Would it be possible to perform a emulation change (i.e. Orin NX 16GB to NX 8GB) on my Jetson AGX Orin Developer Kit?
To emulate performance of Jetson AGX Orin 64GB, Jetson AGX Orin 32GB, Jetson Orin NX 16GB and Jetson Orin NX 8GB modules, you can refer to the emulation section in release notes for detail.
Hi @kayccc , thanks for your prompt reply. So it seems we have to place our developer kit in Force Recovery Mode for the emulation, which means it’s not likely to do this remotely (place command via SSH), correct?
Hi aliu1,
Yes, you need put device into recovery mode and flash with below two configs for emulation as Orin NX 16GB/8GB.
jetson-agx-orin-devkit-as-nx-16gb.conf
jetson-agx-orin-devkit-as-nx-8gb.conf
Hi @carolyuu , noted, it’s clear now, thank you very much.
