I have flashed jetson Nano(full component with deepstream sdk) through SDK Manager.
/dev/mmcblk0p1 size is 14G
I’m using 128GB sdcard.
Can I expand app size?
Thank you.
Thank you.
By default, jetpack4.4 will extend the partition size. Please try to use jetpack4.4.
Please try 4.4GA and set the partition size in the first boot time (during your account configuration).
What is 4.4GA?
I cannot find this
Can you show me a screenshot ?
Thank you
How can I install deepstream sdk through JetPack 4.4?
I cannot find deepstream sdk in this screen.
Thank you.
hello,
I can’t find screen of setting the partition size while configuring ubuntu.
After login, can I resize the partision size?
Thank you.
I did exactly that and the APP partition size option was not shown in the last steps.
Thank you.
When I use SD card image I met following image.
If I install jetpack4.4GA(not 4.4DP) using sdk manager, you cannot see the above screen.
Can you cross check using sdk manager?
Thank you
Looks like sdkmanager does not provide this configuration.
Could you use sdcard image at this moment?
i got the same issue. have no idea now.
Thank you.
When can I resize the partition through sdk manager?
Can you roughly tell me the date the solution comes out?
Hi neuezeal,
Have you resolved the issue?
Any further support required?
There is still no part of changing the app partition size when installing jetpack4.4 through SDK manager.
When can it be reflected?
Thank you.
When will that part be revised?
Still, when installing jetpack4.4 through sdk manager, the screen to change the partition size does not appear.
Thank you.
Please use -S parameter in flash.sh to workaround this issue
Hello
If I use the sdk manager, you just click on the GUI and follow the instructions, where do you put the parameters?
Thank you.
Not sure if you know how to run flash.sh. I assumed you already knew because you even tried something like massflashgen.sh if I remember correctly…
SDKmanager also uses the flash.sh to flash your board. We just make it a GUI to help you people to get into jetson world eaiser.
However, this GUI tool is not smart enough to use all the functions of flash.sh. That is why you cannot use sdkmanager at this moment.
Workaround means a temporary solution. We cannot make sdkmanager to provide a window for you to configure partition size now so sharing an alternative to you instead.
