First, I realise that this is not a supported use case and that this card is designed for servers but I have one laying around and would like to put it to good use.
After reading other threads online I have installed a 40GB A100 in a Dell 7920, I have enabled above 4G decoding, disabled as many built-in devices (ethernet, serial, etc).
128GB Ram
Second nvidia GPU (nvidia t400)
Xeon 4210R (it is PCIe 3.0)
I have installed the A100 in slot 4, which should get the most lanes (I can set the balance in the bios and gave it the maximum possible).
The bios recognises the A100 as a ‘display adapter’ in the correct slot. However the machine just automatically loads the bios setup at each reboot. If I exit it, the machine will reboot but return to the bios setup. If I remove the A100 the machine boots normally.
Does anyone have any ideas what could be causing this?
