A2F 2021.2.5 is now available for download
Hi everyone! Audio2Face 2021.2.5 is now available on the launcher for download. Updates for this version include.
  • Added Tooltips.
  • Auto transform fix for DeltaBlend.
  • Full Undo Wrap UI support.
  • Ability to Delete multiple Transfer Setups.
  • Terminal nodes performance fix - can now be enabled.
  • Fix on Mesh Fitting window not showing up when there is no Default Prim present.
  • Correspondence undo.
  • Allows Recent files, bookmarks, and other app history to function as expected.
  • Mesh Fitting fix for mesh containing points without connections.
  • Viewport draw node type update.
  • omni.audio2face.node_updater extension which update nodetype automatically.
    • Updated file is not backward compatible!
  • Initial Preset feature.
Hi, I have 2021.2.5 installed but it won’t launch, any ideas what is wrong. I’m on a 2080ti, 32gb ram, latest studio driver 462.59.
Jonny
What windows version are you using?
Hi Simon,
I’m on 10.0.19041
If I run the .bat I get these errors
Jonny
The error helps. Thanks. There are a few people who got similar issue and we put this info in the FAQ. It so far has fixed everyone’s issue related to this error. Give it a try and see if it works for you and let us know.
also can you click on the task menu and type “winver” and screenshot the version here? like this:
