage_units_in_meters=1.0,
backend="torch",
device="cuda"
self.my_world.scene.add_default_ground_plane()
self.stage = simulation_app.context.get_stage()
self.num_envs = 10
self.dimx = 5
self.dimy = 5
self.initial_positions = None
self.makeEnvs()
def makeEnvs(self):
for i in range(self.num_envs):
env_path = "/World/Env" + str(i)
env = UsdGeom.Xform.Define(self.stage, env_path)
# set up the geometry
cloth_path = env.GetPrim().GetPath().AppendChild("cloth")
plane_mesh = UsdGeom.Mesh.Define(self.stage, cloth_path)
tri_points, tri_indices = deformableUtils.create_triangle_mesh_square(dimx=5, dimy=5, scale=1.0)
if self.initial_positions is None:
self.initial_positions = torch.zeros((self.num_envs, len(tri_points), 3))
plane_mesh.GetPointsAttr().Set(tri_points)
plane_mesh.GetFaceVertexIndicesAttr().Set(tri_indices)
plane_mesh.GetFaceVertexCountsAttr().Set([3] * (len(tri_indices) // 3))
init_loc = Gf.Vec3f(i * 2, 0.0, 2.0)
physicsUtils.setup_transform_as_scale_orient_translate(plane_mesh)
physicsUtils.set_or_add_translate_op(plane_mesh, init_loc)
physicsUtils.set_or_add_orient_op(plane_mesh, Gf.Rotation(Gf.Vec3d([1, 0, 0]), 15 * i).GetQuat())
self.initial_positions[i] = torch.tensor(init_loc) + torch.tensor(plane_mesh.GetPointsAttr().Get())
particle_system_path = env.GetPrim().GetPath().AppendChild("particleSystem")
particle_material_path = env.GetPrim().GetPath().AppendChild("particleMaterial")
self.particle_material = ParticleMaterial(
prim_path=str(particle_material_path), drag=0.1, lift=0.3, friction=0.6
radius = 0.5 * (0.6 / 5.0)
restOffset = radius
contactOffset = restOffset * 1.5
self.particle_system = SingleParticleSystem(
prim_path=str(particle_system_path),
simulation_owner=self.my_world.get_physics_context().prim_path,
rest_offset=restOffset,
contact_offset=contactOffset,
solid_rest_offset=restOffset,
fluid_rest_offset=restOffset,
particle_contact_offset=contactOffset,
# note that no particle material is applied to the particle system at this point.
# this can be done manually via self.particle_system.apply_particle_material(self.particle_material)
# or to pass the material to the clothPrim which binds it internally to the particle system
self.cloth = SingleClothPrim(
name="clothPrim" + str(i),
prim_path=str(cloth_path),
particle_system=self.particle_system,
particle_material=self.particle_material,
# create a view to deal with all the cloths
self.clothView = ClothPrim(prim_paths_expr="/World/Env*/cloth", name="clothView1")
self.my_world.scene.add(self.clothView)
self.my_world.reset(soft=False)
def play(self):
reset_needed = False
for _ in range(500):
if self.my_world.is_stopped() and not reset_needed:
reset_needed = True
if self.my_world.is_playing():
# deal with sim re-initialization after restarting sim
if reset_needed:
# initialize simulation views
self.my_world.step(render=True)
if self.my_world.current_time_step_index % 50 == 49:
print(
"cloth {} average height = {:.2f}".format(
i, self.clothView.get_world_positions()[i, :, 2].mean()
if args.test is True:
break
# reset some random environments
if self.my_world.current_time_step_index % 200 == 1:
indices = torch.tensor(
np.random.choice(range(self.num_envs), self.num_envs // 2, replace=False), dtype=torch.long
new_positions = self.initial_positions[indices] + torch.tensor([0, 0, 5])
self.clothView.set_world_positions(new_positions, indices)
updated_positions = self.clothView.get_world_positions()
for i in indices:
print("reset index {} average height = {:.2f}".format(i, updated_positions[i, :, 2].mean()))
self.my_world.clear()
while True:
ParticleClothExample().play()
