Problem emulating ORIN NX on the ORIN AGX
We’re trying to flash the 8gb ORIN NX emulation on the AGX devkit.
The flash process (from a laptop connected to the board) is successful, but the device does not boot afterwards.
It neither connects to the screen nor allow an ssh connection.
Re-flashing the AGX original setup returns it to normal operation.
Any help would be appreciated…
Please describe more clearly for what did you do to flash the AGX Orin device to emulate it as Jetson Orin NX 8GB.
Hi amir6,
What flash command are you using?
