I’m testing a server, Dell R720XD + Grid K2, using VMWARE ESXi 6.5
The problem encountered is VMWARE will appear red screen.
According to the manufacturer’s advice, I upgraded Dell’s latest BIOS, using the Dell version of VMWARE;
I tried to expand the memory capacity and power supply, and all the problems that can not be solved, still can not solve the VMWARE crash problem.
When I do not install K2 driver, or not in the virtual machine to enable K2-related configuration, the whole system everything is normal, once I enable K2-related configuration, no matter what kind of drive mode, will lead to the rapid emergence of VMWARE red screen situation The
I judge may be related to the heat dissipation of K2, because I feel K2 temperature is very high, and I use the command to view the equipment situation, the temperature was found as high as 95 degrees Celsius.
Wed Mar 8 15:12:34 2017
| NVIDIA-SMI 367.64 Driver Version: 367.64 |
| 0 GRID K2 On | 0000:44:00.0 Off | Off |
| N/A 98C P8 34W / 117W | 3837MiB / 4095MiB | 0% Default |
| 1 GRID K2 On | 0000:45:00.0 Off | Off |
| N/A 81C P8 31W / 117W | 3837MiB / 4095MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 68203 C+G WIN10 B 3824MiB |
| 1 68202 C+G WIN10 A 3824MiB |
Will this temperature K2 can run properly? Because K2 is a passive cooling mode, and I did not find the relevant parameters, can not confirm the safe operation of the temperature?
What should I do if I have to improve the heat problem?
